[Plugin] RichSection V0.5.8 UPDATED march 2015
@caronte01 said:
...., some of the cut geometry will not create a face....
This is the first time i see a solid not producing a section face in RichSection.
It's not a matter of complexity. Even when i copy the solid group in an empty model it doesn't want to produce a horizontal cut. The solid group is part of a component. In 2 of the 3 instances it produces a section-cut.
The only way to correct : redefine de geometry:
-you can redraw
-faster (tested on SU 2013 and SU2014: open the group (or component) containing only edges and faces (use Menu/Component edit/Hide rest of model +Hide similar); Select all edges and faces ; copy ; past in place ; close the nested groups & components >> Sketchup will redefine (simplify) all faces and edges ; update de RichSection. -
- Different scenes with same style : is on my 'todo' list, but ruby 2.0 / SU2014 came inbeween.
To change the scene style and purge the unused styles :
Activate scene 001; In the scene panel : select multiple scenes : 001, 002, 003...;
Update : in the options unselect everyting except 'style'; Section plan visibility, cut color, cut line width are in the scene style.
they will be the same.
Do the same for 001_,002_, .... . - 1 scene : this option is in the settings : [highlight=#ffffbf:hjq3xewl]Menu/Plugins/RichSection/Settings[/highlight:hjq3xewl]
- renaming : bug
- no section face for some elements: can you send me a file or part of your file ? (Post can be privat, i will only use your file for debugging)>> see my post on 25 Mar 2014 23:39, below
Thanks for reporting.
Perfect. It can be solved. So cut, and then paste in place will force a redraw.... Great! Thanks
Hi Pgarmyn,
An error occurred in present version V0.3.1 as shown below. Thus could not find the RichSection tool as well.Please make any suggestions.
Thank you.
Correction : i did Copy + Past in place
Double geometry will be 'unified' >> geometry will be redefined -
@chooyod said:
Hi Pgarmyn,
Thank you.Please complete your profile : MAC or WINDOWS ?
MAC : not compatible yet.You also have an error on Loading ExtrudeTools.rb >>Permission denied
ExtrudeTools.rb is not part of my Plugin, i think it is TIG'sDid you restart Sketchup after the update ?
I suggest to- Un-install the RichSection plugin manually (Sketchucation Tools only renames the loader): go to de plugin directory and delete PiGa_RichSection.rb (or extensions .rb! .rbx) and folder PiGa_RichSection; for older versions :delete RichSection_loader.rb (or extensions .rb! .rbx) and folder RichSection;
- restart Sketchup
- Re-instal RichSection using Plugin Store & Sketchucation Tools
- close and restart Sketchup
@chooyod said:
Hi Pgarmyn,
Thank you.
Looks like you have got your v8 PC Plugins folder [and its contents] 'Security Permissions' all messed up...
Read this http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
This error does not relate directly to this specific Plugin - it also refers to mine.
But rather to the fact that things are NOT installed properly - a user issue rather than a specific plugin problem
IF you have FULL security permissions setup properly for the Plugins folder and its contents, then ALL Plugins will be installed properly, then read-in and loaded... and then be available for use after SketchUp has loaded...
You will also need to reinstall any Plugins that still display errors, as some of their files might be within your Windows VirtualStore, rather where you think they are... A 'Compatibilities Files...' link/button on the top-bars of your Plugins folder's Windows Explorer window is a give away! -
Hi pgarmyn
As I mentioned before, I´ve got a mac available to test your plugin. Initially, it installed and loaded ok, but most menu items did nothing. I did a small video and saved a log file.
Here´s a link:
https://www.dropbox.com/sh/4jox3nm6m42sudv/rPghb2aQ8P
What should I test specifically?
I´m posting this separately to try and keep this thread organized.
Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
This is set per scene, not globally.
Santiago
Any ideas on my errors? I'm dying to try this out.
Maybe a FR to turn thumbnails creation from ruby on or off to trimble. Quite annoying, and imo not that useful.
