    Model for Rendering Samples - Green Dragon
    61 Posts 24 Posters 13.5k Views 24 Watching
    • micioneM Offline
      micione
      Surface: "coating"
      Base: "reflection"
      Lighting: preset
      Render time: 4 minutes
      Rendering engine: Thea Presto
      • ginchiusG Offline
        ginchius
        Dragon with skin
        Thea Presto AO CPU
        20 min.
        You can find my models at http://sketchucation.com/shop/models
        • FrederikF Offline
          Frederik
          Thea Render TR1
          Raw render...
          Cheers
          Kim Frederik
            jpalm32
            @box said:
            I'm not a fan of Green....
            Twilight Render, medium preset.
            Default Realistic Glass material
            HDRI from the Sketucation Store Studio pack.
            Nice. May I ask your TW settins?
            Never can get SSS correct
            • BoxB Offline
              As I said, default Realistic glass(diamond) and easy preset medium.
              Perhaps the trick I used was scaling a copy of the dragon to fit inside and give that a lampshade material. That adds some density to the whole thing.
              You can see the difference in this one, it is the same settings without the inner lampshade. and a different colour.
              • cottyC Offline
                cotty
                Another one with Indigo...
                my SketchUp gallery
                • ElibjrE Offline
                  Elibjr
                  Wow I really 1ike the last two. When I get home I may join in.
                  EB 👍
                  • N Offline
                    notareal
                    As a side note. If jumping into "dragon" studio, one might be interested to look on Henrik Wann Jensen's iconic A dragon made of frosted glass. That inspired some years ago a Frosted Glass Challenge (Any Render Engine) (http://www.atillaakin.com/maxwell/dragonmatrix.png).
                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    • JonFarJ Offline
                      JonFar
                      hi, im not very good at rendering, mainly because its not my primary focus, but i had to do this one
                      VRay 2.0, rendered at 1600x1200, high exterior preset with ambient occlusion
                      Dragon material is a glass bottle vismat, changed the RGB to 33,160,8
                      Dragon Balls downloaded from wharehouse and just added reflection
                      • soloS Offline
                        Studio and product rendering is a very simple task but can be a pain in the ass if you do not have the right tools.
                        In the past as illustrated above I used a studio setup model on which I could pose my model and that worked fine at the time however the problem with such a setup is there is no balanced lighting from behind so one could only light from sides and front or use an HDR image which again would not project from behind as there is a model of a studio blocking it.
                        The whole point of Prodviz is to show the item in best lighting and minimal or soft shadows it is not to set up an elaborate scene as the emphasis is on the product.
                        I have a 2 minute setup solution using Thea render.
                        What you need:
                        A good HDRI (here is a jpg of what I will use for this example)
                        Then you need another map, this time a pure white image:
                        The method here is you put the HDRI in the IBL slot (Image based lighting) and you put the pure white image in the background slot.
                        Now you create a ground plane and remove all materials and create a shadow catcher in Thea materials.
                        Done, now UV map and add material to model and render with Presto MC less than 2 minutes each.
                        Raw renders.
                        • hellnbakH Offline
                          hellnbak
                          what's a render?
                          • BoxB Offline
                            I'm not a fan of Green....Edit; sorry I only just noticed that you wanted everyone to use the same colour.
                            • cottyC Offline
                              cotty
                              Some variations (without green)...
                              (Indigo Renderer)
                              my SketchUp gallery
                              • alvisA Offline
                                alvis
                                TwilightRender. 10 min with Easy 09.
                                • Al HartA Offline
                                  Al Hart
                                  Alvis,
                                  It the image which looks like an office in the lower right of the screen shot pertinent, or only the position of the Dragon on the geometry?
                                  Al Hart
                                  IRender nXt from Render Plus
                                  • FrederikF Offline
                                    Frederik
                                    The image looking like an office is - I assume - the IBL/HDRI used for this scene... 😉
                                    Cheers
                                    Kim Frederik
                                    • Al HartA Offline
                                      Al Hart
                                      @hellnbak said:
                                      what's a render?
                                      All the images in this thread with light highlights and other reflections on the dragon are created with rendering add-ons to SketchUp which create photorealistic, rendered, images from the SketchUp model.
                                      Al Hart
                                      • jeff hammondJ Offline
                                        Chia
                                        click -> cleaner
                                        Indigo, MakeFur
                                        sun
                                        • alvisA Offline
                                          alvis
                                          Definitely yes 😉
                                          • SminkyS Offline
                                            Sminky
                                            I gave it a try with Brighter3D.
                                            The lighting is provided by a HDR image of uffizzi museum and you can see it reflected on the mirror ball.
                                            • 3 / 4
