    Fishing net modeling
    131 Posts 12 Posters 20.5k Views 12 Watching
    • W Offline
      willipop
      woaa this plugin is amazing ! you rock 😄
      • BoxB Offline
        You can go denser, that whole file is only 6mg and doesn't lag at all with shadows.
        I used another plugin called Wire tool to link the construction points with a nice droop. Then just did as I did in the video. for each section.
        I only used 12 segments for the curves, so that makes it quite wide, you can use more to get a finer mesh. http://sketchucation.com/pluginstore?pln=ae_WireTool
        You may want to use the main wires as thicker support cables, then make the mesh between.
        But it's up to you how you want it to look.
        The trick though is to make it using copies as much as possible. Make one end and flip the components to work on the other end etc
        The render is just a basic preset render from twilight. And as you can see in this one when I flipped it it didn't fit because you structure isn't symmetrical, hence the gap in the middle.
        A finer mesh with some thick cables
        • W Offline
          willipop
          This plugin makes it looks really nice !
          Is there another plugin that I could use to fix some summit and use some other summit that I could move.(just like artisan works with the crease tool.) vertex tool ?
          • olisheaO Offline
            olishea
            gets better and better! I forgot about the wire tool, it's a classic!
            oli
              Perfect for some hammock! ☀
              Au fait j'ai fait la version francophone d'Artisan! 😉
              http://www.endalldisease.com/wp-content/uploads/2013/09/hammock.jpg
              Normally Su make that in native ? 😄
              Sélection verrouillée ou non ?
              • W Offline
                willipop
                ahaha 😄 I wish I could lay down in a hammac ! Mon pays c'est l'hiver ! 😕
                Génial Pilou ! Tu sais s'il existe un outil similaire à l'outil ''cease d'artisan'' comme sur la photo dont je viens de poster? 😄
                • W Offline
                  willipop
                  Here's what I mean. See the physic is nice when one line is moved, but it moves at the end (bottom left) too... I'd like to be able to simulate where is the net goes when it drop !
                  test1.mov
                  • W Offline
                    willipop
                    I'm stupid ^^ 🎉
                    humhum1.mov
                      That i have said! That was yet in Su native! 💚
                      About another crease I don't see one for the moment like that
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/494823496.png
                      I don't see that in VertexTool's manual by Thomthom in French! 😉
                      That you can make is use the inverse selection by TIG Freeze and apply that you want on a wished selection?
                      • W Offline
                        willipop
                        I'm still up ! héhé 😉
                        • olisheaO Offline
                          olishea
                          I take it you're working to a deadline! 😆
                          oli
                          • BoxB Offline
                            There might be a deadline involved, but I suspect there are the glassy eyes of sketchup addiction twitching away through the night.
                            • W Offline
                              willipop
                              Here's what i did the past few days 😄 2 scenario because its an interactive net that goes up and down as the tide interact.
                              Draw wire and EByR plugins were very helpful 😄
                              This file is about 7megs.
                              I did use the line to cylinder it's working great but I took me several hour as I did each group of net one by one. The file is like 140meg 😕
                              I did some test with kerkythea for the rendering it crashed many times, the model is too complex 😕 I'm not sure how to proceed for the next phase.
                              My deadline is in 10days ahah ! 😄
                              lower net
                              higher net
                              solid net, huge file ! :(
                              • BoxB Offline
                                Did you make every piece different?
                                Can you not work it so you are using repeating components?
                                How many faces did you use on the tubes, any more than 3 is probably wasted.
                                • W Offline
                                  willipop
                                  everything is different 😕
                                  • BoxB Offline
                                    If you are doing it for accurate technical construction drawing I can understand that, but if it's for rendering then make it from repeat sections.
                                    • W Offline
                                      willipop
                                      here's a link for the sketchup file : I really like the way the net is shaped 😄
                                      (we.tl)
                                      • BoxB Offline
                                        I don't have a computer that will cope with it at the moment.
                                        • W Offline
                                          willipop
                                          It's the 7meg file, without the edges in solid tube!
                                          • BoxB Offline
                                            Personally to me the difference from one side to the other is so small that I would make them symmetrical.
                                            You would reduce the file size enormously.
                                            • 6 / 7
