    Fishing net modeling
    131 Posts 12 Posters 24.1k Views 12 Watching
    • W Offline
      willipop
      I'm stupid ^^ πŸŽ‰
      humhum1.mov
        That i have said! That was yet in Su native! πŸ’š
        About another crease I don't see one for the moment like that
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/494823496.png
        I don't see that in VertexTool's manual by Thomthom in French! πŸ˜‰
        That you can make is use the inverse selection by TIG Freeze and apply that you want on a wished selection?
        • W Offline
          willipop
          I'm still up ! hΓ©hΓ© πŸ˜‰
          • olisheaO Offline
            olishea
            I take it you're working to a deadline! πŸ˜†
            oli
            • BoxB Offline
              There might be a deadline involved, but I suspect there are the glassy eyes of sketchup addiction twitching away through the night.
              • W Offline
                willipop
                Here's what i did the past few days πŸ˜„ 2 scenario because its an interactive net that goes up and down as the tide interact.
                Draw wire and EByR plugins were very helpful πŸ˜„
                This file is about 7megs.
                I did use the line to cylinder it's working great but I took me several hour as I did each group of net one by one. The file is like 140meg πŸ˜•
                I did some test with kerkythea for the rendering it crashed many times, the model is too complex πŸ˜• I'm not sure how to proceed for the next phase.
                My deadline is in 10days ahah ! πŸ˜„
                lower net
                higher net
                solid net, huge file ! :(
                • BoxB Offline
                  Did you make every piece different?
                  Can you not work it so you are using repeating components?
                  How many faces did you use on the tubes, any more than 3 is probably wasted.
                  • W Offline
                    willipop
                    everything is different πŸ˜•
                    • BoxB Offline
                      If you are doing it for accurate technical construction drawing I can understand that, but if it's for rendering then make it from repeat sections.
                      • W Offline
                        willipop
                        here's a link for the sketchup file : I really like the way the net is shaped πŸ˜„
                        ERROR: The request could not be satisfied
                        (we.tl)
                        • BoxB Offline
                          I don't have a computer that will cope with it at the moment.
                          • W Offline
                            willipop
                            It's the 7meg file, without the edges in solid tube!
                            • BoxB Offline
                              Personally to me the difference from one side to the other is so small that I would make them symmetrical.
                              You would reduce the file size enormously.
                              • W Offline
                                willipop
                                once the file is open, I can easly navigate in it. I now have to find a nice way to render πŸ˜„
                                • BoxB Offline
                                  Ah well, I can't help you much there, my only rendering experience is with Twilight.
                                  • W Offline
                                    willipop
                                    I will test to export the shadows from sketchup and tweak it with photoshop
                                    • BoxB Offline
                                      Oli will probably pop back soon, he knows far more about rendering than me.
                                      • W Offline
                                        willipop
                                        I never learned a software that fast. Thx to all of you guys, I really appreciate ! I will subscribe to premium member ^_^
                                        • BoxB Offline
                                          It's worth pointing out that components can be scaled and and modified and still be instances of the same component.
                                          As you can see in this image I have used one component in three places, I used Fredoscale to scale and shear them to fit in the required spaces, I didn't bother to be too accurate as it's only an example.
                                          It's a bit more work in some ways to pull them into shape, but it's means less tube making. So if you were to fit 10 nets this way you only have to make one set of tubes to get 10 full nets.
                                          Something to keep in mind for the future.
                                          • W Offline
                                            willipop
                                            hi mates ! πŸ˜„
                                            quick screenshot of one perspective I did last night ^^
                                            • 6 / 7
