    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 138.6k Views 58 Watching
      ability to press <return> once your name&password has been typed
      Added to ToDo list
      some sort of feedback upon clicking 'autoinstall' that the plugin is actually downloading.. i.e.- a little spinning wheel pops up somewhere.. or something...
      Added 'or something' to ToDo list
      • BoxB Offline
        It says downloading % in the bottom left corner on mine.
          Jeff means that the PluginStore Dialog box show a loading graphic when you click autoinstall not the status bar in SketchUp.
          In sme instance the download can be so fast that the need for a spinner would be pointless. But I do know on some plugin the few secs to mins needs to be indicated.
          • jeff hammondJ Offline
            oh.. then i change my suggestion.. make that โ†‘ work on mac.
            it's not a big deal for the tiny .rb files as the 'auto-installed' dialog pops up quickly.. with the larger sized plugins though and no feedback, there's enough time in between clicking the install button and the installed message for doubt to kick in on whether or not i clicked the button properly
            [EDIT]
            yes, exactly ๐Ÿ‘
              @Jeff
              You can see in the My Setup bulk updater we display 'Loading' when you are installing multiple updates.
              In the next release we will expand this to all installs so there is visual indicators of 'sumthin' happening.
              You going to Basecamp Jeff?
                i haven't planned on it.. i'm going to make it one of these years mainly so i can have a few drinks with you all
                  pgarmyn
                  It would be great to extend this plugin with jiminy-billy-bob's statistcs, to have statistics on all plugins
                  http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=56056%26amp;p=508939#p508939
                    richyrich33
                    HI there,
                    Before I install I was just wondering if I can designate the plugin folder/ folders that SketchUcation Tools corresponds to? Currently I have my plugins in a dropbox folder that I link to from all of my computers using the additional folders plugin, thus keeping my plugins consistent across all machines.
                    Cheers
                      ... Before I install I was just wondering if I can designate the plugin folder/ folders that SketchUcation Tools corresponds to? Currently I have my plugins in a dropbox folder that I link to from all of my computers using the additional folders plugin, thus keeping my plugins consistent across all machines. ...
                      The default Plugins folder path is hard-coded into SketchUp - however, if you install Fredo's Additional Plugins Folder tool you can easily set up your own custom plugins folders.
                      http://sketchucation.com/pluginstore?pln=000_AdditionalPluginFolders
                      Unfortunately a custom-folder path will NOT be recognized by the native RBZ Installer button under Preferences > Extensions, BUT if you use the SketchUcation PluginStore dialog to AutoInstall from within SketchUp itself, then it should spot the additional folder in the $LOAD_PATH and offers that as an alternative destination for the plugin's installation.
                      You can also use the SketchUcation menu item '...Installer' which lets you install downloaded RBZ andZIP archives, and it again spots if there is an additional custom-folder in the $LOAD_PATH and offers that as an alternative destination for the plugin's installation...
                      ๐Ÿค“
                        richyrich33
                        Awesome thanks for the clarification TIG. Just looking into the auto update function in the sketchucation tools is there a way to make it detect existing plugins to see whether they are up-to-date too?
                          To get the full benefit of the plugin it is best to start fresh and install all your plugins through the store again.
                          This primes your data for future updates to those plugins. Historically we can't tell what you did before the SketchUcation Tools install.
                            richyrich33
                            Yeah that is a good idea as it would possibly explain why my sketchup is now crashing on startup after installing skechucation tools. Old rbs never updated, conflicting, time for a cleanup ๐Ÿ˜‰
                            • HieruH Offline
                              Hieru
                              Can someone tell me what files are safe to delete if I want to reinstall the store plugin? Since installing the last update I haven't been able install any plugins using the app.
                              www.davidhier.co.uk
                                There's a loader .rb and a Sketchucation folder
                                • HieruH Offline
                                  Hieru
                                  Thanks Rich - much appreciated. Just wanted to make sure there wasn't anything else I needed to purge.
                                  Unfortunately, after reinstalling I'm still getting the same error when clicking on the red Plugin Manager tab:
                                  Any ideas?
                                  www.davidhier.co.uk
                                    Gรกbor
                                    Hieru: http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
                                    • HieruH Offline
                                      Hieru
                                      Worked a treat - thanks Gabor!
                                      www.davidhier.co.uk
                                        Back to biznazz?
                                          Gรกbor
                                          ๐Ÿ‘
                                          • HieruH Offline
                                            Hieru
                                            @rich o brien said:
                                            Back to biznazz?
                                            Yup! ๐Ÿ‘ I probably should have better things to do on a Sunday, but you know how it is when you get an idea in your head that you can't shake.
                                            www.davidhier.co.uk
                                            • 11
                                            • 3 / 11
