    [Plugin] Material Renamer
    29 Posts 12 Posters 35.0k Views 12 Watching
    • bagateloB Offline
      bagatelo
      @tig said:
      ...it would be possible to get the base name for the materials from file skp name automatically?
      Yes, where the earlier code says
      m.name = "mat#{'%03d' % i}"
      change it to read
      m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"
      GREAT!!! Thanks...
      Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
      • shannakaeS Offline
        shannakae
        Not sure this has been brought up in this thread or in another, but I am looking for a way to organize my materials within each project. It would be so great to be able to organize them into folders or some sort of system that lets me group items together... I have a ton of materials in the project i am currently working on and have been trying to keep track of them by renaming them etc... but it becomes very daunting to look through them all. For example I downloaded a sketchup 3d file of books for my bookshelves in a family room I am designing... obviously I don't want to re paint all the books with colors in my model... and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library. It would be so great to create a folder or file system to group all the colors that are in the books together so that I don't get them mixed up with my other materials... needless to say it is a hot mess in my materials library. Please tell me someone has created a cool plugin for this or has a solution for me : ) Or am I missing something very obvious???
        • jolranJ Offline
          jolran
          and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library..
          I hate to ask. You do do know you can purge unused materials ?
          In case not. In the Materialpalette, click the house to get to modelmaterials.
          The icons furthest to the right(blueish) click and choose purge unused.
          Otherwise there is maybe this:
          404 Not Found
          (sketchucation.com)
          or this ?
          404 Not Found
          (sketchucation.com)
          Take care.
            shannakae
            404 Not Found
            (sketchucation.com)
            or this ?
            404 Not Found
            (sketchucation.com)
            Take care.
            Thanks, i will look those up. I do know about purge un-used (but I did just learn about it the other day so you are not so far off 😉 )Thanks! I will look up the two topics and see if there is something there that works for me... I was looking at the open or create a collection section... and was going to explore how that might work for what I am trying to do...
            • bagateloB Offline
              bagatelo
              change it to read
              GREAT!!! Thanks...
              I want to add a shurtcut for this function. Can you make a plugin for me, please? 😳
              • CadFatherC Offline
                CadFather
                def matrename
                Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "- #{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
                if( not file_loaded? "TT_materials_renamer.rb" )
                UI.menu("View").add_item("Materials Rename") { matrename.new }
                file_loaded("TT_materials_renamer.rb")
                • bagateloB Offline
                  bagatelo
                  @cadfather said:
                  > def matrename
                  > end
                  > end
                  Great! Thanks!
                  One thing that would be really interesting would be that this script index materials application in areas with higher per square meter first. Thus, a material that was on all the walls would be in first place. A material that was in small areas (a decorative object for example) would be the end of the numbering.
                  • H Offline
                    harvey1
                    Is it possible for this plugin to allow one to rename individual materials. For example, let's say my model is imported into SU as Material 1, and I'd like to rename it Window, and Material 2 to be renamed Door, etc.
                      Pherim
                      This plugin appears to be buggy for me... it seems to be applied as soon as Sketchup has started, so when I open a file by double-clicking it in explorer, the materials get renamed immediately. The same happens when I activate the plugin via the Sketchucation Plugin Store. Will leave it deactivated until the cause is found...
                      • JBJDesignsJ Offline
                        JBJDesigns
                        Currently, I have this plug-in disabled (i.e., "tt_materials_renamer.rb" to "tt.materials.renamer.rbDISABLE"). Is there a way to turn this option on or off as needed. Many of my projects are uploaded into Vue 10 Esprit for rendering. I've been "building" a database of materials from SU. When the files are automatically renamed to "mat00", "mat01", etc., it's near impossible to determine whether the material has been saved to it's converted ".mat" format. Your help is appreciated. Jo Ann 😄
                        ...you send them to school, you give them books, and they eat the pages...
                          rv1974
                          Beware: It runs silently in background on the file opening! I managed to spoil a couple of files with this one 😳
                          It should be written on the top.
                          • designerbursaD Offline
                            designerbursa
                            Plugin name and menu text
                            PLUGIN_NAME = 'Rename Materials by File Name'.freeze
                            Plugin class
                            class RenameMaterials
                            def self.rename
                            # Get the active model
                            model = Sketchup.active_model
                            # Get the file name and remove the extension
                            file_name = File.basename(model.path, ".*")
                            # Get all materials in the model
                            materials = model.materials
                            # Iterate through all materials and assign new names based on the file name
                            materials.each_with_index do |material, index|
                              new_name = "#{file_name}_#{format('%02d', index + 1)}"
                              material.name = new_name
                            puts "Materials have been successfully renamed based on the file name."
                            Menu item that activates the plugin
                            UI.menu('Plugins').add_item(PLUGIN_NAME) { RenameMaterials.rename }
                            • 2 / 2
