    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 190.5k Views 85 Watching
      chooyod
      Hi Pgarmyn,
      An error occurred in present version V0.3.1 as shown below. Thus could not find the RichSection tool as well.
      Please make any suggestions.
      Thank you.
        pgarmyn
        @caronte01 said:
        Perfect. It can be solved. So cut, and then paste in place will force a redraw.... Great! Thanks
        Correction : i did Copy + Past in place
        Double geometry will be 'unified' >> geometry will be redefined
          pgarmyn
          @chooyod said:
          Hi Pgarmyn,
          Thank you.
          Please complete your profile : MAC or WINDOWS ?
          MAC : not compatible yet.
          You also have an error on Loading ExtrudeTools.rb >>Permission denied
          ExtrudeTools.rb is not part of my Plugin, i think it is TIG's
          Did you restart Sketchup after the update ?
          I suggest to
          • Un-install the RichSection plugin manually (Sketchucation Tools only renames the loader): go to de plugin directory and delete PiGa_RichSection.rb (or extensions .rb! .rbx) and folder PiGa_RichSection; for older versions :delete RichSection_loader.rb (or extensions .rb! .rbx) and folder RichSection;
          • restart Sketchup
          • Re-instal RichSection using Plugin Store & Sketchucation Tools
          • close and restart Sketchup
            @chooyod said:
            Hi Pgarmyn,
            Thank you.
            Looks like you have got your v8 PC Plugins folder [and its contents] 'Security Permissions' all messed up...
            Read this http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
            This error does not relate directly to this specific Plugin - it also refers to mine.
            But rather to the fact that things are NOT installed properly - a user issue rather than a specific plugin problem 😒
            IF you have FULL security permissions setup properly for the Plugins folder and its contents, then ALL Plugins will be installed properly, then read-in and loaded... and then be available for use after SketchUp has loaded...
            You will also need to reinstall any Plugins that still display errors, as some of their files might be within your Windows VirtualStore, rather where you think they are... A 'Compatibilities Files...' link/button on the top-bars of your Plugins folder's Windows Explorer window is a give away!
              caronte01
              Hi pgarmyn
              As I mentioned before, I´ve got a mac available to test your plugin. Initially, it installed and loaded ok, but most menu items did nothing. I did a small video and saved a log file.
              Here´s a link:
              Dropbox - Error - Simplify your life
              (www.dropbox.com)
              What should I test specifically?
                caronte01
                I´m posting this separately to try and keep this thread organized.
                Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
                This is set per scene, not globally.
                Santiago
                • KrisidiousK Offline
                  Krisidious
                  Any ideas on my errors? I'm dying to try this out.
                  By: Kristoff Rand
                    caronte01
                    Maybe a FR to turn thumbnails creation from ruby on or off to trimble. Quite annoying, and imo not that useful.
                      pgarmyn
                      @caronte01 said:
                      .....Can you set via ruby scenes to not generate scene thumbnails? Currently, all scenes created with rs have this set to yes. It is not to useful, and slows down scene creation/editing in large models.
                      Santiago
                      Thumbnails : http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=31349#p275878
                      Can only be switched off for the model, not for one scene.
                      I hope to send you the next RichSection version for testing this weekend.
                        pgarmyn
                        @arcad-uk said:
                        I was about to check the models TIG worked with and got the same EXPIRED DEMO message.
                        And others. ......
                        [highlight=#ffff40:2atg51ts]Sorry. childhood illness
                        I'll fix that tomorrow. 😒 😳 😳 😳[/highlight:2atg51ts]
                        • romboutR Offline
                          rombout
                          @bimbachi said:
                          @pgarmyn said:
                          @davecoopstl said:
                          pgarmyn -
                          THERE ARE MANY PROBLEMS WITH MAC
                          MAC USERS, PLEASE WAIT :
                          IS THERE SOME MAC-VOLUNTEER TO HELP WITH SOME TESTING ❓
                          I dont have ruby knowlege, but as user testing , I can give a try.
                          I'm using skp pro version 8 only with a lot of addons so conflict with other plugs is possibul.
                          However sketchucation store plug alows to do some limted sets if needed.
                          I would like to be a volunteer 😄
                          • romboutR Offline
                            rombout
                            @caronte01 said:
                            Hi pgarmyn
                            Here´s a link:
                            (www.dropbox.com)
                            Is this still available some where
                              pgarmyn
                              @rombout said:
                              As I mentioned before, I´ve got a mac available to test your plugin. .....
                              I will send you the next pre-release. Probably this weekend.
