    Sketchup 14 mac crashing like never before
    56 Posts 11 Posters 13.9k Views 11 Watching
      slbaumgartner
      I don't have a solution, but a few observations:
      • the lack of the BugSplat window on Mac has been reported by several people. So far as I know, nobody has figured out why, though I believe Trimble has contacted the BugSplat developers to see if they can diagnose it.
      • the popup to report to Apple rather than BugSplat means the error appeared to be in an OS X library rather than in SU code per-se. That could still be SU's fault for provoking the error, but it was detected in the library.
      • Inability to quit means the app is not responding to events. As someone else noted, sometimes this means there is a modal dialog hidden behind some other window. It could also mean that a plugin is hung up. Observers are notorious for problems of this sort. Have you tried with all plugins disabled?
      Steve
      • W Offline
        whitelock
        I will try disabling all plugins soon, at the moment I need them for the job I am on. Will report back if no change.
        • W Offline
          whitelock
          @ Driven
          here is the list you asked for
          puts Sketchup.find_support_file("Plugins")
          (Sketchup.find_support_files("","Plugins")).each{|f| puts File.basename(f)}
          nil
          /Users/lukewhitelock/Library/Application Support/SketchUp 2014/SketchUp/Plugins
          BZ_Dir_16
          clf_arc_centerpoint_finder
          cmd_select_n_isolate
          Fredo6_!LibFredo6
          Fredo6_JointPushPull
          Fredo6_RoundCorner
          Hatchfaces
          SectionCutFace
          SketchUcation
          smustard_Weld
          su_advancedcameratools
          su_dynamiccomponents
          su_sandbox
          su_webtextures
          tt_cleanup
          TT_Lib2
          tt_solid_inspector
          ~Superseded
          SU_Podium_V2
          nil
            driven
            @Luke,
            need more info to try and help...
            a list of plugins may help...
            in 'Ruby Console' can you copy/paste then enter/return this enquiry
            Dir.foreach(Sketchup.find_support_file("Plugins"))do
            |f|
            puts f
            copy/paste result into a reply...
            the other things are the usual suspects...
            Autosave frequency...
            Outliner window ON/OFF
            Components window ON/OFF
            Do you run as an Root Account? or admin user
            I'll think of more...
            EDIT: updated the snippet to be more informative
              driven
              hi Luke
              I tweaked the snippet to give more info, can you try it again...
              • W Offline
                whitelock
                Hi Driven,
                Here is the new code
                |f|
                puts f
                !SketchUcation_loader.rb
                bezierspline.rb
                BZ_Dir_16
                clf_arc_centerpoint_finder.rb
                cmd_select_n_isolate.rb
                Fredo6_!LibFredo6
                Fredo6_!LibFredo6.rb
                Fredo6_JointPushPull.rb
                Fredo6_RoundCorner
                Fredo6_RoundCorner.rb
                Hatchfaces
                Hatchfaces.rb
                LibTraductor.rb
                SectionCutFace
                SectionCutFace.rb
                SketchUcation
                smustard_Weld
                smustard_Weld.rb
                su_advancedcameratools.rb
                su_dynamiccomponents.rb
                su_sandbox
                su_sandbox.rb
                su_webtextures
                su_webtextures.rb
                TIG-solidsolver.rb
                tt_cleanup
                tt_cleanup.rb
                TT_Lib2
                TT_Lib2.rb
                tt_solid_inspector
                tt_solid_inspector.rb
                ~Superseded
                nil
                thanks for this by the way.
                • jeff hammondJ Offline
                  @whitelock said:
                  when I re open sketch up it opens all the crashed files.
                  (this is borderline off-topic but..)
                  that's a system preference which causes all those files to open upon a relaunch/restart.. it has it's benefits for sure but when you're dealing with crashing apps etc, it sucks..
                  System Preferences-> General
                  tick the box 'Close windows when quitting an application'
                  • W Offline
                    whitelock
                    Hi Jeff,
                    Thats what I thought also, I had the same problem on my macbook. I changed the settings in system preferences but it seems that sketch up is the only program that doesn't adhere to these settings. Since I got my iMac about two weeks ago, I have had the same problem. The system preferences box (close windows when quitting an application) is ticked - see screen shot below. But again it does not appear to work when using sketch up - This has only happened since upgrading to 2014, On both machines this happens.
                      hmm.. that's strange.. I guess I haven't yet run into a scenario of 2014 crashing with multiple windows open.. I'll try to force crash it with multiple windows open tonight to see what I find.
                      in the meantime, have you tried running SU without section cut face installed? if so, does stability improve?
                        A new version of SectionCutFace was released recently to try an fix some unexpected Observer issues on MACs etc...
                        Get the latest version and see if that helps...
                        If a know "deficiency" of v2014 MR0 πŸ˜’
                        • 3 / 3
