    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @jql said:
      We could change the color of a group and change all the layers inside it or window select some layers, then changing one, could change all. Maybe selecting a bunch of layers and make all layers same color from the active layer...
      It's coming! 😄
      TT > Thanks a lot for your generous donation, that's very much appreciated 😉
        jiminy-billy-bob
        New version 1.0.2 !
        Changelog :
        • All selected layers are now sorted together
        • Added shift-click for multiple selection
        • Fixed issue when copy/pasting from another instance creates a new layer
        • Fixed minimize/maximize
        Download in the plugin store !
          ckho1985
          Have to praise this tool!! working on big projects and having loooooooooong list on the SU layers is just a pain.
          Notice you have added a render icon for different engines on your tool. Artlantis is not there…. doesn't affect my work. but at first i though it was a miracle button to press.
          working on Mac machine. works okay, not as smooth as you show it
            jiminy-billy-bob
            Can't you already choose which layer you want to render in Artlantis?
            What's not smooth on Mac? Can you do a small video?
            • tt_suT Offline
              tt_su
              I just noticed that 1.0.2 doesn't update the WebDialog when you add/remove layers via the WebDialog. The model layers are created - it's just the UI doesn't.
              Adding layer-groups updates the UI though.
                ckho1985
                for the rendering button, at first, i thought it would open up an instant window for quick rendering instead of having to opening Artlantis separately. I think the render function makes more sense for those plug-in engines and so…. ( i used to run Shaderlight… not on your list either)
                Keeping Artlantis not saying its a bad thing, there are pros and cons I would say.
                Not so smooth wise. it does't happen all the time, but so far i found the following are most common.
                1)The subject (layers and names) on your tool window does not response simultaneously to SU window. (i.e.; what I click add layer in your tool, I can see layer is added ONLY in the SU window, but not on tool's window) like they both do not spontaneously correspond.
                1. Having several SU files open. switching from one to other. The tool struggles to keep up.
                  ie; the tool's window content still showing the first SU model, even I have jump to working on the second model. (the first model still running at the back ground)
                Sorry don't have a video (don't know how to, please enlighten me if there is a way to Screen-capture a video)
                will let you know if there is further niggles
                  ckho1985
                  and just now… it crashes 👊 👊 👊 👊 👊 👊
                  • tt_suT Offline
                    tt_su
                    Are you submitting the BugSplats? Did you enter any information we can use to look it up?
                    • unclebimU Offline
                      unclebim
                      I confirm that the copy/paste issue when creation of new layers is needed is solved. Great work!
                      How about that:
                      @nanolin said:
                      Hello
                      You can sort the list by alphabetical order of layers? . It can be added as an option?
                      thanks
                      Someone (maybe you ?) already suggested this. So it's on my todo list 😉
                      If possible, would be layer groups sorted too and would the user be able to overwrite the alphabetical sorting or just put a lower number as prefix in order to get the layer up?
                        ckho1985
                        It is not a bugsplats. the programme freezes up, so i had to force quit. summited report to apple.
                        but yes, i generally summit reports if bugsplats occurs
                        • Y Offline
                          yinliangxxxx
                          载入文件 C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb 时出错
                          Error: 126: ÕÒ²»µ½Ö¸¶¨µÄÄ£¿é¡£ - C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Win32API.so
                          C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in require' C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in module:JBB_LayersPanel'
                          C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>' D:/Tool/SketchUp 2014/Tools/extensions.rb:197:in require'
                          D:/Tool/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in register_extension'
                          C:/Users/Seven-Yin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in `<top (required)>'
                          Thank Quick Update,but Layers Panel Beta v1.0.2 Unable to load!
                          in Sketchup 2014
                          Hope to be in Sketchup2014 Run!!
                            jiminy-billy-bob
                            New version 1.0.3 !
                            Changelog :
                            • Fixed multiple important issues on OSX
                              jiminy-billy-bob
                              It's a limitation of the Sketchup API. I can't do better.
                              You have to move the view for the dialog to update. (Orbit, pan, etc)
                              Actually, after some testing, serveral things -including this- were broken since version 1.0.0 on Mac. It's weird that nobody mentionned it earlier.
                              I fixed it, see below:
                              • vremennyiV Offline
                                vremennyi
                                @tony bombata said:
                                interestingly, if you pin a file to sketchup 2014, and launch from the taskbar jumplist, it will open without errors - dont know if that helps
                                Thank you! It works!
                                I think it may be linked with SU current "Working Directory".
                                I tested some random folders. If current working directory is on other drive than SU installed(maybe it should be only C:) plugin crashes.
                                I have profile folders on D:. When I'm starting SU with desktop shortcut SU's working dir sets to D:\Profile\Desktop. When starting from pinned shortcut - C:\Windows\System32\
                                jiminy-billy-bob, you are using relative paths in source. Maybe ruby engine tries load file using current working directory and only it's drive(D: in my case)
                                Maybe there is way to set up current working dir to system drive or any MS API to find system drive and try load required libraries with that path?
                                Or is this SU bug and about this should think SU developers?
                                I think any can repeat this bug in Windows just changing "Working dir" in shortcut to any folder on any another than system drive.
                                Is there bugtracker?)
                                  jiminy-billy-bob
                                  This.
                                  • Bob JamesB Offline
                                    Bob James
                                    Any updates you'd care to share on the work to make LP and Thea work together?
                                      jiminy-billy-bob
                                      Thea doesn't expose any render funtion in ruby. The render is triggered on C++ side. So there is no way I can trigger it from Layers Panel. Therefore, it must be Thea that reads LP's attribute to see which layers have been tagged 'to be rendered' by the user.
                                      (The same issue applies to render[in], shaderlight, twilight)
                                      It's pretty simple:
                                      • Check if LP is active (optional)
                                        JBB_LayersPanel.isActive == true
                                      • Determine in which context the user is (active scene if one exists, otherwise the model)
                                        if Sketchup.active_model.pages.selected_page == nil context = Sketchup.active_model else context = Sketchup.active_model.pages.selected_page end#if
                                      • Read the attributes to see which layers are tagged
                                        layerId = layer.get_attribute("jbb_layerspanel", "ID") context.get_attribute("jbb_layerspanel_render", layerId)
                                        It gives 0 or 1 if the layer should not be rendered, and 2 if the layer should be rendered.
                                      I gave this to Tomasz, I don't know if he tried to add it to Thea or not.
                                      I'll probably simplify all of this in an upcoming update with simply something like:
                                      JBB_LayersPanel.render(layer) that would return true or false.
                                      • tt_suT Offline
                                        tt_su
                                        Yes - it's our fault. 😞 We're working on a fix.
                                        • U Offline
                                          unclex
                                          Winx64chinse
                                          SU2013english OK
                                          SU2014english Not Work Still
                                            jiminy-billy-bob
                                            @unclex said:
                                            Winx64chinse
                                            SU2013english OK
                                            I invite you to read the post just above yours... 😒
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 33
                                            • 34
                                            • 23 / 34
