    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 36.7k Views 21 Watching
      the.pjt
      @jorge2011 said:
      the.pjt or sdmitch.
      This change does not work in my pc. I use sketchup 8 and windows xp sp3.
      You can correct this error? really very useful tool
      maybe becouse of I'm not a programmer ,I am just a newbie ... It works well on my ms win 8 ,SU 8 M3 .... I don't have any apple device .. 😞 ... so maybe it doesn't work on mac , I don't know
      and ... It could be better if the author have modified it , not me ... I think he dislikes me πŸ˜„ ..
      dear ThomThom .. Or MR sdmitch .... is it posible to check my editings ? ? I will welcome ...
      thanks a lot ... πŸ˜‰
      all of thing that I have done is : just changing line 32 (notepad++)
      old :
      class RotatedBox
      def initialize
      @mod = Sketchup.active_model
      @ent = @mod.entities
      new
      class RotatedBox
      def initialize
      @ent = @mod.active_entities
      and then it creates every thing in active group ... am I wrong ?
        @the.pjt
        Can you respond to the PM I sent regards this in-post plugin uploading?
          sdmitch
          @jorge2011 said:
          does not work, create the geometry inside a group. Or create a group inside another group
          The change the.pjt made will only add the current box to a group if you have the group open for edit it does not open the group automatically. It should have no effect on whether or not the current box is created as a group or not. That will still depend on grouping being On or Off.
          http://sdmitch.blogspot.com/
            jorge2011
            sdmitch, sorry, I do not understand your explanation. my English is not good.
            You can create a group inside another group, or a grometria within a group or component?
            You can add this feature?
            thank you very much for your kindness and your time
              If I might interject. πŸ€“
              All native and most 3rd-party tools add new geometry etc into the "current context" [ model.active_entities] - even if the added 'object' itself is a group of new geometry.
              To always force new stuff into model.entities as its context will be very confusing, unless the two entities' contexts are not the sample.
              So if you are editing a component or a group and you use this tool to add a 'box' then the newly made object will currently then be added outside of the current context... which is not what you'd expect at all - e.g. if you draw a 'line' it's added inside the context, not outside in the model.entities πŸ˜’
              It IS a very simple adjustment to the code to make these tools intuitive in the way it adds its geometry like the native tools...
              πŸ€“
                sdmitch
                For all of you who have been anxiously awaiting the change of mod.entities to mod.active_entities, your wait is over and Version 1.2.1 is for you.
                  brookefox
                  I'm all over it. Thank you, Sam.
                  ~ Brooke
                    sdmitch
                    Updated to be SU2014 compatible.
                      I have added it to the PluginStore.
                      http://sketchucation.com/pluginstore?pln=Rotated_Box
                        dedmin
                        See the video.
                        Video_2014-03-29_033416.wmv
                          sdmitch
                          Very interesting. I'll try to solve the mystery.
                            Jim
                            Just something I noted from the video - implement the Tool#getExtents method to fix the clipping of your temporary geometry.
                              Bob James
                              @the.pjt
                              3Pts_Tools is a great tool set (yours and Sam's) and the toolbar.
                              Comments:
                              1. Works fine in SU13, but the cylinder creation is somewhat counter-intuitive: In the Box Tool the base is created first, then the height. In the Cylinder Tool it is the opposite: the height is created first, then the radius. Not a deal-breaker, but it would be better (IMO) if they were both in the same order; base, then height.
                              2. In SU13 it works whether in the 'standard' plugin folder or in an 'additional' folder. In SU14 it does not load successfully in either location: I get load errors in either folder.
                                sdmitch
                                In the case of the cylinder, the definition of the height also defines the normal for the cylinder. If you were only doing cylinders oriented along one of the axes, then you could just as easily do it the other way.
                                I think I have found and fixed the bug in Rotated Box that caused the box to be displaced when dimensions were keyed in.
                                  dedmin
                                  Can the default be NOT to add to a group? It is very frustrating!
                                    sdmitch
                                    Yes of course. Using Notepad, change the line "@group_box = true" to "@group_box = false".
                                      dedmin
                                      β˜€ πŸ‘
                                        dedmin
                                        Love this - using it all day long to build furniture from ply and sheet goods!
                                        One wish - to draw the height of the box from the center, not just up or down.
                                        Thanks.
                                          sdmitch
                                          Thanks.
                                          Do you mean the height value entered would be half the desired height? Would this always be the case?
                                            dedmin
                                            Thanks.
                                            I mean - the value entered would be the desired one, just drawn in half up and down.
                                            • 3 / 4