@caronte01 said:
.....Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
Santiago
Thumbnails : http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=31349#p275878
Can only be switched off for the model, not for one scene.I hope to send you the next RichSection version for testing this weekend.
@arcad-uk said:
I was about to check the models TIG worked with and got the same EXPIRED DEMO message.
And others. ......
[highlight=#ffff40:2atg51ts]Sorry. childhood illness
I'll fix that tomorrow. [/highlight:2atg51ts] -
@bimbachi said:
@pgarmyn said:
@davecoopstl said:
pgarmyn -
THERE ARE MANY PROBLEMS WITH MAC
MAC USERS, PLEASE WAIT :
IS THERE SOME MAC-VOLUNTEER TO HELP WITH SOME TESTINGI dont have ruby knowlege, but as user testing , I can give a try.
I'm using skp pro version 8 only with a lot of addons so conflict with other plugs is possibul.
However sketchucation store plug alows to do some limted sets if needed.I would like to be a volunteer
@caronte01 said:
Hi pgarmyn
Here´s a link:
Is this still available some where
@rombout said:
As I mentioned before, I´ve got a mac available to test your plugin. .....
I will send you the next pre-release. Probably this weekend.
Thanks. -
If you want a mac tester I'm volunteering.
prader- at - nvizeon - dot - com
after instal / load errors:
Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader.rb
private methodgsub' called for nil:NilClassError Loading File PiGa_RichSection.rb private method
gsub' called for nil:NilClassand ruby console :
RS: START DEBUG
RS0.4.1|2.479|
Start Logfile____ __________________________________________/var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T//RichSection_log.txt
RS0.4.1|0.154|
RichSection plugin __________________________________________#<SketchupExtension:0xecfc6d8
@name="RichSection",
@registered=true,
@version="V0.4.1-RC-2014.04.20-20:30 DEMO",
@loaded=false,
@path="/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader",
@copyright=" 2013, All rights reserved for RichSection plugin : Name, code and functionality are the intellectual property of the author. Distribution, reproduction or integration of code or functionality, even partly, is only permitted with the explicit permission of the author",
@description="Creats 'SECTION materials' based on 'layer' or 'nature' of groups and components (if section is a closed polygone). PROJECTs elements above the sectionplane as pointed lines. SECTION and PROJECTION are placed in a 'RichSection' group, respecting the same (nested) structure as the model. Switching layers 'on' and 'off' will swich the corresponding 'RichSection' information.",
@load_on_start=false,
@creator="Piet Garmyn, Luxembourg (pgarmyn)">
RS0.4.1|0.004|
User info____________________________________________________{"PATH"=>"/usr/bin:/bin:/usr/sbin:/sbin",
"GOOGLE_GILD_RUNTIME_FRAMEWORK_ABSOLUTE_PATH"=>"/Library/Google/Frameworks/Gild.framework",
"TMPDIR"=>"/var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T/",
"SHELL"=>"/bin/bash",
"HOME"=>"/Users/tignaciuk",
"USER"=>"tignaciuk",
"LOGNAME"=>"tignaciuk",
"SSH_AUTH_SOCK"=>"/tmp/launch-AjI9WA/Listeners",
"Apple_PubSub_Socket_Render"=>"/tmp/launch-qOUkYE/Render",
"DISPLAY"=>"/tmp/launch-hvrCBq/org.macosforge.xquartz:0",
"COM_GOOGLE_CHROME_FRAMEWORK_SERVICE_PROCESS/USERS/TIGNACIUK/LIBRARY/APPLICATION_SUPPORT/GOOGLE/CHROME_SOCKET"=>"/tmp/launch-Qsk4v0/ServiceProcessSocket",
"__CF_USER_TEXT_ENCODING"=>"0x1F6:29:42",
"__CHECKFIX1436934"=>"1",
"IG_ROOT"=>"/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"}
RS0.4.1|0.040|PiGaRSection.start_debug :
RS0.4.1|0.008|Logging to RubyPanel : true
RS0.4.1|0.006|Logging to File : true
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:27: warning: don't put space before argument parentheses
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:42: warning: don't put space before argument parentheses
(eval):2837: warning: parenthesize argument(s) for future version
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:16: warning: already initialized constant VERSION_PATTERN
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:23: warning: already initialized constant THEME_DEFAULT
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:24: warning: already initialized constant THEME_GRAPHITE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:31: warning: already initialized constant EVENT_WINDOW_READY
