    Model for Rendering Samples - Green Dragon
    61 Posts 24 Posters 17.6k Views 24 Watching
    • Al HartA
      Al Hart
      I rendered this one with IRender nXt. I made the Dragon translucent, and used a studio background geometry from the 3D Warehouse provided by Solo a few years ago, and the Studio rendering lighting default setting in IRender nXt. I let this rendering "cook" for about 2 hours.
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Al Hart
      IRender nXt from Render Plus
      • micioneM
        micione
        Surface: "coating"
        Base: "reflection"
        Lighting: preset
        Render time: 4 minutes
        Rendering engine: Thea Presto
        • ginchiusG
          ginchius
          Dragon with skin
          Thea Presto AO CPU
          20 min.
          You can find my models at http://sketchucation.com/shop/models
          • FrederikF
            Frederik
            Thea Render TR1
            Raw render...
            Cheers
            Kim Frederik
              jpalm32
              @box said:
              I'm not a fan of Green....
              Twilight Render, medium preset.
              Default Realistic Glass material
              HDRI from the Sketucation Store Studio pack.
              Nice. May I ask your TW settins?
              Never can get SSS correct
              • BoxB
                As I said, default Realistic glass(diamond) and easy preset medium.
                Perhaps the trick I used was scaling a copy of the dragon to fit inside and give that a lampshade material. That adds some density to the whole thing.
                You can see the difference in this one, it is the same settings without the inner lampshade. and a different colour.
                • cottyC
                  cotty
                  Another one with Indigo...
                  my SketchUp gallery
                  • ElibjrE
                    Elibjr
                    Wow I really 1ike the last two. When I get home I may join in.
                    EB 👍
                    • N
                      notareal
                      As a side note. If jumping into "dragon" studio, one might be interested to look on Henrik Wann Jensen's iconic A dragon made of frosted glass. That inspired some years ago a Frosted Glass Challenge (Any Render Engine) (http://www.atillaakin.com/maxwell/dragonmatrix.png).
                      • JonFarJ
                        JonFar
                        hi, im not very good at rendering, mainly because its not my primary focus, but i had to do this one
                        VRay 2.0, rendered at 1600x1200, high exterior preset with ambient occlusion
                        Dragon material is a glass bottle vismat, changed the RGB to 33,160,8
                        Dragon Balls downloaded from wharehouse and just added reflection
                        • soloS
                          Studio and product rendering is a very simple task but can be a pain in the ass if you do not have the right tools.
                          In the past as illustrated above I used a studio setup model on which I could pose my model and that worked fine at the time however the problem with such a setup is there is no balanced lighting from behind so one could only light from sides and front or use an HDR image which again would not project from behind as there is a model of a studio blocking it.
                          The whole point of Prodviz is to show the item in best lighting and minimal or soft shadows it is not to set up an elaborate scene as the emphasis is on the product.
                          I have a 2 minute setup solution using Thea render.
                          What you need:
                          A good HDRI (here is a jpg of what I will use for this example)
                          Then you need another map, this time a pure white image:
                          The method here is you put the HDRI in the IBL slot (Image based lighting) and you put the pure white image in the background slot.
                          Now you create a ground plane and remove all materials and create a shadow catcher in Thea materials.
                          Done, now UV map and add material to model and render with Presto MC less than 2 minutes each.
                          Raw renders.
                          • hellnbakH
                            hellnbak
                            what's a render?
                            • BoxB
                              I'm not a fan of Green....Edit; sorry I only just noticed that you wanted everyone to use the same colour.
                              • cottyC
                                cotty
                                Some variations (without green)...
                                (Indigo Renderer)
                                my SketchUp gallery
                                • alvisA
                                  alvis
                                  TwilightRender. 10 min with Easy 09.
                                  • Al HartA
                                    Al Hart
                                    Alvis,
                                    It the image which looks like an office in the lower right of the screen shot pertinent, or only the position of the Dragon on the geometry?
                                    Al Hart
                                    • FrederikF
                                      Frederik
                                      The image looking like an office is - I assume - the IBL/HDRI used for this scene... 😉
                                      Cheers
                                      Kim Frederik
                                      • Al HartA
                                        Al Hart
                                        @hellnbak said:
                                        what's a render?
                                        All the images in this thread with light highlights and other reflections on the dragon are created with rendering add-ons to SketchUp which create photorealistic, rendered, images from the SketchUp model.
                                        Al Hart
                                        • jeff hammondJ
                                          Chia
                                          click -> cleaner
                                          Indigo, MakeFur
                                          sun
                                          • alvisA
                                            alvis
                                            Definitely yes 😉
                                            • 1 / 4
