    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 39.4k Views 21 Watching
      @the.pjt
      Can you respond to the PM I sent regards this in-post plugin uploading?
      • sdmitchS Offline
        sdmitch
        @jorge2011 said:
        does not work, create the geometry inside a group. Or create a group inside another group
        The change the.pjt made will only add the current box to a group if you have the group open for edit it does not open the group automatically. It should have no effect on whether or not the current box is created as a group or not. That will still depend on grouping being On or Off.
        http://sdmitch.blogspot.com/
          jorge2011
          sdmitch, sorry, I do not understand your explanation. my English is not good.
          You can create a group inside another group, or a grometria within a group or component?
          You can add this feature?
          thank you very much for your kindness and your time
          • TIGT Online
            If I might interject. πŸ€“
            All native and most 3rd-party tools add new geometry etc into the "current context" [ model.active_entities] - even if the added 'object' itself is a group of new geometry.
            To always force new stuff into model.entities as its context will be very confusing, unless the two entities' contexts are not the sample.
            So if you are editing a component or a group and you use this tool to add a 'box' then the newly made object will currently then be added outside of the current context... which is not what you'd expect at all - e.g. if you draw a 'line' it's added inside the context, not outside in the model.entities πŸ˜’
            It IS a very simple adjustment to the code to make these tools intuitive in the way it adds its geometry like the native tools...
            πŸ€“
            • sdmitchS Offline
              sdmitch
              For all of you who have been anxiously awaiting the change of mod.entities to mod.active_entities, your wait is over and Version 1.2.1 is for you.
              • brookefoxB Offline
                brookefox
                I'm all over it. Thank you, Sam.
                ~ Brooke
                • sdmitchS Offline
                  sdmitch
                  Updated to be SU2014 compatible.
                  • TIGT Online
                    I have added it to the PluginStore.
                    http://sketchucation.com/pluginstore?pln=Rotated_Box
                      dedmin
                      See the video.
                      Video_2014-03-29_033416.wmv
                      • sdmitchS Offline
                        sdmitch
                        Very interesting. I'll try to solve the mystery.
                          Jim
                          Just something I noted from the video - implement the Tool#getExtents method to fix the clipping of your temporary geometry.
                          • Bob JamesB Offline
                            Bob James
                            @the.pjt
                            3Pts_Tools is a great tool set (yours and Sam's) and the toolbar.
                            Comments:
                            1. Works fine in SU13, but the cylinder creation is somewhat counter-intuitive: In the Box Tool the base is created first, then the height. In the Cylinder Tool it is the opposite: the height is created first, then the radius. Not a deal-breaker, but it would be better (IMO) if they were both in the same order; base, then height.
                            2. In SU13 it works whether in the 'standard' plugin folder or in an 'additional' folder. In SU14 it does not load successfully in either location: I get load errors in either folder.
                            • sdmitchS Offline
                              sdmitch
                              In the case of the cylinder, the definition of the height also defines the normal for the cylinder. If you were only doing cylinders oriented along one of the axes, then you could just as easily do it the other way.
                              I think I have found and fixed the bug in Rotated Box that caused the box to be displaced when dimensions were keyed in.
                                dedmin
                                Can the default be NOT to add to a group? It is very frustrating!
                                • sdmitchS Offline
                                  sdmitch
                                  Yes of course. Using Notepad, change the line "@group_box = true" to "@group_box = false".
                                    dedmin
                                    β˜€ πŸ‘
                                      dedmin
                                      Love this - using it all day long to build furniture from ply and sheet goods!
                                      One wish - to draw the height of the box from the center, not just up or down.
                                      Thanks.
                                      • sdmitchS Offline
                                        sdmitch
                                        Thanks.
                                        Do you mean the height value entered would be half the desired height? Would this always be the case?
                                          dedmin
                                          Thanks.
                                          I mean - the value entered would be the desired one, just drawn in half up and down.
                                          • sdmitchS Offline
                                            sdmitch
                                            @dedmin said:
                                            Thanks.
                                            I'm sorry but that makes no sense.
                                            • 3 / 4
