    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @vremennyi said:
      Or is this SU bug and about this should think SU developers?
      This.
      • Bob JamesB Offline
        Bob James
        Any updates you'd care to share on the work to make LP and Thea work together?
          jiminy-billy-bob
          Thea doesn't expose any render funtion in ruby. The render is triggered on C++ side. So there is no way I can trigger it from Layers Panel. Therefore, it must be Thea that reads LP's attribute to see which layers have been tagged 'to be rendered' by the user.
          (The same issue applies to render[in], shaderlight, twilight)
          It's pretty simple:
          • Check if LP is active (optional)
            JBB_LayersPanel.isActive == true
          • Determine in which context the user is (active scene if one exists, otherwise the model)
            if Sketchup.active_model.pages.selected_page == nil context = Sketchup.active_model else context = Sketchup.active_model.pages.selected_page end#if
          • Read the attributes to see which layers are tagged
            layerId = layer.get_attribute("jbb_layerspanel", "ID") context.get_attribute("jbb_layerspanel_render", layerId)
            It gives 0 or 1 if the layer should not be rendered, and 2 if the layer should be rendered.
          I gave this to Tomasz, I don't know if he tried to add it to Thea or not.
          I'll probably simplify all of this in an upcoming update with simply something like:
          JBB_LayersPanel.render(layer) that would return true or false.
          • tt_suT Offline
            tt_su
            Yes - it's our fault. 😞 We're working on a fix.
            • U Offline
              unclex
              Winx64chinse
              SU2013english OK
              SU2014english Not Work Still
                jiminy-billy-bob
                @unclex said:
                Winx64chinse
                SU2013english OK
                I invite you to read the post just above yours... πŸ˜’
                  pibuz
                  Hello Jiminy!
                  I had some time to test this baby and I cannot get it to work.
                  I use Indigo Renderer (SkIndigo exporter 3.6.25.5 version), and:
                  1. none of the peculiar and extra-useful tools of your plugin work (neither the "hide but render" or the "show but not render")
                  2. when clicking on the Indigo Logo on the upper right corner of the plugin, a message is displayed saying that Indigo Is no tinstalled on the pc, whether it is instead, and it works like a charm if I use the SkIndigo export bar...
                  The plugin seems wonderful, really! Only, at the moment Indigo support is a little bit unconvincing πŸ˜†
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    jiminy-billy-bob
                    pibuz > It's indeend broken with Indigogo for some reason. I'll fix it.
                    amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
                    So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
                      ckho1985
                      the update work great on Mac now. thanks!!
                      I am sure you are award of it… many have request a 'sort by name' function on the table. so we could navigate layers easily.
                      thanks once more
                      • U Offline
                        unclex
                        sorry jiminy
                        I know it's not your fault
                        but I was so regretful for cannot using your wonderful plugins
                          jiminy-billy-bob
                          @unclex said:
                          sorry jiminy
                          Don't worry, no hard feelings.
                          While waiting for a fix, you can start Sketchup and then open your file from SU. It should work fine.
                          • SolarwiseLLCS Offline
                            SolarwiseLLC
                            Jiminy-Billy-Bob,
                            First off let me say I love this plugin.
                            Recently, my layer's panel has become unresponsive in one of my drawings. (This is true for SU13 and SU14) Unresponsive in that the layers do not toggle on or off anymore. This one file was working. I saved multiple copies of it and now none of them work properly. Other files/drawings work. I even created a new drawing. Created a new layers list and pasted the original drawing in layer by layer. This worked until I closed the drawing and restarted my computer. Is there a a easy fix? I could have moved or removed a file when I was trying out SU 14.
                            Layers Panel 1.03
                            I'm using SU 13, but have 14 installed
                            Windows 8
                            I have other layer managing plugin installed (Conflict?) They aren't interfering with my other files.
                              jiminy-billy-bob
                              Could you send me the file by PM?
                              What are the other layer managing plugins?
                                jiminy-billy-bob
                                @solarwisellc said:
                                So something strange has happen since I posted. I continued to work on the drawing "DD1", but stopped using the Layer Panel plugin. I was just using the Layers Window. After a while I checked the Layers Panel and it had started working again. I noticed all the folders had been removed and it was now just a list of layers.
                                Drawing DD1.1 still shows the folders and is still unresponsive.
                                Addition layer plugins:
                                Layers Manager (I think that is it)
                                I'm not sure what caused the issue, but here is how to solve it:
                                • Install Aerilius' AttributeInspector
                                • Open it
                                • Click on "jbb_layerspanel"
                                • Delete all the " group[22]=null&group[23]=22&layer...." stuff (Just select and delete)
                                • Reopen Layers Panel, you should loose all the sorting and groups, but it should work fine.
                                http://i.imgur.com/xqYYqWb.png
                                  SolarwiseLLC
                                  • Open it
                                  Thanks. I will try this. Will I be able to regroup afterwards?
                                    jiminy-billy-bob
                                    Of course, LP should behave normally after this. It's a fresh start.
                                    • sadyoS Offline
                                      sadyo
                                      Hi mr.Bob
                                      Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
                                      http://s30.postimg.org/mgwf0y5fl/hh2.jpg
                                      I'm using Sketchup 2014 pro_Win8.1-64bit
                                        jiminy-billy-bob
                                        sadyo > Please see:
                                        • tt_suT Offline
                                          tt_su
                                          That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                                            SolarwiseLLC
                                            After resetting the folders as you outlined. I was able to regroup and work in the file successfully. After closing SU and restarting my computer, the layers panel stop being responsive in that file. After working in the same file, using just the layers window, the layers panel reset the folders/grouping by itself. Once it reset itself, the layers panel worked, but the folders/grouping were deleted. Wondering if it's the plugin or my file.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 33
                                            • 34
                                            • 23 / 34