                              Thanks.
                                Phil Rader AIA
                                If you want a mac tester I'm volunteering.
                                prader- at - nvizeon - dot - com
                                http://www.philrader.com
                                  bimbachi
                                  after instal / load errors:
                                  Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader.rb
                                  private method gsub' called for nil:NilClassError Loading File PiGa_RichSection.rb private method gsub' called for nil:NilClass
                                  and ruby console :
                                  RS: START DEBUG
                                  RS0.4.1|2.479|
                                  Start Logfile____ __________________________________________
                                  /var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T//RichSection_log.txt
                                  RS0.4.1|0.154|
                                  RichSection plugin __________________________________________
                                  #<SketchupExtension:0xecfc6d8
                                  @name="RichSection",
                                  @registered=true,
                                  @version="V0.4.1-RC-2014.04.20-20:30 DEMO",
                                  @loaded=false,
                                  @path="/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RSloader",
                                  @copyright=" 2013, All rights reserved for RichSection plugin : Name, code and functionality are the intellectual property of the author. Distribution, reproduction or integration of code or functionality, even partly, is only permitted with the explicit permission of the author",
                                  @description="Creats 'SECTION materials' based on 'layer' or 'nature' of groups and components (if section is a closed polygone). PROJECTs elements above the sectionplane as pointed lines. SECTION and PROJECTION are placed in a 'RichSection' group, respecting the same (nested) structure as the model. Switching layers 'on' and 'off' will swich the corresponding 'RichSection' information.",
                                  @load_on_start=false,
                                  @creator="Piet Garmyn, Luxembourg (pgarmyn)">
                                  RS0.4.1|0.004|
                                  User info____________________________________________________
                                  {"PATH"=>"/usr/bin:/bin:/usr/sbin:/sbin",
                                  "GOOGLE_GILD_RUNTIME_FRAMEWORK_ABSOLUTE_PATH"=>"/Library/Google/Frameworks/Gild.framework",
                                  "TMPDIR"=>"/var/folders/vp/czvv48md4dz_zv8rgyxm_0h40000gp/T/",
                                  "SHELL"=>"/bin/bash",
                                  "HOME"=>"/Users/tignaciuk",
                                  "USER"=>"tignaciuk",
                                  "LOGNAME"=>"tignaciuk",
                                  "SSH_AUTH_SOCK"=>"/tmp/launch-AjI9WA/Listeners",
                                  "Apple_PubSub_Socket_Render"=>"/tmp/launch-qOUkYE/Render",
                                  "DISPLAY"=>"/tmp/launch-hvrCBq/org.macosforge.xquartz:0",
                                  "COM_GOOGLE_CHROME_FRAMEWORK_SERVICE_PROCESS/USERS/TIGNACIUK/LIBRARY/APPLICATION_SUPPORT/GOOGLE/CHROME_SOCKET"=>"/tmp/launch-Qsk4v0/ServiceProcessSocket",
                                  "__CF_USER_TEXT_ENCODING"=>"0x1F6:29:42",
                                  "__CHECKFIX1436934"=>"1",
                                  "IG_ROOT"=>"/Applications/Google SketchUp 8/SketchUp.app/Contents/Resources"}
                                  RS0.4.1|0.040|PiGaRSection.start_debug :
                                  RS0.4.1|0.008|Logging to RubyPanel : true
                                  RS0.4.1|0.006|Logging to File : true
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:27: warning: don't put space before argument parentheses
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/repair_broken_lines.rb:42: warning: don't put space before argument parentheses
                                  (eval):2837: warning: parenthesize argument(s) for future version
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:16: warning: already initialized constant VERSION_PATTERN
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:23: warning: already initialized constant THEME_DEFAULT
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:24: warning: already initialized constant THEME_GRAPHITE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:31: warning: already initialized constant EVENT_WINDOW_READY
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:43: warning: already initialized constant EVENT_CALLBACK
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:70: warning: already initialized constant EVENT_OPEN_URL
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
                                  (eval):344: warning: don't put space before argument parentheses
                                  (eval):444: warning: don't put space before argument parentheses
                                  (eval):666: warning: don't put space before argument parentheses
                                  (eval):1221: warning: don't put space before argument parentheses
                                  (eval):1403: warning: don't put space before argument parentheses
                                  (eval):1627: warning: don't put space before argument parentheses
                                  (eval):2702: warning: don't put space before argument parentheses
                                  (eval):2703: warning: don't put space before argument parentheses
                                  (eval):2824: warning: don't put space before argument parentheses
                                  (eval):2845: warning: don't put space before argument parentheses
                                  (eval):935: warning: don't put space before argument parentheses
                                  (eval):936: warning: don't put space before argument parentheses
                                  (eval):939: warning: don't put space before argument parentheses
                                  (eval):943: warning: don't put space before argument parentheses
                                  (eval):1520: warning: don't put space before argument parentheses
                                  (eval):2496: warning: don't put space before argument parentheses
