    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
      caronte01
      Hi pgarmy
      A couple of questions:
      Is there a need to have a style created per scene? In the model I´m working on right now, I have 15 rich sections, and that creates 15 different styles. Maybe have a switch to create only two, when the first rich section is created?
      I know it has been asked before, but an option to only create 1 scene instead of two. I kind of understand, from reading previous posts that it is necessary, but maybe an option to only create one.
      There is a bug (i think). I renamed a couple of rich sections with the context menu. The layer was renamed accordingly, but only one of the two scenes was.
      Also, some of the cut geometry will not create a face. I checked and they are solids (report a volume). What else should I look for when this happens?
      Santiago
        caronte01
        @pgarmyn said:
        • 1 scene : it's already in the settings
        Hi Pgarmyn,
        Sorry to ask, but how, I looked through the entire topic and could not find it?
        Thanks for your time!
        S
        Edit:
        Thanks for clarifying. Lots of settings to play with.....
          pgarmyn
          @caronte01 said:
          ....and could not find it?...
          I'v put a picture of the 'RichSection Setting' panel in my previous post.
          Update your plugin if you don't have those settings in Menu/plugin/RichSection/settings 😉
            pgarmyn
            @caronte01 said:
            ...., some of the cut geometry will not create a face....
            This is the first time i see a solid not producing a section face in RichSection.
            It's not a matter of complexity. Even when i copy the solid group in an empty model it doesn't want to produce a horizontal cut. The solid group is part of a component. In 2 of the 3 instances it produces a section-cut.
            The only way to correct : redefine de geometry:
            -you can redraw
            -faster (tested on SU 2013 and SU2014: open the group (or component) containing only edges and faces (use Menu/Component edit/Hide rest of model +Hide similar); Select all edges and faces ; copy ; past in place ; close the nested groups & components >> Sketchup will redefine (simplify) all faces and edges ; update de RichSection.
              pgarmyn
              @caronte01
              • Different scenes with same style : is on my 'todo' list, but ruby 2.0 / SU2014 came inbeween.
                To change the scene style and purge the unused styles :
                Activate scene 001; In the scene panel : select multiple scenes : 001, 002, 003...;
                Update : in the options unselect everyting except 'style'; Section plan visibility, cut color, cut line width are in the scene style.
                they will be the same.
                Do the same for 001_,002_, .... .
              • 1 scene : this option is in the settings : [highlight=#ffffbf:hjq3xewl]Menu/Plugins/RichSection/Settings[/highlight:hjq3xewl]
                RichSection Settings (Version 0.3.0)
              • renaming : bug
              • no section face for some elements: can you send me a file or part of your file ? (Post can be privat, i will only use your file for debugging)>> see my post on 25 Mar 2014 23:39, below
                Thanks for reporting.
                caronte01
                Perfect. It can be solved. So cut, and then paste in place will force a redraw.... Great! Thanks
                  chooyod
                  Hi Pgarmyn,
                  An error occurred in present version V0.3.1 as shown below. Thus could not find the RichSection tool as well.
                  Please make any suggestions.
                  Thank you.
                    pgarmyn
                    Correction : i did Copy + Past in place
                    Double geometry will be 'unified' >> geometry will be redefined
                      pgarmyn
                      @chooyod said:
                      Hi Pgarmyn,
                      Thank you.
                      Please complete your profile : MAC or WINDOWS ?
                      MAC : not compatible yet.
                      You also have an error on Loading ExtrudeTools.rb >>Permission denied
                      ExtrudeTools.rb is not part of my Plugin, i think it is TIG's
                      Did you restart Sketchup after the update ?
                      I suggest to
                      • Un-install the RichSection plugin manually (Sketchucation Tools only renames the loader): go to de plugin directory and delete PiGa_RichSection.rb (or extensions .rb! .rbx) and folder PiGa_RichSection; for older versions :delete RichSection_loader.rb (or extensions .rb! .rbx) and folder RichSection;
                      • restart Sketchup
                      • Re-instal RichSection using Plugin Store & Sketchucation Tools
                      • close and restart Sketchup
                        @chooyod said:
                        Hi Pgarmyn,
                        Thank you.
                        Looks like you have got your v8 PC Plugins folder [and its contents] 'Security Permissions' all messed up...
                        Read this http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
                        This error does not relate directly to this specific Plugin - it also refers to mine.
                        But rather to the fact that things are NOT installed properly - a user issue rather than a specific plugin problem 😒
                        IF you have FULL security permissions setup properly for the Plugins folder and its contents, then ALL Plugins will be installed properly, then read-in and loaded... and then be available for use after SketchUp has loaded...
                        You will also need to reinstall any Plugins that still display errors, as some of their files might be within your Windows VirtualStore, rather where you think they are... A 'Compatibilities Files...' link/button on the top-bars of your Plugins folder's Windows Explorer window is a give away!
                          caronte01
                          Hi pgarmyn
                          As I mentioned before, I´ve got a mac available to test your plugin. Initially, it installed and loaded ok, but most menu items did nothing. I did a small video and saved a log file.
                          Here´s a link:
                          Dropbox - Error - Simplify your life
                          (www.dropbox.com)
                          What should I test specifically?
                            caronte01
                            I´m posting this separately to try and keep this thread organized.
                            Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
                            This is set per scene, not globally.
                            Santiago
                            • KrisidiousK Offline
                              Krisidious
                              Any ideas on my errors? I'm dying to try this out.
                              By: Kristoff Rand
                                caronte01
                                Maybe a FR to turn thumbnails creation from ruby on or off to trimble. Quite annoying, and imo not that useful.
                                  pgarmyn
                                  @caronte01 said:
                                  .....Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
                                  Santiago
                                  Thumbnails : http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=31349#p275878
                                  Can only be switched off for the model, not for one scene.
                                  I hope to send you the next RichSection version for testing this weekend.
                                    pgarmyn
                                    @arcad-uk said:
                                    I was about to check the models TIG worked with and got the same EXPIRED DEMO message.
                                    And others. ......
                                    [highlight=#ffff40:2atg51ts]Sorry. childhood illness
                                    I'll fix that tomorrow. 😒 😳 😳 😳[/highlight:2atg51ts]
                                    • romboutR Offline
                                      rombout
                                      @bimbachi said:
                                      @pgarmyn said:
                                      @davecoopstl said:
                                      pgarmyn -
                                      THERE ARE MANY PROBLEMS WITH MAC
                                      MAC USERS, PLEASE WAIT :
                                      IS THERE SOME MAC-VOLUNTEER TO HELP WITH SOME TESTING ❓
                                      I dont have ruby knowlege, but as user testing , I can give a try.
                                      I'm using skp pro version 8 only with a lot of addons so conflict with other plugs is possibul.
                                      However sketchucation store plug alows to do some limted sets if needed.
                                      I would like to be a volunteer 😄
                                      • romboutR Offline
                                        rombout
                                        @caronte01 said:
                                        Hi pgarmyn
                                        Here´s a link:
                                        (www.dropbox.com)
                                        Is this still available some where
                                          pgarmyn
                                          @rombout said:
                                          As I mentioned before, I´ve got a mac available to test your plugin. .....
                                          I will send you the next pre-release. Probably this weekend.
                                          Thanks.
                                            Phil Rader AIA
                                            If you want a mac tester I'm volunteering.
                                            prader- at - nvizeon - dot - com
                                            http://www.philrader.com
                                            • 11
                                            • 12
                                            • 19
                                            • 20
                                            • 10 / 20
