    SketchUp 2014
    205 Posts 79 Posters 54.0k Views 79 Watching
    • FrederikF Offline
      Frederik
      @numerobis said:
      And why should DWG export be a problem?
      Limitations in the format... But as I understand it now, the limitations is within SU and not the dwg-format...
      (Great to learn something new... ๐Ÿ˜„ )
      Cheers
      Kim Frederik
      • N Offline
        numerobis
        @frederik said:
        Although my knowledge in this area is somehow limited, I don't know any other 3D app. having real curves, nor do I see the need...
        AutoCAD and Revit doesn't have real curves (as far as I know) and I believe the compatibility with other applications (in particular the option to export to DWG format) also limits the option for this...
        ๐Ÿ˜ฎ
        @jeff hammond said:
        all of the CAD apps use real curves. (autocad, rhino, solidworks, catia, etcetc )
        and i think almost every 3d app too... 3DSmax, Maya, cinema4D, Modo, Softimage, Lightwave, Houdini, Bonzai3D, formZ, Moi3D, NVil...
        • arail1A Offline
          arail1
          @frederik said:
          Thanks, Andy... ๐Ÿ‘
          So... Why is it important to have exact curves...?
          A curve in SketchUp is just a bunch of connected lines - what that means is: there's no center to snap to, no radial dimensions, no tangents, nor any of the other geometrical characteristics of a curve. With true curves any point on a circle or arc will always be exactly the same distance from a center point as any other. Alternately, wherever you snap to on a 'chord' will be a different dimension from a hypothetical center than any other point.
          Why is it important to have exact curves? - because it's the basis for enormous amounts of basic geometry.
          • arail1A Offline
            arail1
            "jbacus via twitter
            When was the last time a feature that made you catch your breath was added to Photoshop? Or Microsoft Word?"
            This comment concerns me as far as future direction is concerned.
            Most of the requests on this forum aren't really about new features - most of them are about adding features that should always have been there.
            My request for true curves is a request for basic geometry that no other application I use functions without. Getting true curves would be like Word getting the ability to capitalize letters - not so much something new and additional, as something that shouldn't have been lacking in the original.
            I don't want SketchUp to become too much more than it is but I do want it to function well within it's own parameters. Having to scale an object up 10 times to be able to zoom close in to it and then scale it back down is kind of ridiculous. But as more work is exporting out of SketchUp to sub d modelers, to nurbs programs or for 3D printing, those little errors are costly. That function wouldn't be a 'new' feature - it would be basic functionality that should already exist in the program.
            • PixeroP Offline
              Pixero
              I had hoped ThomThoms quads would be deeply incorporated in this release. ๐Ÿ˜ข
              Maybe even his Bezier Surfaces.
              Never the less, I got a OK from by Boss to uprade SU because of the BIM classification.
              • FrederikF Offline
                Frederik
                Cheers, Arail11... ๐Ÿ‘
                I understand much better now...
                Although I use SU on a daily basis for the business I work within (mechanical/engineering) I haven't had the need to use exact curves...
                For me SU is a 3D application, where I can visualize how things can be put together...
                For me it's accurate enough, but I can see businesses where exact curves are needed...
                Thanks for enlighten me... ๐Ÿ˜„ ๐Ÿ‘
                Cheers
                Kim Frederik
                • arail1A Offline
                  arail1
                  I'm probably more aware of the issue than you are because I work 'in between' autocad and SU. Consequently I have to jump through several unnecessary hoops multiple times during the day - I make x marks at the centers of circles and arcs in AutoCad because SU wouldn't otherwise be able to find the center, I extend any lines that touch curves in AutoCAD because when I export to SU those lines will be either short of the curve or extend minimally beyond it depending on where on the chord they fall. And then I have to do a lot of cleanup on the SU side. All because of the lack of curves which would seem to me to be on the top of necessary improvements going forward but the Boulder team obviously disagrees.
                  Have a good day.
                    d12dozr
                    Can someone that uses BIM in other apps explain how the new Classify feature will be useful? I've never used BIM, but am curious if this will really be useful or if it's going to go unused (like Dynamic Components) by the majority of users.
                    http://goo.gl/f7ooYh
                      slbaumgartner
                      Have a good day.
                      I understand your need. However, I don't expect to see it implemented in SketchUp any time soon because it would require a fundamental redesign of how SketchUp works.
                      Today there is a 1-1 matchup between how Entities are represented in the model data and how they are drawn on the screen. That is, the internal data representation is all Edges and Faces, and (with some shading and texturing tricks) that is exactly what is drawn on the screen.