                                  (eval):2498: warning: don't put space before argument parentheses
                                  (eval):2531: warning: don't put space before argument parentheses
                                  (eval):2533: warning: don't put space before argument parentheses
                                  (eval):2973: warning: don't put space before argument parentheses
                                  (eval):2983: warning: don't put space before argument parentheses
                                  (eval):2994: warning: don't put space before argument parentheses
                                  (eval):3004: warning: don't put space before argument parentheses
                                  (eval):3102: warning: don't put space before argument parentheses
                                  (eval):3129: warning: don't put space before argument parentheses
                                  (eval):3138: warning: don't put space before argument parentheses
                                  (eval):3143: warning: don't put space before argument parentheses
                                  (eval):3220: warning: don't put space before argument parentheses
                                  (eval):3223: warning: don't put space before argument parentheses
                                  (eval):3226: warning: don't put space before argument parentheses
                                  (eval):3268: warning: don't put space before argument parentheses
                                  (eval):3269: warning: don't put space before argument parentheses
                                  (eval):3324: warning: don't put space before argument parentheses
                                  (eval):3325: warning: don't put space before argument parentheses
                                  (eval):3506: warning: don't put space before argument parentheses
                                  (eval):4556: warning: don't put space before argument parentheses
                                  (eval):4635: warning: don't put space before argument parentheses
                                  (eval):4997: warning: don't put space before argument parentheses
                                  (eval):5052: warning: don't put space before argument parentheses
                                  (eval):5096: warning: don't put space before argument parentheses
                                  (eval):5100: warning: don't put space before argument parentheses
                                  (eval):9026: warning: don't put space before argument parentheses
                                  (eval):9026: warning: parenthesize argument(s) for future version
                                  (eval):191: warning: don't put space before argument parentheses
                                  (eval):291: warning: don't put space before argument parentheses
                                  (eval):758: warning: don't put space before argument parentheses
                                  (eval):906: warning: don't put space before argument parentheses
                                  (eval):692: warning: don't put space before argument parentheses
                                  (eval):699: warning: don't put space before argument parentheses
                                  (eval):719: warning: don't put space before argument parentheses
                                  (eval):739: warning: don't put space before argument parentheses
                                  (eval):746: warning: don't put space before argument parentheses
                                  (eval):766: warning: don't put space before argument parentheses
                                  (eval):786: warning: don't put space before argument parentheses
                                  7
                                  (eval):3119: warning: parenthesize argument(s) for future version
                                  (eval):3142: warning: parenthesize argument(s) for future version
                                  key = Units
                                  value = 0.0
                                  and log files attached
                                  cheers
                                  RichSection_log.txt
                                  RichSection_log_140421-201054.txt
                                  RichSection_log_140421-200134.txt
                                    pgarmyn
                                    Thanks Bimbachi
                                    I'll work on it.
                                    Please, for readability,, don't copy the whole log in this post.
                                      Phil Rader AIA
                                      Got it loaded on my mac I'll kick the tires on it later. Thanks for the Mac version
                                        pgarmyn
                                        Sorry, its not working yet on Mac.
                                          pgarmyn
                                          Hi all
                                          This version is for testing, and feedback please.
                                          • on mac
                                          • for those on Windows having problems to run this plugin
                                          This test version has logging switched on by default.
                                          A log-file is created, and can be opened.
                                          • Open the file (and save as) : Menu/Plugins/RichSection/Open logfile....
                                          • Copy the file. The file location is shown at startup (panel opening)and in the Ruby panel.
                                          Logging can be switched off in Menu/Plugins/RichSection/Settings.
                                          Please send the complete log file (RichSection_log.txt), not just the last lines.
                                          Thanks.
                                          %(#FF0000)[file deleted, not woking yet on
                                          april 24, 2014]
                                            Krisidious
                                            I just couldn't believe that only I was having this problem and pgarmyn was not able to fix the issue. I removed all my plugins one more time and now the plugin works. I'll have to add the old ones back until I find the culprit of the conflict.
                                            By: Kristoff Rand
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
