    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 204.2k Views 41 Watching
      srknytgn
      I don't understand why should i scale imported drawing. I have nothing to do with inches, want to import like SU Pro. My base SU file always in cm or mm unit and always draw in Autocad unitless.
      Finally my su file's unit is cm and I draw a 100 x 100 square in Autocad and I want to see it in SU as 100 x 100 cm. Is it possible with that plugin or not?
        This importer always takes the DXF length of 100 as 100".
        Jim's latest update is intended to allow you to 'scale' the input to whatever units you desire.
        So if you choose "to-mm" then it currently applies a scaling factor to make 100 into 2540mm
        My point was that it should take 1/25.4 as the scaling factor 'from-mm' and therefore you'd get 100mm as your result.
        I'm sure Jim will address this shortly... πŸ˜•
          Jim
          @srknytgn said:
          hey jim,
          i'm trying to import a dxf file but it comes in scaled to inches.
          as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed.
          do you think something was wrong?
          Yes I botched the importer scale. It is now fixed and version 0.8.1 is available in the Plugin Store.
            srknytgn
            Hey Jim, please don't mention it : )
            But the same problem is here, I've attached the screenshot.
            I've also tried clean install, but no way.
            100x100_square.dxf
              Jim
              I found it - this had to do with updating the options from the UI rather than incorrect scaling factors. Check for version 0.8.2 soon.
                srknytgn
                thanks Jim!
                  rungek
                  Just today loaded and tried with Make 2014 on Win 7 x64. Does not work!
                  Removed
                  • BoxB Offline
                    Then you must be doing something wrong, but as you've given no information about how it hasn't worked for you nobody can help.
                      rungek
                      Box. Your right of course so here is the error info. SU reports on startup
                      Error: #<SyntaxError: C:/Users/Laptop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Dxf_In_v2.2.rb:306: formal argument cannot be an instance variable
                      ramFile.each do |@line| #search for entities @line by @line
                      Thanks for any help. Maybe just using provious version of Google SU will be easier.
                        Jim
                        Removed
                        Sorry you are having difficulty.
                        How did you install FreeDXF? What version did you install?
                        The only supported download is from the SketchUcation Plugin Store. The most recent version is 0.8.7. In recent versions of FreeDXF this version number appears right in the Plugins menu.
                        Is this what you see after installing?
                          Jim
                          This error is not from FreeDXF - it is from a different plugin named Dxf_in.
                            rungek
                            Thanks, still new to this and thought I installed the correct plugin. Works now.
                            • W Offline
                              wootton
                              I'm also having trouble installing this plugin into Sketchup 2014. I may have the wrong version; I see above that the latest is 0.8.7, but in the filename I downloaded it's 0.8.2, which appears to have been created 2 months ago, and I can't find a more current version. Is "0.8.7" a typo? If not, is there a link to the newer version? I got it from the following link at the Sketchucation download store:
                              404 Not Found
                              (sketchucation.com)
                              The filename is freedfx_v0.8.2.rbz
                              I pasted the file to the following folder on my computer, and restarted SketchUp:
                              C:\Users\tom\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                              When I try to find it in SketchUp, I don't see a "plugins" icon anywhere, and when I open Ruby console, nothing appears. Have I left out a step?
                              Thanks in advance,
                              Tom
                              Tom Wootton
                              • W Offline
                                wootton
                                Never mind, I figured it out.
                                Tom Wootton
                                  The latest is v0.8.2.
                                  You need to install the RBZ archive's contents, using Preferences > Extensions > Install... button...
                                  No need to mess on accessing your Plugins folder at all, for this kind of Plugin... Just 'AutoInstall' it...
                                    SGC
                                    SU 14.1.1282
                                    FreeDXF 0.8.2
                                    Win7 Pro
                                    Jim - when I open the plug-in I'm getting this empty dialog box. I tried reinstalling both the plug-in and SU14, no changes. Any suggestions?
                                    Screenshot of dialog box
                                      Open Internet Explorer > Safety > Delete Browsing History and empty the cache...
                                      SketchUp uses IE for its web-dialogs, irrespective of your default browser.
                                      Sometimes the cache is messed up and needs clearing...
                                      Report back...
                                        SGC
                                        Report back...
                                        That wasn't it. I deleted temp downloads, cookies, history, and tracking protection from IE, no changes. Did the same in Chrome (my default browser) just to be sure. Restarted SU and still have an empty dialog box when I call up the plugin.
                                          Jim
                                          Hi Stephen - I've not experienced this myself, and don't know why it is happening.
                                          The dialog is made using thomthom's SKUI framework.
                                          Could it be an IE security setting?
                                            Yes, make sure that your IE Internet Options settings for Javascript etc are not overly strict...
                                            Can you get other web-dialogs to work OK ?
                                            • 5 / 8
