[Plugin] Layers Panel 1.2.1
jbb,
I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
now I will be able to switch to LP. great.
Glad to hear that!
one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
regards.
This plugin doesn't work on my laptop.
After installing it shows, works. But after restarting SU it crashes.
Stack:Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb Error; #<LoadError; cannot load such file -- Win32API> C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require' ...I'm using Win 8.1 x64.
Edson > It works fine on windows, I'll look into it.
vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
Yes, latest version 1.0.0.
Reproduced on other PC. I removed SU2013, cleaned up folders and installed SU2014(Make) and plugin.
I get this error just opening SU.This is really weird: after saving my old 2013 file and relaunch SU - plugin is working.
Last opened file affects on plugin loading? -
Now that its at 1.0 I desided to download it and it looks great.
One wish though. Thea Render support.
Oh and is it possible to doubleclick on panel to minimize it? Mine gets stuck as minimized. -
Unfortunalty, I can't trigger Thea Render from ruby. Support for this would have to be done in Thea. Tomasz is supposed to be working on this, but it's been a while, maybe you could remind him
It seems to be broken, I'm on it.
Loving this update. First public use of the new Layer.color API methods!
Thank you Layers Panel
Chinese version Sketchup 2014 However, to use this plug-in can not be any!!
I hope you can fix -
I hope you can fixSee above :
I still have same error. Opening new 2014 file...
Your advice was helpful with my PC, but on laptop it does'nt work... I will try reinstall SU. -
After reinstalling SU Make, cleaning directory in %AppData% I have same error...
First, thank you for the plugin !
I have the same issue as vremennyi. Sketchup 2014 pro and windows 7. The plugin works well except when I try to launch sketchup by clicking a file stored on another drive (D:) or network. Then it cannot find winAPI.so.
It could explain vremennyi problem on his laptop. -
I spoke to the Trimble guys, and it seems to be an issue with SU2014 itself. In some cases, ruby fails to load properly, when double-clicking on a file.
There's not much I can do... Trimble is working to fix it.
Meanwhile, try to open Sketchup, and then open your files with "Files > Open".EDIT : Oh well, I'm too slow
vremennyi, yinliangxxxx, babak,
Try replacing the file"Plugins/jbb_layers_panel/layers_panel.rb"by the attached one (see below), and tell me if it works.
%(#004080)[jiminy-billy-bob, thank you for your quick answer.
I still get the following error while launching from d:\ or network.]Erreur de chargement du fichier C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
Error: #<LoadError: cannot load such file -- dl>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:in<top (required)>'
C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:inrequire' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:inrescue in module:JBB_LayersPanel'
C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:28:in<module:JBB_LayersPanel>' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload'
C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:inregister_extension' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins /jbb_layers_panel.rb:39:in<top (required)>' -
Well, in that case we just need to wait for trimble to fix this.
