    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 40.4k Views 21 Watching
      dedmin
      See the video.
      Video_2014-03-29_033416.wmv
      • sdmitchS
        sdmitch
        Very interesting. I'll try to solve the mystery.
        http://sdmitch.blogspot.com/
          Jim
          Just something I noted from the video - implement the Tool#getExtents method to fix the clipping of your temporary geometry.
          • Bob JamesB
            Bob James
            @the.pjt
            3Pts_Tools is a great tool set (yours and Sam's) and the toolbar.
            Comments:
            1. Works fine in SU13, but the cylinder creation is somewhat counter-intuitive: In the Box Tool the base is created first, then the height. In the Cylinder Tool it is the opposite: the height is created first, then the radius. Not a deal-breaker, but it would be better (IMO) if they were both in the same order; base, then height.
            2. In SU13 it works whether in the 'standard' plugin folder or in an 'additional' folder. In SU14 it does not load successfully in either location: I get load errors in either folder.
            • sdmitchS
              sdmitch
              In the case of the cylinder, the definition of the height also defines the normal for the cylinder. If you were only doing cylinders oriented along one of the axes, then you could just as easily do it the other way.
              I think I have found and fixed the bug in Rotated Box that caused the box to be displaced when dimensions were keyed in.
                dedmin
                Can the default be NOT to add to a group? It is very frustrating!
                • sdmitchS
                  sdmitch
                  Yes of course. Using Notepad, change the line "@group_box = true" to "@group_box = false".
                    dedmin
                    β˜€ πŸ‘
                      dedmin
                      Love this - using it all day long to build furniture from ply and sheet goods!
                      One wish - to draw the height of the box from the center, not just up or down.
                      Thanks.
                      • sdmitchS
                        sdmitch
                        Thanks.
                        Do you mean the height value entered would be half the desired height? Would this always be the case?
                          dedmin
                          Thanks.
                          I mean - the value entered would be the desired one, just drawn in half up and down.
                          • sdmitchS
                            sdmitch
                            @dedmin said:
                            Thanks.
                            I'm sorry but that makes no sense.
                              dedmin
                              For instance - to draw a shelf centered on the side. This is Rhino:
                              • sdmitchS
                                sdmitch
                                [attachment=0:u6oxrafv]<!-- ia0 -->selection_toys.gif<!-- ia0 -->[/attachment:u6oxrafv]
                                Thanks for the graphic. At least it makes sense now.
                                I have sent you, by Personal Message, a modified copy that I think does what you want.
                                • designerbursaD
                                  designerbursa
                                  Toolbar 😎 rotated box plugin πŸ˜‰
                                  Rotated_Box.zip
                                  • 4 / 4
