    Fishing net modeling
    131 Posts 12 Posters 13.5k Views 12 Watching
    • BoxB Offline
      Is this anything like what you want?
      • W Offline
        willipop
        Wow it's very nice ๐Ÿ˜„ It's close to what I have in mind. I'd love the net more dense. Could you show me how you did that and I will try myself !? How did you did the rendering ? very cool !
        • W Offline
          willipop
          I think I will have to go with something similar you did ( I mean more space between each squares of the mesh )
          • W Offline
            willipop
            woaa this plugin is amazing ! you rock ๐Ÿ˜„
            • BoxB Offline
              You can go denser, that whole file is only 6mg and doesn't lag at all with shadows.
              I used another plugin called Wire tool to link the construction points with a nice droop. Then just did as I did in the video. for each section.
              I only used 12 segments for the curves, so that makes it quite wide, you can use more to get a finer mesh. http://sketchucation.com/pluginstore?pln=ae_WireTool
              You may want to use the main wires as thicker support cables, then make the mesh between.
              But it's up to you how you want it to look.
              The trick though is to make it using copies as much as possible. Make one end and flip the components to work on the other end etc
              The render is just a basic preset render from twilight. And as you can see in this one when I flipped it it didn't fit because you structure isn't symmetrical, hence the gap in the middle.
              A finer mesh with some thick cables
              • W Offline
                willipop
                This plugin makes it looks really nice !
                Is there another plugin that I could use to fix some summit and use some other summit that I could move.(just like artisan works with the crease tool.) vertex tool ?
                • olisheaO Offline
                  olishea
                  gets better and better! I forgot about the wire tool, it's a classic!
                  oli
                    Perfect for some hammock! โ˜€
                    Au fait j'ai fait la version francophone d'Artisan! ๐Ÿ˜‰
                    http://www.endalldisease.com/wp-content/uploads/2013/09/hammock.jpg
                    Normally Su make that in native ? ๐Ÿ˜„
                    Sรฉlection verrouillรฉe ou non ?
                    • W Offline
                      willipop
                      ahaha ๐Ÿ˜„ I wish I could lay down in a hammac ! Mon pays c'est l'hiver ! ๐Ÿ˜•
                      Gรฉnial Pilou ! Tu sais s'il existe un outil similaire ร  l'outil ''cease d'artisan'' comme sur la photo dont je viens de poster? ๐Ÿ˜„
                      • W Offline
                        willipop
                        Here's what I mean. See the physic is nice when one line is moved, but it moves at the end (bottom left) too... I'd like to be able to simulate where is the net goes when it drop !
                        test1.mov
                        • W Offline
                          willipop
                          I'm stupid ^^ ๐ŸŽ‰
                          humhum1.mov
                            That i have said! That was yet in Su native! ๐Ÿ’š
                            About another crease I don't see one for the moment like that
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/494823496.png
                            I don't see that in VertexTool's manual by Thomthom in French! ๐Ÿ˜‰
                            That you can make is use the inverse selection by TIG Freeze and apply that you want on a wished selection?
                            • W Offline
                              willipop
                              I'm still up ! hรฉhรฉ ๐Ÿ˜‰
                              • olisheaO Offline
                                olishea
                                I take it you're working to a deadline! ๐Ÿ˜†
                                oli
                                • BoxB Offline
                                  There might be a deadline involved, but I suspect there are the glassy eyes of sketchup addiction twitching away through the night.
                                  • W Offline
                                    willipop
                                    Here's what i did the past few days ๐Ÿ˜„ 2 scenario because its an interactive net that goes up and down as the tide interact.
                                    Draw wire and EByR plugins were very helpful ๐Ÿ˜„
                                    This file is about 7megs.
                                    I did use the line to cylinder it's working great but I took me several hour as I did each group of net one by one. The file is like 140meg ๐Ÿ˜•
                                    I did some test with kerkythea for the rendering it crashed many times, the model is too complex ๐Ÿ˜• I'm not sure how to proceed for the next phase.
                                    My deadline is in 10days ahah ! ๐Ÿ˜„
                                    lower net
                                    higher net
                                    solid net, huge file ! :(
                                    • BoxB Offline
                                      Did you make every piece different?
                                      Can you not work it so you are using repeating components?
                                      How many faces did you use on the tubes, any more than 3 is probably wasted.
                                      • W Offline
                                        willipop
                                        everything is different ๐Ÿ˜•
                                        • BoxB Offline
                                          If you are doing it for accurate technical construction drawing I can understand that, but if it's for rendering then make it from repeat sections.
                                          • W Offline
                                            willipop
                                            here's a link for the sketchup file : I really like the way the net is shaped ๐Ÿ˜„
                                            (we.tl)
                                            • 3 / 7
