    Improve watertightness in modelling
    16 Posts 6 Posters 2.8k Views 6 Watching
    • olisheaO Offline
      olishea
      Can you post an image or example sketchup file?
      oli
        Stefmanovic
        Sure.
        I've been working on a spaceship model for 3d printing. And I've been unable to make some shapes by just push/pull, so I used the line (pencil thingie) to put these shapes together (especially in the front).
        The model in the attachment is still very much a work in progress, so don't judge on that yet. But I did however wanted to see how printable it would be (wall thickness and all that). So I converted it to an .stl file and then used Netfabb's cloud service to fix the watertightness, but what I get back is a model with lots of parts missing and giant chunks taken out of it.
        Thing is that apparently the model isn't watertight since I didn't do all my shapes using push/pull, which is rather frustrating. Would be nice if all enclosed shapes you make, be it through push/pull or just put together with lines, would automatically be watertight.
        sample.skp
        • BoxB Offline
          You are working very small and that can cause all sorts of problem. One of which is faces not forming properly and you are probably seeing clipping, problems with things disappearing when you zoom in.
          Life would be easier if you worked larger and scaled down when you need to print.
          But the main thing is you need to understand how something becomes 'watertight'. In other words you need to understand how to work with solids, which is what a watertight thing is.
          You can't just throw a whole bunch of shapes together and expect them to be solid. That can work in a drawing but proper modelling is really about making geometry that works in the real world.
          @tig said:
          The simple definition of a manifold solid - one that will successfully 3d-print when exported to a compatible file format - is a collection of 'geometry', consisting of just faces and the edges bounding those faces [within a group or a component 'container'].
          Every edge must bound exactly two faces - no fewer and no more.
          So that precludes faceless edges, or edges around holes, forming flaps/shelves etc with therefore one face only, or edges bounding internal partition faces where they would have three or more faces, or edges shared by two otherwise seemingly solid objects - like cubes meeting along one edge - where that edge is shared by four faces.
          It also precludes nested groups/components and any other entities like text and dims.
          Although construction-lines and points [aka guides] within a collection do not compromise its solidity, these are best avoided when sending on for 3d-printing etc...
            Stefmanovic
            Yeah, I kinda figured that. Means I probably have to start all over again.
            Man, I should learn Blender...
            • olisheaO Offline
              olishea
              you don't have to just use push/pull either to create a solid!
              If you made a model like this in blender, you would still come into problems because you haven't intersected anything, you have just placed shapes inside one another, see section, it should be hollow like a hull:
              oli
                Stefmanovic
                Sorry, I'm just a bit bummed out. Spent a lot of time trying to do this and then realized that I basically did it all wrong with the geometry. I thought I created a solid model, which apparently I didn't.
                • olisheaO Offline
                  olishea
                  if you don't make mistakes you will never learn πŸ˜‰ we all do it! won't take you long to model something like that again; lots of repeating elements where if you get one right, they will all be right. There is also a solid inspector plugin to see where the holes are.
                  oli
                    Stefmanovic
                    I've got the solid inspector plugin, so I will give it a shot with that. πŸ˜„
                    I guess I've grown a bit lazy, kinda hoped a new version of SketchUp could automatically make a selection solid if it doesn't have too big holes. But yeah, that's just super wishfull thinking I guess. 😳
                    • olisheaO Offline
                      olishea
                      SketchUp does already have boolean tools! It's called Solid Tools. You can always do it manually do, by intersecting and deleting geometry.
                      Tak2hata also wrote a bool plugin, as have others.
                      oli
                        Stefmanovic
                        That means you already need to have solid objects. I was kinda hoping for a feature that would easily and automatically make my model solid, meaning I can just easily draw stuff without having to worry about geometries and such.
                        Like I said...I'm feeling lazy. 😍
                          Remember, this is a computer program and GIGO applies. πŸ˜‰
                          One of the things I tell my students early on is to practice good housekeeping and make clean models. It may seem like extra work at the time but it's a whole lot less work than fixing up the model to make it usable, later.
                          • olisheaO Offline
                            olishea
                            I know what you mean.....but it can't happen. You are asking a computer to make choices about which areas to fill etc.
                            You are almost asking the computer to make a vacuum formed cast of your model....now there's an idea for a plugin. Like a vacuum drape tool. πŸ˜‰
                            I don't see why you have a problem creating an array of solids, when your model contains, well, an array of solids already. You are already making solids, they just haven't been intersected cleanly.
                            oli
                              Make your spaceship 30+ meters long...
                              Then when it's done scale it down to 32mm
                              Very tiny facets will not get made in many operations like FollowMe and mesh-making plugins.
                              However, you can scale down afterwards - tiny facets can exist but they can't be made.
                              Also set your 'length-snapping' OFF.
                              Thomthom's SolidInspector will highlight 'issues' with non-solid forms.
                              If the errors are relatively minor then my SolidSolver can probably fix it.
                              If the problems are more widespread, then there are many posts on how to use Temporarily-Hiding-Faces, Using-SectionPlanes, With-Erase, and so on... the solve the issues raised by SolidInspector...
                                d12dozr
                                Also remember the "Outer Shell" tool, which combines solids into one watertight shell.
                                http://goo.gl/f7ooYh
                                  Stefmanovic
                                  Thanks a lot for the help guys! πŸ˜„ I've been playing with the Solid Inspector, which works like a charm! It works that great that I no longer need stuff like Netfabb to fix the model. πŸ˜„
