    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.7k Views 110 Watching
    • F Offline
      function
      awesome! thanks jiminy-billy-bob
      by "auto-color groups" The idea was that layers could inherit the color of their group folder- this may cause problems with nested folders however
      • EdsonE Offline
        Edson
        jbb,
        I am still experiencing some difficulties on mac: there is always a missing layer comparing to what the native panel shows. until all the layers appear in your Layers Panel all the time it will be difficult to switch definitely to it.
        please, keep up the great work.
        http://www.mahfuz.arq.br
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Even when using the debug dialog?
          Could you send me your file?
          • EdsonE Offline
            Edson
            jbb,
            I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
            now I will be able to switch to LP. great.
              jiminy-billy-bob
              Glad to hear that!
              • EdsonE Offline
                Edson
                one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
                regards.
                • vremennyiV Offline
                  vremennyi
                  This plugin doesn't work on my laptop.
                  After installing it shows, works. But after restarting SU it crashes.
                  Stack:
                  Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                  Error; #<LoadError; cannot load such file -- Win32API>
                  C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
                  I'm using Win 8.1 x64.
                    jiminy-billy-bob
                    Edson > It works fine on windows, I'll look into it.
                    vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
                      jiminy-billy-bob
                      Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
                        vremennyi
                        Yes, latest version 1.0.0.
                        Reproduced on other PC. I removed SU2013, cleaned up folders and installed SU2014(Make) and plugin.
                        I get this error just opening SU.
                        This is really weird: after saving my old 2013 file and relaunch SU - plugin is working.
                        Last opened file affects on plugin loading?
                        • PixeroP Offline
                          Pixero
                          Now that its at 1.0 I desided to download it and it looks great.
                          One wish though. Thea Render support.
                          Oh and is it possible to doubleclick on panel to minimize it? Mine gets stuck as minimized.
                            jiminy-billy-bob
                            Unfortunalty, I can't trigger Thea Render from ruby. Support for this would have to be done in Thea. Tomasz is supposed to be working on this, but it's been a while, maybe you could remind him 😄
                            It seems to be broken, I'm on it.
                            • tt_suT Offline
                              tt_su
                              Loving this update. First public use of the new Layer.color API methods! 😄
                              • Y Offline
                                yinliangxxxx
                                Sketchup2014 Unavailable
                                Thank you Layers Panel
                                Chinese version Sketchup 2014 However, to use this plug-in can not be any!!
                                I hope you can fix
                                  jiminy-billy-bob
                                  I hope you can fix
                                  See above :
                                    vremennyi
                                    I still have same error. Opening new 2014 file...
                                    Your advice was helpful with my PC, but on laptop it does'nt work... I will try reinstall SU.
                                      vremennyi
                                      After reinstalling SU Make, cleaning directory in %AppData% I have same error...
                                        babak
                                        First, thank you for the plugin !
                                        I have the same issue as vremennyi. Sketchup 2014 pro and windows 7. The plugin works well except when I try to launch sketchup by clicking a file stored on another drive (D:) or network. Then it cannot find winAPI.so.
                                        It could explain vremennyi problem on his laptop.
                                        • tt_suT Offline
                                          tt_su
                                          This is a known issue in SketchUp 2014. 😞
                                            jiminy-billy-bob
                                            I spoke to the Trimble guys, and it seems to be an issue with SU2014 itself. In some cases, ruby fails to load properly, when double-clicking on a file.
                                            There's not much I can do... Trimble is working to fix it.
                                            Meanwhile, try to open Sketchup, and then open your files with "Files > Open".
                                            EDIT : Oh well, I'm too slow 😄
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
