    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.8k Views 110 Watching
    • EdsonE Offline
      Edson
      hi jbb,
      it is working on mac os 10.8.5 now.
      almost all the features work, except the render one. I understand the kettle icons are for one to disable scenes as far as rendering goes. however, nothing happens when I hover the cursor over the kettle icons: there is no indication that I can click on them, as all the others do.
      when clicking on the podium icon I got a message that it was not installed but the rendering process started anyway although id did not go through to the end.
      I am sure you will fix those little glitches soon. Layers Panel is already an important part of my workflow. thanks.
      best regards.
      http://www.mahfuz.arq.br
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        You mean there is no "hand" icon?
        What happens if you click anyway?
        • EdsonE Offline
          Edson
          this is the point: nothing happens!
          two more issues: Layers Panel does not keep the layers in the order I set them originally. why is that? the other is that it does not pick up all my original layers. see the attached image: layers AUX-Pergola and AUX-Pergola 2 are nowhere to be seen, and layer AUX-Pergola 3 is way down below the others with the AUX prefix.
          thanks.
            jiminy-billy-bob
            When first opened, Layers Panel sorts the layers in the order they were created. There is no way to recover the order of the layers window.
            As for the missing layers, could you send me the file by PM? (Even with all the geometry deleted if you're not comfortable with that)
            • EdsonE Offline
              Edson
              no problem. I will send you the file right away.
                jiminy-billy-bob
                Thanks, I'll take a look at it.
                • EdsonE Offline
                  Edson
                  LP has a nice feature that allows one to decide whether it opens when Sketchup starts or not. now, could you include something to tell it to open the main dialog at the same spot it was when Sketchup closed for the last time? right now it opens always on the same place of the screen.
                    jiminy-billy-bob
                    Oh? On Windows it remembers the position. Anyone else has the same issue?
                      jiminy-billy-bob
                      New version 0.10.2 beta !
                      Changelog :
                      • Better management of multiple models opened on OSX (You need to pan/orbit/zoom to trigger the change)
                      • Added debug dialog
                      • Fixed bug at startup
                      Download in the plugin store !
                      • F Offline
                        function
                        this keeps getting better and better. 😎
                        i had an idea from a screen a few posts up. how about layer colors? and then on top of that, 'auto-color sub-group' this would be a great way to quickly locate layers when you are dealing with quite a few.
                        thanks for the great plug
                          jiminy-billy-bob
                          Unfortunatly, there is no way to retreive or set the layer colors in the current versions of Sketchup. Let's hope Trimble adds it to the API in future versions!
                          Can you explain a bit more your 'auto-color sub-group' idea?
                            jiminy-billy-bob
                            New version 1.0.0 !
                            This is the first "stable" version. The plugin is now out of beta, as all features are now present, and it's running fine on OSX.
                            Changelog :
                            • Added layer colors for SketchUp 2014 (Right-click on a color to change it)
                            • Fixed issue with undo operations
                            http://i.imgur.com/UgA185k.png
                              jiminy-billy-bob
                              It was hard not to tell you this was coming.
                              The feature was ready and just waiting for SU2014 to officialy come out. 😄
                              Hope you guy will like it. Now Layers Panel has all the features of Su's default layers window.
                              • F Offline
                                function
                                awesome! thanks jiminy-billy-bob
                                by "auto-color groups" The idea was that layers could inherit the color of their group folder- this may cause problems with nested folders however
                                • EdsonE Offline
                                  Edson
                                  jbb,
                                  I am still experiencing some difficulties on mac: there is always a missing layer comparing to what the native panel shows. until all the layers appear in your Layers Panel all the time it will be difficult to switch definitely to it.
                                  please, keep up the great work.
                                    jiminy-billy-bob
                                    Even when using the debug dialog?
                                    Could you send me your file?
                                    • EdsonE Offline
                                      Edson
                                      jbb,
                                      I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
                                      now I will be able to switch to LP. great.
                                        jiminy-billy-bob
                                        Glad to hear that!
                                        • EdsonE Offline
                                          Edson
                                          one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
                                          regards.
                                          • vremennyiV Offline
                                            vremennyi
                                            This plugin doesn't work on my laptop.
                                            After installing it shows, works. But after restarting SU it crashes.
                                            Stack:
                                            Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                            Error; #<LoadError; cannot load such file -- Win32API>
                                            C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
                                            I'm using Win 8.1 x64.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
