    Getting Started
    75 Posts 45 Posters 190.4k Views 45 Watching
      If it's in the outbox, it is sent but not read yet. If it's under "Sent messages", it has already been delivered and read by the recipient.
      • SimFonIA_teamS Offline
        SimFonIA_team
        Perfect, thank you for your answer Gaieus.
        Give life to your ideas : http://www.simfonia.fr/SAT/
          Jehphg
          Hi guys, my name is Jéssica, i'm a newbie and i am loving the forum already!
            Gundulph1
            Hello everybody - I'm a newbie to the site and (currently) the most casual of casual users. Am intending to change that over the next few years before leaving my current employer to go it alone (small scale infrastructure engineering). I have a feeling I'm going to be asking the assorted wise heads here a lot of questions in the meantime... thanks in advance!
              mehimu
              • V Offline
                vanesscast
                thank you so much for all the helpful tips! it really helps a beginner like me out!
                • picsP Offline
                  pics
                  A newbie question: I never used SU before (2017 make) and I read online somewhere that it's better to start in 2d and get to know the tools. Do you agree that this is a good way to start learning SketchUp? Any suggestions are appreciated. Thanks
                  Dave
                    Dave
                    I wouldn't agree at all. SketchUp is a 3D modeling tool. You should learn it in 3D.
                      jmdiazfranco
                      Hi, I have an question but it seems that I can't write in the forums (yet?). So apologies if I am dumping the question in the wrong place...
                      How can I reduce line width when exporting 2D drawings (.dwg format) from Sketchup to be used in CNC software (specifically in Enroute)?
                      I realized that without controlling the line width, small perforations or arches are heavily segmented which gives problems when loading the files.
                      Hopefully someone can help.
                      Warm regards!
                      Jose
                        Line weight has nothing to do with the segmentation of arcs, circles, and curves. They will always be segmented in SketchUp. If you export the 2D file using the 3D .dwg exporter instead, the acrs, circles, and curves will be smoothed as you want them to be.
                        FWIW, SketchUp doesn't have real line weight control. You can set a thickness for Profile edges but that's not the same. You could change the line weight in LayOut, however.
                          keithver
                          I have just bought 2021 and am trying to load the Sketchucation plugin. I have downloaded it from the site, but when i click on it in my Downloads, it open SKup and gives a message "this does not appear to be a Sketchup model"
                          Where am i going wrong. I remember it being very easy in Ver.18
                          • BoxB Offline
                            From within Sketchup, Go Extensions/Extension Manager/Install Extension navigate to the RBZ file in your Downloads folder and click open.
                            This will install the extension automatically.
                              keithver
                              Fantastic. Thanks very much. I've got it loaded now, along with the rest 😎 😄
                              • N Offline
                                Nalarupa
                                Hi All.
                                I am new to Sketchucation, and I'm trying to purchase SketchCuisine from this platform.
                                Can anyone help me what is "duration" means?
                                Thanks.
                                • 4 / 4