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:43: warning: already initialized constant EVENT_CALLBACK
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:70: warning: already initialized constant EVENT_OPEN_URL
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
(eval):344: warning: don't put space before argument parentheses
(eval):444: warning: don't put space before argument parentheses
(eval):666: warning: don't put space before argument parentheses
(eval):1221: warning: don't put space before argument parentheses
(eval):1403: warning: don't put space before argument parentheses
(eval):1627: warning: don't put space before argument parentheses
(eval):2702: warning: don't put space before argument parentheses
(eval):2703: warning: don't put space before argument parentheses
(eval):2824: warning: don't put space before argument parentheses
(eval):2845: warning: don't put space before argument parentheses
(eval):935: warning: don't put space before argument parentheses
(eval):936: warning: don't put space before argument parentheses
(eval):939: warning: don't put space before argument parentheses
(eval):943: warning: don't put space before argument parentheses
(eval):1520: warning: don't put space before argument parentheses
(eval):2496: warning: don't put space before argument parentheses
(eval):2498: warning: don't put space before argument parentheses
(eval):2531: warning: don't put space before argument parentheses
(eval):2533: warning: don't put space before argument parentheses
(eval):2973: warning: don't put space before argument parentheses
(eval):2983: warning: don't put space before argument parentheses
(eval):2994: warning: don't put space before argument parentheses
(eval):3004: warning: don't put space before argument parentheses
(eval):3102: warning: don't put space before argument parentheses
(eval):3129: warning: don't put space before argument parentheses
(eval):3138: warning: don't put space before argument parentheses
(eval):3143: warning: don't put space before argument parentheses
(eval):3220: warning: don't put space before argument parentheses
(eval):3223: warning: don't put space before argument parentheses
(eval):3226: warning: don't put space before argument parentheses
(eval):3268: warning: don't put space before argument parentheses
(eval):3269: warning: don't put space before argument parentheses
(eval):3324: warning: don't put space before argument parentheses
(eval):3325: warning: don't put space before argument parentheses
(eval):3506: warning: don't put space before argument parentheses
(eval):4556: warning: don't put space before argument parentheses
(eval):4635: warning: don't put space before argument parentheses
(eval):4997: warning: don't put space before argument parentheses
(eval):5052: warning: don't put space before argument parentheses
(eval):5096: warning: don't put space before argument parentheses
(eval):5100: warning: don't put space before argument parentheses
(eval):9026: warning: don't put space before argument parentheses
(eval):9026: warning: parenthesize argument(s) for future version
(eval):191: warning: don't put space before argument parentheses
(eval):291: warning: don't put space before argument parentheses
(eval):758: warning: don't put space before argument parentheses
(eval):906: warning: don't put space before argument parentheses
(eval):692: warning: don't put space before argument parentheses
(eval):699: warning: don't put space before argument parentheses
(eval):719: warning: don't put space before argument parentheses
(eval):739: warning: don't put space before argument parentheses
(eval):746: warning: don't put space before argument parentheses
(eval):766: warning: don't put space before argument parentheses
(eval):786: warning: don't put space before argument parentheses
7
(eval):3119: warning: parenthesize argument(s) for future version
(eval):3142: warning: parenthesize argument(s) for future version
key = Units
value = 0.0and log files attached
cheers
RichSection_log_140421-201054.txt
Thanks Bimbachi
I'll work on it.
Please, for readability,, don't copy the whole log in this post. -
Got it loaded on my mac I'll kick the tires on it later. Thanks for the Mac version