                      To get what you desire, they would have to break this 1-1 relationship so that the screen geometrical representation was dynamically calculated from an abstract mathematical geometry representation (e.g. center point and radius) every time the object was displayed. Obviously it's possible to do that, but it isn't how SketchUp was designed. So, a very major redesign and alteration of how SketchUp works would be needed.
                      The simplicity SketchUp gets from its approach is also a reason it is so much less expensive than true CAD programs.
                      Steve
                        Think of the Classifier as a means of writing metadata into your geometry.
                        This metadata is readable in other apps.
                        Its focus is towards users in the Design,Build and Operate arena.
                          Jim
                          One of my first thoughts about Classifier was that it might be useful for SketchyPhysics to classify objects. Right now SP uses a custom AttributeDictionary's to label and track objects in the simulation. It would be useful to use the Classifier to inspect and edit SP types.
                          • arail1A Offline
                            arail1
                            Steve
                            Thanks for taking the time to explain that. A very interesting description and, for a non technical individual like myself, rather easy to grasp. Discouraging though. Obviously I'm happy that SU is so cheap by comparison to other programs and I don't want it to become a feature rich / bloated application. It's simplicity is it's strength. But, curves are such an essential function of so much of what I do that I'm forced out to other software because of the lack of true curves in SU.
                            At least now I'll know to stop asking for and expecting improvement in this area from each new upgrade and then feeling disappointed when it doesn't happen.
                            • jeff hammondJ Offline
                              yeah, it really would.. i know i wrote 'a few modifications' up there but i didn't mean it as if the devs could just add on to the core.. the core/fundamentals would have to change.. it would (probably) need splines and control points in which lines/curves are 'aware' of their whole length instead of each segment being it's own thing.
                              i'd guess many/most su users wouldn't even care about it (and might not even notice) -or- the new behaviors would be unwelcome by a lot of people and the gripes would then be 'just make it how it was before etc.'..
                              probably best to just keep sketchup how it is and the people needing other functionality can get it from other applications.
                                rtd
                                This thread has included a variety of issues and questions, many indirectly relating to the direction that SU is headed.
                                Some of you may have seen this but, for those who haven't, look at the Trimble ad on pg. 8 of the December 2013 issue of "Building Design and Construction". It includes SketchupPro as a companion to their other products, "Proliance", and "Modelogix". Sketchup is described as a collaboration tool, working along with the others to "...track the performance of infrastructure and facilities across your portfolio in order to effectively plan for the future..."
                                This is where it's headed, hence the BIM direction in the current release.
                                  @adamb said:
                                  My 2 cents worth. I'm really impressed with SU 2014.
                                  Seems much more stable than previous versions, obviously significantly faster in dealing with large models than previous version due to the Ruby 2.0 + other engine optimizations. Just better all around in my book.
                                  from what i can tell, i agree that it's much more stable than su8.. based on that alone, i'll be upgrading.
                                  (not saying that's the only thing i like about the update.. i also like the new arc tool)
                                  • F Offline
                                    frv
                                    As I understand there is no such thing as "upgrading" the license to version 2014.
                                    You can buy the new license for a year after which it expires.
                                    I tried to update but was charged 0 and charged for the maintenance program for 73 euro ex. vat per year. That is till March 2015.
                                    Actually, I like this better than pay a full license per user at 500 euro or so and still have to upgrade.
                                    Francois
                                      d12dozr
                                      Thanks Rich and Jim. I guess we'll have to play with it to see how useful it'll really be.
                                      • Chris FullmerC Offline
                                        Francois
                                        Hi Francois, we operate on a subscription now. So you paid 73 euro for the subscription, or "maintenance program". While you are covered by the maintenance, you get all upgrades for free. If we come out with another version before March 2015, you will get a license to it for free. That license and your 2014 license will never expire. Once you receive a license, it does not expire.
                                        I hope that helps clarify things a little.
                                        • utilerU Offline
                                          utiler
                                          Just got back from a few days out of towm; loaded 2014 and get this message:
                                          Any suggestions?
                                          Just Curious...
                                            slbaumgartner
                                            [attachment=0:2yxmu76m]<!-- ia0 -->2014-03-04_0914.png<!-- ia0 -->[/attachment:2yxmu76m]
                                            Any suggestions?
                                            To cite the now all to familiar refrain, where did you get the plugins you installed in 2014? That looks like you have some old code in which somebody worked around the fact that SU didn't include the Ruby standard library prior to 2014. Try purging all plugins and installing fresh copies from EW or SCF plugins store.
                                            Sorry, that's tedious, but since every person's list of plugins is different it is really the only way...
                                            Steve
                                            • 11
                                            • 6 / 11
