    Sketchup 14 mac crashing like never before
    56 Posts 11 Posters 14.8k Views 11 Watching
    • O
      otb designworks
      Hi Luke, sorry to hear about your difficulties; I know how frustrating they can be.
      Have you tried running SU without any plugins installed? If not, then I would try that first.
      Not sure what is going on with the lack of a SU bug report; you probably are not getting the SU bugsplat window because you are having to force quit as opposed to having SU just crash. I am pretty sure that SU does not get the apple bug reports.
      Cheers, Chuck
      OTB Designworks is on Youtube
      • O
        otb designworks
        On not being able to quit SU, is it possible that SU is giving you the dialogue for "do you want to save before quitting" and that this window is somehow hidden behind another window? SU won't quit until you choose to either save or not. This is especially maddening because SU always opens a new window when you start and that can be easily hidden behind your actual working files and then you have to choose to not save before SU will quit.
        Next time you try to quit and it stalls, use mission control to show all windows and see if there is that hidden dialogue window. Just a thought...
        Cheers, Chuck
        • W
          whitelock
          Here are some screen shots of what I get
          A) SHOWING HOW SKETCHUP DOES NOT RESPOND TO SHUT DOWN
          B) THE GREY BOX I GET, I GET THIS BOX ON CRASHING AND FORCE QUIT, SINCE UPGRADING I DONT SEE THE OLD BUGSPLAT REPORTER OF OLD.
          just looked up and realised its all in capitals, I'm not shouting just can't be bothered to type it all out again.
          Luke
          • O
            otb designworks
            There is a difference between crashing and force quitting. I think that is maybe why you aren't seeing the SU bugsplat reporter? I would expect the SU bugsplat dialogue only when SU crashes by it's self?
            I feel like I have seen just what you are experiencing with having to force quit and it was, for me, because I didn't see the save dialogue window and SU seemed to just stall out and beach ball.
            Cheers, Chuck
              slbaumgartner
              I don't have a solution, but a few observations:
              • the lack of the BugSplat window on Mac has been reported by several people. So far as I know, nobody has figured out why, though I believe Trimble has contacted the BugSplat developers to see if they can diagnose it.
              • the popup to report to Apple rather than BugSplat means the error appeared to be in an OS X library rather than in SU code per-se. That could still be SU's fault for provoking the error, but it was detected in the library.
              • Inability to quit means the app is not responding to events. As someone else noted, sometimes this means there is a modal dialog hidden behind some other window. It could also mean that a plugin is hung up. Observers are notorious for problems of this sort. Have you tried with all plugins disabled?
              Steve
              • W
                whitelock
                I will try disabling all plugins soon, at the moment I need them for the job I am on. Will report back if no change.
                • W
                  whitelock
                  @ Driven
                  here is the list you asked for
                  puts Sketchup.find_support_file("Plugins")
                  (Sketchup.find_support_files("","Plugins")).each{|f| puts File.basename(f)}
                  nil
                  /Users/lukewhitelock/Library/Application Support/SketchUp 2014/SketchUp/Plugins
                  BZ_Dir_16
                  clf_arc_centerpoint_finder
                  cmd_select_n_isolate
                  Fredo6_!LibFredo6
                  Fredo6_JointPushPull
                  Fredo6_RoundCorner
                  Hatchfaces
                  SectionCutFace
                  SketchUcation
                  smustard_Weld
                  su_advancedcameratools
                  su_dynamiccomponents
                  su_sandbox
                  su_webtextures
                  tt_cleanup
                  TT_Lib2
                  tt_solid_inspector
                  ~Superseded
                  SU_Podium_V2
                  nil
                    driven
                    @Luke,
                    need more info to try and help...
                    a list of plugins may help...
                    in 'Ruby Console' can you copy/paste then enter/return this enquiry
                    Dir.foreach(Sketchup.find_support_file("Plugins"))do
                    |f|
                    puts f
                    copy/paste result into a reply...
                    the other things are the usual suspects...
                    Autosave frequency...
                    Outliner window ON/OFF
                    Components window ON/OFF
                    Do you run as an Root Account? or admin user
                    I'll think of more...
                    EDIT: updated the snippet to be more informative
                      driven
                      hi Luke
                      I tweaked the snippet to give more info, can you try it again...
                      • W
                        whitelock
                        Hi Driven,
                        Here is the new code
                        |f|
                        puts f
                        !SketchUcation_loader.rb
                        bezierspline.rb
                        BZ_Dir_16
                        clf_arc_centerpoint_finder.rb
                        cmd_select_n_isolate.rb
                        Fredo6_!LibFredo6
                        Fredo6_!LibFredo6.rb
                        Fredo6_JointPushPull.rb
                        Fredo6_RoundCorner
                        Fredo6_RoundCorner.rb
                        Hatchfaces
                        Hatchfaces.rb
                        LibTraductor.rb
                        SectionCutFace
                        SectionCutFace.rb
                        SketchUcation
                        smustard_Weld
                        smustard_Weld.rb
                        su_advancedcameratools.rb
                        su_dynamiccomponents.rb
                        su_sandbox
                        su_sandbox.rb
                        su_webtextures
                        su_webtextures.rb
                        TIG-solidsolver.rb
                        tt_cleanup
                        tt_cleanup.rb
                        TT_Lib2
                        TT_Lib2.rb
                        tt_solid_inspector
                        tt_solid_inspector.rb
                        ~Superseded
                        nil
                        thanks for this by the way.
                        • jeff hammondJ
                          @whitelock said:
                          when I re open sketch up it opens all the crashed files.
                          (this is borderline off-topic but..)
                          that's a system preference which causes all those files to open upon a relaunch/restart.. it has it's benefits for sure but when you're dealing with crashing apps etc, it sucks..
                          System Preferences-> General
                          tick the box 'Close windows when quitting an application'
                          • W
                            whitelock
                            Hi Jeff,
                            Thats what I thought also, I had the same problem on my macbook. I changed the settings in system preferences but it seems that sketch up is the only program that doesn't adhere to these settings. Since I got my iMac about two weeks ago, I have had the same problem. The system preferences box (close windows when quitting an application) is ticked - see screen shot below. But again it does not appear to work when using sketch up - This has only happened since upgrading to 2014, On both machines this happens.
                            • jeff hammondJ
                              hmm.. that's strange.. I guess I haven't yet run into a scenario of 2014 crashing with multiple windows open.. I'll try to force crash it with multiple windows open tonight to see what I find.
                              in the meantime, have you tried running SU without section cut face installed? if so, does stability improve?
                                A new version of SectionCutFace was released recently to try an fix some unexpected Observer issues on MACs etc...
                                Get the latest version and see if that helps...
                                If a know "deficiency" of v2014 MR0 πŸ˜’
                                • 3 / 3
