    [REQ] un-select everything
    34 Posts 15 Posters 1.9k Views 15 Watching
      driven
      @jeff,
      esc works on my iMac. but I have never used it...
      I don't think it did on my mac book, so haven't tried it since...
        DOD3R
        Hi all,
        I use ESC to exit components/groups i have no problem with that. I dont even need a function exit all, because its not that difficult to hit esc four times to exit from the nested group. And even i thing it helps me to be aware on witch layer in the nest am I.
        But still sometimes I loose track of things and i would like some visual clue. I know there is outliner and it serves this purpose well. But it gets messy sometimes and for good orientation takes a lot of my screen space. I would like something illustrator has. see attachment.
        what do you think?
        T.
          Sure if all components are named "Component"! πŸ’š
          • KrisidiousK Offline
            Krisidious
            Have you been looking at my models again Pilou?
            By: Kristoff Rand
            • BoxB Offline
              Funny how people can be talking about the same thing and not notice.
              @bob james said:
              @jim said:
              Paste this into a file with the .rb extension in your plugins folder.
              > > UI.add_context_menu_handler {|menu|
              > >   menu.add_item("Close All Contexts") {
              > >     Sketchup.active_model.selection.clear
              > >     while (Sketchup.active_model.close_active); end
              Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key πŸ˜„
              Thank you very much πŸ‘
                @jeff hammond said:
                @gilles said:
                It does for me or maybe I've a fake Mac πŸ’š
                really? that's strange.
                do you use an english keyboard? or- i wonder what else may be the reason why ESC deselects for you and not me?
                It works for me on my Mac, too, Jeff.
                  Too true. πŸ˜‰
                  • Bob JamesB Offline
                    Bob James
                    massimo did notice.
                    @massimo said:
                    @krisidious said:
                    Esc does work and I use it often... But something to exit out of all groups and unselect everything back to the top of the model hierarchy would be nice.
                    This works like a charm.
                    That's what led me to turn Jim's code into backout.rb
                    BackOut.rb
                    • soloS Offline
                      massimo did notice.
                      πŸ‘
                      • bazB Offline
                        baz
                        Perhaps I am misunderstanding the issue but in the shortcuts menu there is an option for 'deselect all' This doesn't 'back out' like the escape key but does exactly what it says.
                        I have it set as 'shift D'
                        Baz
                          Bob James
                          That's the whole point of this discussion. Deselecting something buried within a component/group still leaves you inside the group/component. Backout deselects and brings the cursor all the way out of the group/component leaving you free to select something else in your model.
                          By the way:,I can't find this:
                          • bazB Offline
                            baz
                            I get you, 'Select None' only deselects within the group or component.
                            Here Tis...
                              Bob James
                              Thanks:I was looking for 'deselect all'
                              • bazB Offline
                                baz
                                my bad 😳
                                • jeff hammondJ Offline
                                  @gilles said:
                                  @jeff hammond said:
                                  are we talking about exiting groups or un-selecting selected items? πŸ˜• i'll read back through the thread a little later.
                                  Both.
                                  what if you aren't editing inside a group (raw geometry) and you have some items selected? will ESC deselect those items? i've tried it on a macpro and a mbp now and it works on neither. for that, i have to use the 'select none' shortcut.
                                  (though the way i usually do this when there is no blank space to click in is to select a new item which i can see then shift-select it in order to clear all selections.. just i bad habit i've developed over the years where i should probably be using the shift-cmmd-A shortcut)
                                  • gillesG Offline
                                    gilles
                                    @jeff hammond said:
                                    @gilles said:
                                    Both.
                                    Yes this works, I' running Mountain lion Mac book pro SU V8.
                                    As I said before ESC does not deselect with some tools when they are active.
                                      well.. that's just strange (tried it in su8 too on lion and mavericks-- with various active tools).. i'm sure there's a reason behind the differing behaviors on our computers but i guess it's not important enough to figure out.
                                      fwiw, i do use the ESC key often in sketchup but i use it as a cancel button while drawing (for instance, i use the line tool if i need to measure something but i ESC once i see the dimension in the measurement box.. or if i misplace the beginning click of a tool etc..)
                                      • 2 / 2
