    Fishing net modeling
    131 Posts 12 Posters 26.2k Views 12 Watching
    • W
      willipop
      ahaha πŸ˜„ I wish I could lay down in a hammac ! Mon pays c'est l'hiver ! πŸ˜•
      GΓ©nial Pilou ! Tu sais s'il existe un outil similaire Γ  l'outil ''cease d'artisan'' comme sur la photo dont je viens de poster? πŸ˜„
      • W
        willipop
        Here's what I mean. See the physic is nice when one line is moved, but it moves at the end (bottom left) too... I'd like to be able to simulate where is the net goes when it drop !
        test1.mov
        • W
          willipop
          I'm stupid ^^ πŸŽ‰
          humhum1.mov
            That i have said! That was yet in Su native! πŸ’š
            About another crease I don't see one for the moment like that
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/494823496.png
            I don't see that in VertexTool's manual by Thomthom in French! πŸ˜‰
            That you can make is use the inverse selection by TIG Freeze and apply that you want on a wished selection?
            • W
              willipop
              I'm still up ! hΓ©hΓ© πŸ˜‰
              • olisheaO
                olishea
                I take it you're working to a deadline! πŸ˜†
                oli
                • BoxB
                  There might be a deadline involved, but I suspect there are the glassy eyes of sketchup addiction twitching away through the night.
                  • W
                    willipop
                    Here's what i did the past few days πŸ˜„ 2 scenario because its an interactive net that goes up and down as the tide interact.
                    Draw wire and EByR plugins were very helpful πŸ˜„
                    This file is about 7megs.
                    I did use the line to cylinder it's working great but I took me several hour as I did each group of net one by one. The file is like 140meg πŸ˜•
                    I did some test with kerkythea for the rendering it crashed many times, the model is too complex πŸ˜• I'm not sure how to proceed for the next phase.
                    My deadline is in 10days ahah ! πŸ˜„
                    lower net
                    higher net
                    solid net, huge file ! :(
                    • BoxB
                      Did you make every piece different?
                      Can you not work it so you are using repeating components?
                      How many faces did you use on the tubes, any more than 3 is probably wasted.
                      • W
                        willipop
                        everything is different πŸ˜•
                        • BoxB
                          If you are doing it for accurate technical construction drawing I can understand that, but if it's for rendering then make it from repeat sections.
                          • W
                            willipop
                            here's a link for the sketchup file : I really like the way the net is shaped πŸ˜„
                            ERROR: The request could not be satisfied
                            (we.tl)
                            • BoxB
                              I don't have a computer that will cope with it at the moment.
                              • W
                                willipop
                                It's the 7meg file, without the edges in solid tube!
                                • BoxB
                                  Personally to me the difference from one side to the other is so small that I would make them symmetrical.
                                  You would reduce the file size enormously.
                                  • W
                                    willipop
                                    once the file is open, I can easly navigate in it. I now have to find a nice way to render πŸ˜„
                                    • BoxB
                                      Ah well, I can't help you much there, my only rendering experience is with Twilight.
                                      • W
                                        willipop
                                        I will test to export the shadows from sketchup and tweak it with photoshop
                                        • BoxB
                                          Oli will probably pop back soon, he knows far more about rendering than me.
                                          • W
                                            willipop
                                            I never learned a software that fast. Thx to all of you guys, I really appreciate ! I will subscribe to premium member ^_^
                                            • 6 / 7
