    Like "Rail revolve" in Rhino
    23 Posts 6 Posters 2.6k Views 6 Watching
      Try EEby Rails...
      If you use the same Profile at the start and end of ONE Rail then it will sweep along that Rail [pick the same rail twice].
      If you set the profiles non-orthogonally to the model axes [or to each other] then the sweep is 'skewed'.
        Maybe one image from you will be more useful and speedy and avoid any reseach by ourselves ! πŸ˜‰
        Moi to Sketchup πŸ˜„
        I believe that you can make the same but in several parts with the existing plugins from Tig or Fredo!
          tambox
          I want to this in one shot or easier way is possible.
          In Rhino I can do this and more:
          I can put the axis of rotation out of the center of the basis shape
          I can have the axis of rotation not perperdicular to the basis shape
          I can have the basis shape not on one plan but a 3d profile
          thank you in advance for your solution
          • jeff hammondJ Offline
            depending on the desired shape, you may be able to use the followMe tool to do a rail revolve:
            @tambox said:
            I need to turn followingan irregular shape, not a circle; and the second issue is to incline the axis of rotation in a non perpendicular direction - please see a tutorial image or video "Rail revolve" of rhino
            I don't believe it works with tool you suggested...
            to do an off-centered or non-perpendicular revolve axis, you should probably just use rhino.. πŸ˜‰
            (or- set up multiple profiles of the shape at various locations along the path then loft it with curviloft.. this may or may not be possible with your desired revolve.. upload a .skp for better advice)
              tambox
              this solid in picture is made by a real lathe with axis of rotation out of center and inclined, the spindle move along a rail profile.
              in Rhino after designing the basis "rail" profile (2d or 3d), designing the axis rotation in one shot make this with "rail revolve" in one shot.
              please tell me all the steps to follow in sketchup with a geometrical control of basis figures (1-rail profile, 2-section path, 3-rotation axis), without slicing in many parts
                why don't you use rhino to do this? seems like the best way-- especially if you're looking for fastest/easiest/most accurate..
                  tambox
                  I don't want to leave sketch-up for Rhino; I designed these shape with sketchup with much effort using only starting from rail profile basis push-pull + scale sveral times to follow the path preferred and editing free hands the model. When a friend of mine sowed me Rhino does it in one shot command I got crazy.. It is a challenge to do it in sketchup.
                  Is there a good guy able to set up a plug in similar to "push-pull and scale following a path" (and an axis)?
                    tambox
                    if we have a push-pull and scale following a path of a 3d basis rail ( I mean a plan figure in 3d like a chipster) we can do it!
                      tambox
                      here is a .skp file and jpg files showing as follow-me doesn't work but push/pull+scale work but working in a very slow way
                      Base and profile.skp
                        Why you don't make the inverse in your special case? πŸ˜‰
                        Take the horinzontal section then make a little vertical loft!
                        I believe that Curviloft by Fredo can make that!
                        Take a face start (your section), a face end (any what you want )and your profile as path! πŸ˜‰
                        Ps Post your file as V6 for a more large audiance! πŸ˜‰
                        Try also Lss Toolbar by Kirill2008
                          tambox
                          Thank you Pilou,
                          As Jeff suggested I'd need to set up in size and position my basis horizontal and connect them two each time with curviloft, but it is too long for my design as in samples I posted where I solved simply with repeated pull/push+scale.... I search something to short this process
                            you might be able to do your example fairly quickly with curviloft's sweep function (the middle icon in its toolbar)
                            if you duplicate your profile curve and mirror it to the other side of the path then use the two profiles as rails, it should give the desired results. I'm on a phone right now- I'll try it out later.
                            • massimoM Offline
                              massimo Moderator
                              This is curviloft, as jeff suggested. Is it what you want to achieve?
                              I've simplified the profile because there was a ton of segments.
                                right.. like that ^
                                  tambox
                                  thank you guys,
                                  I'm proud that help arrived from Italy to Italy!
                                  Now let's try to shake it tilting the shapes or modify the basis figure in 3d shape
                                  thank you for your helps
                                  all the best to you
                                    My vertical method with always Curviloft! πŸ˜„
                                    Thickness is not straight inside!
                                    • massimoM Offline
                                      massimo Moderator
                                      Well I don't know if Jeff has some Italian ancestor. πŸ˜‰
                                      • Rich O BrienR Online
                                        The Borgias.
                                          tambox
                                          please give me setting of curviloft in this case: method? geometry?.... or a screenshot of your vedeo
                                          thank you from italy
                                            Something like this πŸ˜„
                                            Separate the Profile (welded) for a better easy selection of the segments!
                                            Select the profil
                                            Select the surface
                                            (click twice on the middle of the surfaces - zoom it)
                                            Click Twice on the empty Space
                                            And curiously prefere an horizontal "profil"! (so just a rotation from my previous post! πŸ˜‰
                                            Thickness will follow the skin!
