    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 286.7k Views 110 Watching
    • EdsonE Offline
      Edson
      one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
      regards.
      http://www.mahfuz.arq.br
      • vremennyiV Offline
        vremennyi
        This plugin doesn't work on my laptop.
        After installing it shows, works. But after restarting SU it crashes.
        Stack:
        Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
        Error; #<LoadError; cannot load such file -- Win32API>
        C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
        I'm using Win 8.1 x64.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Edson > It works fine on windows, I'll look into it.
          vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
            jiminy-billy-bob
            Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
              vremennyi
              Yes, latest version 1.0.0.
              Reproduced on other PC. I removed SU2013, cleaned up folders and installed SU2014(Make) and plugin.
              I get this error just opening SU.
              This is really weird: after saving my old 2013 file and relaunch SU - plugin is working.
              Last opened file affects on plugin loading?
              • PixeroP Offline
                Pixero
                Now that its at 1.0 I desided to download it and it looks great.
                One wish though. Thea Render support.
                Oh and is it possible to doubleclick on panel to minimize it? Mine gets stuck as minimized.
                  jiminy-billy-bob
                  Unfortunalty, I can't trigger Thea Render from ruby. Support for this would have to be done in Thea. Tomasz is supposed to be working on this, but it's been a while, maybe you could remind him 😄
                  It seems to be broken, I'm on it.
                  • tt_suT Offline
                    tt_su
                    Loving this update. First public use of the new Layer.color API methods! 😄
                    • Y Offline
                      yinliangxxxx
                      Sketchup2014 Unavailable
                      Thank you Layers Panel
                      Chinese version Sketchup 2014 However, to use this plug-in can not be any!!
                      I hope you can fix
                        jiminy-billy-bob
                        I hope you can fix
                        See above :
                          vremennyi
                          I still have same error. Opening new 2014 file...
                          Your advice was helpful with my PC, but on laptop it does'nt work... I will try reinstall SU.
                            vremennyi
                            After reinstalling SU Make, cleaning directory in %AppData% I have same error...
                              babak
                              First, thank you for the plugin !
                              I have the same issue as vremennyi. Sketchup 2014 pro and windows 7. The plugin works well except when I try to launch sketchup by clicking a file stored on another drive (D:) or network. Then it cannot find winAPI.so.
                              It could explain vremennyi problem on his laptop.
                              • tt_suT Offline
                                tt_su
                                This is a known issue in SketchUp 2014. 😞
                                  jiminy-billy-bob
                                  I spoke to the Trimble guys, and it seems to be an issue with SU2014 itself. In some cases, ruby fails to load properly, when double-clicking on a file.
                                  There's not much I can do... Trimble is working to fix it.
                                  Meanwhile, try to open Sketchup, and then open your files with "Files > Open".
                                  EDIT : Oh well, I'm too slow 😄
                                    jiminy-billy-bob
                                    vremennyi, yinliangxxxx, babak,
                                    Try replacing the file "Plugins/jbb_layers_panel/layers_panel.rb" by the attached one (see below), and tell me if it works.
                                    layers_panel.rb
                                      babak
                                      %(#004080)[jiminy-billy-bob, thank you for your quick answer.
                                      I still get the following error while launching from d:\ or network.]
                                      Erreur de chargement du fichier C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                      Error: #<LoadError: cannot load such file -- dl>
                                      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:in <top (required)>'
                                      C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:in require' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:in rescue in module:JBB_LayersPanel'
                                      C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:28:in <module:JBB_LayersPanel>' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>'
                                      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                      C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in register_extension' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins /jbb_layers_panel.rb:39:in <top (required)>'
                                        jiminy-billy-bob
                                        Well, in that case we just need to wait for trimble to fix this.
                                        • U Offline
                                          unclex
                                          Error Loading File C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                          Error: #<LoadError: cannot load such file -- Win32API>
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in module:JBB_LayersPanel'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>' E:/Trimble/Sketchup.14/Tools/extensions.rb:197:in require'
                                          E:/Trimble/Sketchup.14/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in register_extension'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in `<top (required)>'
                                          it's same problem
                                          su2014en @ win7x64chinese
                                          so I guess, that's something about system, Trimble had better fix it
                                            tony bombata
                                            interestingly, if you pin a file to sketchup 2014, and launch from the taskbar jumplist, it will open without errors - dont know if that helps
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
