    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 317.0k Views 110 Watching
    • EdsonE Offline
      Edson
      @jiminy-billy-bob said:
      @edson said:
      almost all the features work, except the render one. I understand the kettle icons are for one to disable scenes as far as rendering goes. however, nothing happens when I hover the cursor over the kettle icons: there is no indication that I can click on them, as all the others do.
      You mean there is no "hand" icon?
      What happens if you click anyway?
      this is the point: nothing happens!
      two more issues: Layers Panel does not keep the layers in the order I set them originally. why is that? the other is that it does not pick up all my original layers. see the attached image: layers AUX-Pergola and AUX-Pergola 2 are nowhere to be seen, and layer AUX-Pergola 3 is way down below the others with the AUX prefix.
      thanks.
      http://www.mahfuz.arq.br
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        When first opened, Layers Panel sorts the layers in the order they were created. There is no way to recover the order of the layers window.
        As for the missing layers, could you send me the file by PM? (Even with all the geometry deleted if you're not comfortable with that)
        • EdsonE Offline
          Edson
          no problem. I will send you the file right away.
            jiminy-billy-bob
            Thanks, I'll take a look at it.
            • EdsonE Offline
              Edson
              LP has a nice feature that allows one to decide whether it opens when Sketchup starts or not. now, could you include something to tell it to open the main dialog at the same spot it was when Sketchup closed for the last time? right now it opens always on the same place of the screen.
                jiminy-billy-bob
                Oh? On Windows it remembers the position. Anyone else has the same issue?
                  jiminy-billy-bob
                  New version 0.10.2 beta !
                  Changelog :
                  • Better management of multiple models opened on OSX (You need to pan/orbit/zoom to trigger the change)
                  • Added debug dialog
                  • Fixed bug at startup
                  Download in the plugin store !
                  • F Offline
                    function
                    this keeps getting better and better. 😎
                    i had an idea from a screen a few posts up. how about layer colors? and then on top of that, 'auto-color sub-group' this would be a great way to quickly locate layers when you are dealing with quite a few.
                    thanks for the great plug
                      jiminy-billy-bob
                      Unfortunatly, there is no way to retreive or set the layer colors in the current versions of Sketchup. Let's hope Trimble adds it to the API in future versions!
                      Can you explain a bit more your 'auto-color sub-group' idea?
                        jiminy-billy-bob
                        New version 1.0.0 !
                        This is the first "stable" version. The plugin is now out of beta, as all features are now present, and it's running fine on OSX.
                        Changelog :
                        • Added layer colors for SketchUp 2014 (Right-click on a color to change it)
                        • Fixed issue with undo operations
                        http://i.imgur.com/UgA185k.png
                          jiminy-billy-bob
                          It was hard not to tell you this was coming.
                          The feature was ready and just waiting for SU2014 to officialy come out. πŸ˜„
                          Hope you guy will like it. Now Layers Panel has all the features of Su's default layers window.
                          • F Offline
                            function
                            awesome! thanks jiminy-billy-bob
                            by "auto-color groups" The idea was that layers could inherit the color of their group folder- this may cause problems with nested folders however
                            • EdsonE Offline
                              Edson
                              jbb,
                              I am still experiencing some difficulties on mac: there is always a missing layer comparing to what the native panel shows. until all the layers appear in your Layers Panel all the time it will be difficult to switch definitely to it.
                              please, keep up the great work.
                                jiminy-billy-bob
                                Even when using the debug dialog?
                                Could you send me your file?
                                • EdsonE Offline
                                  Edson
                                  jbb,
                                  I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
                                  now I will be able to switch to LP. great.
                                    jiminy-billy-bob
                                    Glad to hear that!
                                    • EdsonE Offline
                                      Edson
                                      one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
                                      regards.
                                      • vremennyiV Offline
                                        vremennyi
                                        This plugin doesn't work on my laptop.
                                        After installing it shows, works. But after restarting SU it crashes.
                                        Stack:
                                        Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                        Error; #<LoadError; cannot load such file -- Win32API>
                                        C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
                                        I'm using Win 8.1 x64.
                                          jiminy-billy-bob
                                          Edson > It works fine on windows, I'll look into it.
                                          vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
                                            jiminy-billy-bob
                                            Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
