    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.5k Views 98 Watching
    • tt_suT
      tt_su
      There is no way I can keep the SI tool active while editing. The API doesn't have any feature to do so.
      Best thing I can do is selecting the edges.
      • jgbJ
        jgb
        No need to keep SI active during an edit. Just make it easier to switch back and forth.
        Selecting edges would be a real bonus.
        jgb
        • tt_suT
          tt_su
          Toolbar?
          • jgbJ
            jgb
            @tt_su said:
            Toolbar?
            That could work. πŸ‘ πŸ‘
            One icon to launch SI on a selected object.
            2nd icon to launch edit mode on same object.
            They would be mutually exclusive, one or the other, not both at the same time.
            Other icons for other stuff.
            jgb
            • O
              Orthogon
              Like many people I have a model which just "is not manifold" (says Slic3r) and I cannot find the problem, so I found your program. I haven't found a manual or documentation for it though. My question is: how do I know it's working? The only indication is the check mark by Tools->Solid Inspector (which does not turn off when I click "Solid Inspector") -I would think an icon would be more intuitive. But anyway... No Ruby Console messages, no errors, no sounds, no screen messages or lines, no flashing popup (i.e. "group checks fine" or "component has n errors"). I tried pressing "tab"; does nothing. The only indication that it's enabled is that when I click outside of a group/component, it doesn't deselect it (a bug?) like the selection arrow does. It is ver 1.2, and library 2.9.8 BTW
                You might try selecting a non-solid group or component and then activating the tool. See what you get. There are instructions in the first post of this thread, too.
                • P
                  psychomuffin
                  Thomthom, I must say, and I'm sure many others have, that this plugin is a lifesaver! It is amazing how some details so tiny can have such a huge impact to STLs. I would have never found the errors otherwise!
                  Also... for anyone else having trouble with the installation process with rbz, I just searched google for "tt_solid_inspector.rb" and that regular ol' *.rb file is posted in other places =-)I put that in my plugin folder and it worked great!
                  • tt_suT
                    tt_su
                    I'd recommend you install the latest version. If you are using SketchUp older than version 7 you can read this article on how to install it manually: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                    • K
                      keramare
                      just T H A N X
                        d12dozr
                        I just tried installing Solid Inspector via Extensions Warehouse in Sketchup 2014, but got an error message:
                        Downloading and installing manually worked fine, but also got a reminder to install TT_Lib2 (Duh!), which worked fine to install via Extensions Warehouse.
                        Just to check the process, I uninstalled Solid Inspector via Extensions Warehouse, closed and reopened Sketchup, then tried to reinstall it. Same error message.
                        So I can install manually, but not via EW.
                        http://goo.gl/f7ooYh
                          Mythos
                          I really like Solid Inspector because it makes my life much easier for 3D printing. Thank you very much for this fantastic tool!
                          Unfortunately there is a small issue left in the pre-inspection phase (before I use Solid Inspector):
                          Most times I create a lot of groups of nested solid objects to ease the model organization. Before a model can be printed I create a copy of the skp file and manually ungroup all nested groups until I have all solids on the root level of the group (letting the group become a solid group). This must be done otherwise the solid tools can not be used. Then I start to merge, intersect, subtract the solid groups by using the solid tools. Afterwards I use Solid Inspector to fix the problems. Then it can be printed.
                          Especially for complex models this manually un-nesting operation of many groups took a lot of time. 😐
                          Is there any possibility to do that un-nesting group operation with Solid Inspector? In other words I want to bring all nested solids on one level by a one-click operation to let all groups become solid-groups.
                          Here is a screenshot showing my problem. All nested groups need to be manually exploded to transform "1-Before" into "2-After" to let "2-After" be a solid group.
                          http://sketchucation.com/forums/download/file.php?mode=view&id=119599
                          Thank you very much for your attention.
                            robrobk
                            i was building something and i found out that a component wasnt "solid" so i spent at least 2 hours trying to find the problem. i finally gave up and did a google search for my problem and found a website that had a link to this plugin, within 2 minutes, my component was solid
                            i cant thank you enough for this plugin! 😍 😍 😍 😍 😍 😍
                            • TandemT
                              Tandem
                              Thank you very much Thomas for this great plugin, really saved the day. 😍
                                miniellipse
                                screenshot
                                I just downloaded this plugin and put it through a simple test. Not sure, what I am doing wrong but it does not seem to recognize a missing face.
                                I am using Sketchup version V14.0.4900
                                example of plug in not finding a missing face.
                                  It's not showing you any problems because there aren't any. You just hid the face so it looks like there's a hole. That's not the same as a missing face. πŸ˜’
                                  If you actually delete the face, then the plugin shows you the hole. The plugin works just fine.
                                  • tt_suT
                                    tt_su
                                    This issue came up with the STL exporter as well.
                                    Filed new issue: https://bitbucket.org/thomthom/solid-inspector/issue/5/detect-hidden-entities
                                      It's not an issue with Solid Inspector or SketchUp seeing the group as a Solid ?
                                      BUT of course it could flag the 'hidden' parts if its export is critical...
                                      It only becomes an issue when exporting geometry that ignores Hidden entities, or those on OFF Layers, because then the exported object is no longer a Solid...
                                      So tools like the STL Exporter needs to 'include' any such 'hidden' geometry, if those are critical to the Solidity of the exported object......
                                        Yea, even SketchUp doesn't take into account hidden entities in the solid-test. I guess it's not that common to hide individual faces of a mesh.
                                        • K
                                          kjhunter
                                          Doesn't work. Additionally, documentation is anything but easy step-by-step. Anyway, I got to the point where Extension Warehouse worked. Installed Solid Inspector ok, but nothing showed up in tools. Figured I needed to install the TT_Lib which was also required. I went to do that, and the following came up:
                                          The requested page "/en/content/tt_lib%25C2%25B2" could not be found.
                                          System:
                                          OSX 10.9.2
                                          Again, the documentation of this "Solid Inspector" is REALLY unclear! πŸ‘Ž
                                            It does indeed work fine when installed correctly along with TT_Lib2 as described in the first post of this thread.
                                            What do you mean by "Anyway, I got to the point where Extension Warehouse worked"?
                                            It sounds as if at least you didn't install TT_Lib2 correctly. How did you go about installing it?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
