    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • vremennyiV
      vremennyi
      @tony bombata said:
      interestingly, if you pin a file to sketchup 2014, and launch from the taskbar jumplist, it will open without errors - dont know if that helps
      Thank you! It works!
      I think it may be linked with SU current "Working Directory".
      I tested some random folders. If current working directory is on other drive than SU installed(maybe it should be only C:) plugin crashes.
      I have profile folders on D:. When I'm starting SU with desktop shortcut SU's working dir sets to D:\Profile\Desktop. When starting from pinned shortcut - C:\Windows\System32\
      jiminy-billy-bob, you are using relative paths in source. Maybe ruby engine tries load file using current working directory and only it's drive(D: in my case)
      Maybe there is way to set up current working dir to system drive or any MS API to find system drive and try load required libraries with that path?
      Or is this SU bug and about this should think SU developers?
      I think any can repeat this bug in Windows just changing "Working dir" in shortcut to any folder on any another than system drive.
      Is there bugtracker?)
      • jiminy-billy-bobJ
        jiminy-billy-bob
        This.
        • Bob JamesB
          Bob James
          Any updates you'd care to share on the work to make LP and Thea work together?
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Thea doesn't expose any render funtion in ruby. The render is triggered on C++ side. So there is no way I can trigger it from Layers Panel. Therefore, it must be Thea that reads LP's attribute to see which layers have been tagged 'to be rendered' by the user.
            (The same issue applies to render[in], shaderlight, twilight)
            It's pretty simple:
            • Check if LP is active (optional)
              JBB_LayersPanel.isActive == true
            • Determine in which context the user is (active scene if one exists, otherwise the model)
              if Sketchup.active_model.pages.selected_page == nil context = Sketchup.active_model else context = Sketchup.active_model.pages.selected_page end#if
            • Read the attributes to see which layers are tagged
              layerId = layer.get_attribute("jbb_layerspanel", "ID") context.get_attribute("jbb_layerspanel_render", layerId)
              It gives 0 or 1 if the layer should not be rendered, and 2 if the layer should be rendered.
            I gave this to Tomasz, I don't know if he tried to add it to Thea or not.
            I'll probably simplify all of this in an upcoming update with simply something like:
            JBB_LayersPanel.render(layer) that would return true or false.
            • tt_suT
              tt_su
              Yes - it's our fault. 😞 We're working on a fix.
              • U
                unclex
                Winx64chinse
                SU2013english OK
                SU2014english Not Work Still
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  @unclex said:
                  Winx64chinse
                  SU2013english OK
                  I invite you to read the post just above yours... πŸ˜’
                  • P
                    pibuz
                    Hello Jiminy!
                    I had some time to test this baby and I cannot get it to work.
                    I use Indigo Renderer (SkIndigo exporter 3.6.25.5 version), and:
                    1. none of the peculiar and extra-useful tools of your plugin work (neither the "hide but render" or the "show but not render")
                    2. when clicking on the Indigo Logo on the upper right corner of the plugin, a message is displayed saying that Indigo Is no tinstalled on the pc, whether it is instead, and it works like a charm if I use the SkIndigo export bar...
                    The plugin seems wonderful, really! Only, at the moment Indigo support is a little bit unconvincing πŸ˜†
                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      pibuz > It's indeend broken with Indigogo for some reason. I'll fix it.
                      amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
                      So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
                      • C
                        ckho1985
                        the update work great on Mac now. thanks!!
                        I am sure you are award of it… many have request a 'sort by name' function on the table. so we could navigate layers easily.
                        thanks once more
                        • U
                          unclex
                          sorry jiminy
                          I know it's not your fault
                          but I was so regretful for cannot using your wonderful plugins
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            @unclex said:
                            sorry jiminy
                            Don't worry, no hard feelings.
                            While waiting for a fix, you can start Sketchup and then open your file from SU. It should work fine.
                            • SolarwiseLLCS
                              SolarwiseLLC
                              Jiminy-Billy-Bob,
                              First off let me say I love this plugin.
                              Recently, my layer's panel has become unresponsive in one of my drawings. (This is true for SU13 and SU14) Unresponsive in that the layers do not toggle on or off anymore. This one file was working. I saved multiple copies of it and now none of them work properly. Other files/drawings work. I even created a new drawing. Created a new layers list and pasted the original drawing in layer by layer. This worked until I closed the drawing and restarted my computer. Is there a a easy fix? I could have moved or removed a file when I was trying out SU 14.
                              Layers Panel 1.03
                              I'm using SU 13, but have 14 installed
                              Windows 8
                              I have other layer managing plugin installed (Conflict?) They aren't interfering with my other files.
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                Could you send me the file by PM?
                                What are the other layer managing plugins?
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  @solarwisellc said:
                                  So something strange has happen since I posted. I continued to work on the drawing "DD1", but stopped using the Layer Panel plugin. I was just using the Layers Window. After a while I checked the Layers Panel and it had started working again. I noticed all the folders had been removed and it was now just a list of layers.
                                  Drawing DD1.1 still shows the folders and is still unresponsive.
                                  Addition layer plugins:
                                  Layers Manager (I think that is it)
                                  I'm not sure what caused the issue, but here is how to solve it:
                                  • Install Aerilius' AttributeInspector
                                  • Open it
                                  • Click on "jbb_layerspanel"
                                  • Delete all the " group[22]=null&group[23]=22&layer...." stuff (Just select and delete)
                                  • Reopen Layers Panel, you should loose all the sorting and groups, but it should work fine.
                                  http://i.imgur.com/xqYYqWb.png
                                  • SolarwiseLLCS
                                    SolarwiseLLC
                                    • Open it
                                    Thanks. I will try this. Will I be able to regroup afterwards?
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Of course, LP should behave normally after this. It's a fresh start.
                                      • sadyoS
                                        sadyo
                                        Hi mr.Bob
                                        Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
                                        http://s30.postimg.org/mgwf0y5fl/hh2.jpg
                                        I'm using Sketchup 2014 pro_Win8.1-64bit
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          sadyo > Please see:
                                          • tt_suT
                                            tt_su
                                            That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 33
                                            • 34
                                            • 23 / 34
