    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 194.9k Views 18 Watching
      driven
      the problem seems to be the path from boost to the file not having the correct permissions, if that makes sense...
      As the folder is in the HD/Applications/ I have tried it at /tmp/, ~/Desktop, ~/Documents and in Plugins, all fail...
      my copy of boost lives in /usr/local/bin/include, but it's a symlink to homebrew/cellar so that my be the issue...
      not following symlink from ruby, I'll check it again from terminal...
        driven
        that returns
        dyld; Symbol not found; __cg_jpeg_resync_to_restart
          Referenced from; /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          Expected in; /usr/local/lib/libJPEG.dylib
         in /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        Trace/BPT trap; 5
          tak2hata
          @driven said:
          that returns
          > Trace/BPT trap; 5
          Avoiding this problem,
          I will write the code for serialized mesh exporter in ruby.
          Thanks.
          by TAK2HATA
            driven
            Good idea, it's probably the best long term solution...
            you can PM me if you want anything tested...
              driven
              I just had a thought and did some tests...
              commandline tool need to modify .bashrc to point to python...
              I don't use a .bashrc file, i use .bashprofile, so I created one under User/me/.bashrc and it's not written to...
              where is your .bashrc located, and exactly what does it contain??
                tak2hata
                I search in my mac.
                I found "bashrc" in "/private/etc"
                it contains this.
                # System-wide .bashrc file for interactive bash(1) shells.
                if [ -z "$PS1" ]; then
                   return
                fi
                PS1='¥h;¥W ¥u¥$ '
                # Make bash check its window size after a process completes
                shopt -s checkwinsize
                # Tell the terminal about the working directory at each prompt.
                if [ "$TERM_PROGRAM" == "Apple_Terminal" ] && [ -z "$INSIDE_EMACS" ]; then
                    update_terminal_cwd() {
                        # Identify the directory using a "file;" scheme URL,
                        # including the host name to disambiguate local vs.
                        # remote connections. Percent-escape spaces.
                	local SEARCH=' '
                	local REPLACE='%20'
                	local PWD_URL="file;//$HOSTNAME${PWD//$SEARCH/$REPLACE}"
                	printf '¥e]7;%s¥a' "$PWD_URL"
                    PROMPT_COMMAND="update_terminal_cwd; $PROMPT_COMMAND"
                fi
                by TAK2HATA
                  driven
                  thanks for that,
                  I found a note in the 'Mitsuba' source repository that the .bashrc file was no longer written to, so their message-box needs updating.
                  It does seem to be a simple path issue, that halts the process...
                  I just can't find it.
                  I have a separate instal of 'boost', so it may be a version/path conflict when Mitsuba calls it from shell...
                  Mitsuba works with other .dae files when imported, and I have older scene files from a previous instal, that run after they are auto updated on loading...
                  I'll remove my copy of boost and see if that makes a difference...
                    driven
                    hi
                    got it working...
                    will need tidying...
                    line 264
                    			commandline = %Q{cd /Applications && Mitsuba.app/Contents/MacOS/mtsimport #{objfile.gsub(/\\/,'/')} #{xmlfile.gsub(/\\/,'/')}}
                    OSX 10.9.2 must be stricter about the context...
                      tak2hata
                      @driven said:
                      hi
                      got it working...
                      line 264
                      Hi,john.
                      Thanks!!!
                      I change that line.and I update this to v1.2.1.
                      I am very Happy.
                      Thank you very much!
                      by TAK2HATA
                        tak2hata
                        @sadyo said:
                        Mitsuba seem work fine on my Sketchup 2014-Windowc 8.1 64bit
                        But,
                        How to implementing the clipmap/2D object in Mitsuba ❓ ❓
                        http://s1.postimg.org/jtfu9opfj/image.jpg
                        it won't appear in Renderer
                        Hi sadyo.
                        This problem is still exists.
                        if it is clip mapped material ,please use mask option in "OTHER" tab of material editor.
                        But the Image object is not material.
                        So it can not edit by material editor.
                        Please explode it to face and material.
                        The image object is no supported in this plugin ,yet
                        It will support in future version.
                        But clipping of Image object will not be supported.
                        And other notice,mitsuba render can not read TIFF and PSD.
                        by TAK2HATA
                          driven
                          downloaded v1.2.1 and notice you left the log code in...
                          		system(commandline, ;out => ['/tmp/log.txt', 'a'], ;err => ['/tmp/log.txt', 'a'])
                          not sure if it breaks PC's
                            tak2hata
                            Sorry.
                            Now I deleted that log option.and updated.
                            Thanks john!
                            by TAK2HATA
                              sergonavt
                              ""sophi skin"" 😞((
                              windows-7, 64-bit, SU-7.
                                Does anyone have any genderal advice on installing mitsuba? I am getting a report that a dll is missing and installation stops. Basically I can find no proper install documentation. Thanks.
                                  driven
                                  @mike
                                  did you try either/both of these window.exe downloads?http://www.mitsuba-renderer.org/download.html
                                  maybe some machine specs would help us out, helping you...
                                    Thanks John, I feel like a right muppet not including specs, not as if I do not know, please put it down to a muppet day. I have tried the 64 bit program from that site/location.
                                    Specs as in the attached image.
                                    NVIDIA graphics card 1gb vram. This is updated as of about 1 week ago for drivers.
                                    System Specs
                                      tak2hata
                                      Hi,All.
                                      I update this to v1.2.4. in 2014-03-21.
                                      I finally understood this problem of running mtsimport.
                                      I add code setting current directory in ruby.
                                      So mtsimport will make "textures" in setter directory.
                                      Thanks John.
                                      Hi,Mike.
                                      There is "vcredist_2013_x64.exe" in folder unzipped mitsuba render package.
                                      It is microsoft visual studio 2014 x64 redisributable package"
                                      Please install it.
                                      Mitsuba will work.
                                      by TAK2HATA
                                        driven
                                        thank you...
                                        next thought is, can we 'tag the view' before export, and if it is the 'same tag' after a materials tweak, skip the geometry re-creation? maybe an update button on the materials dialog?
                                        jonh
                                          Thanks very much, its appreciated.
                                            driven
                                            sketchup model, materials, no lights
                                            slowly getting the hang of it...
                                            • 2 / 6
