    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 152.1k Views 58 Watching
    • HieruH
      Hieru
      Worked a treat - thanks Gabor!
      www.davidhier.co.uk
        Back to biznazz?
        • G
          Gábor
          • HieruH
            Hieru
            @rich o brien said:
            Back to biznazz?
            Yup! 👍 I probably should have better things to do on a Sunday, but you know how it is when you get an idea in your head that you can't shake.
            www.davidhier.co.uk
              sandysaltus
              I have just been trying to download the SketchUcation Tool and all I get is a page of code. Nothing downloads to my computer. Windows 7
              I am a new Premium member of SkethUcation. I am trying to install and use the Follow Me Helix plugin. I have downloaded the file for this plugin.
              Can you help?
              Sandy Saltus
              saltussand@aol.com
                Hi Sandy,
                When you go here...
                404 Not Found
                (sketchucation.com)
                ...and click Download Now does your browser download SketchUcationTools.rbz to your downloads folder?
                • E
                  expresso405
                  hi all
                  I've loaded this and the "box" appears but no content gets shown within the box...
                  Any suggestions what I'm doing wrong?
                  thanks
                  • K
                    KB
                    Hello, I just installed Sketchucation tools Plug In. When I try to have access to the Plug In Manager this windos appears: No Security Permission to Manage ANY Plugins Folder in the $LOAD PATH.
                    FULL Read/Write Permissions are needed to Manage Plugins within PLugins Folders...
                    As you see I am a novice ....
                    Could you give a clue of what to do?
                    Thank you
                    Katerine
                    • BoxB
                      With the arrival of SU2014 it would be really handy if the My Downloads section had the auto install button. It would be much easier to scroll through that and add the ones you know you want, rather than find them then go to the main page again to install them.
                      I'm probably jumping the gun and you are about to release a new version that lets you synchronize your setup.
                      • cottyC
                        cotty
                        You can find a detailed solution here.
                        my SketchUp gallery
                        • K
                          KB
                          As I see I am not the first one to went trough the game of Security and Permissions.
                          Thanks a lot to all of you.
                          Katerine
                            With v2014 the newly located Plugins folder automatically has FULL permissions so at last this issue should be behind us 😒
                            Except the same still potentially applies to the shipped folders for Materials/Components/Styles - although of course you can have extra folders linked to anywhere you choose...
                            • P
                              pomelo3d
                              Hello. Two suggestions for the next version.
                              It is possible add an option to delete a plugin?
                              It is possible add a link to open the folder where all the plugin?
                              thanks
                              • BoxB
                                The tool has an uninstaller, it's not a toolbar item but you will find it in the Sketchucation plugin submenu.
                                • PixeroP
                                  Pixero
                                  A way of not having to click on three confirmation boxes for each installed plugin would be great.
                                    What version of the the plugin and SketchUp are u using Jan?
                                    • PixeroP
                                      Pixero
                                      v2.5 with SU 8 on Windows 7 at the moment.
                                        You should see an improvement on less clicks on more modern versions of SketchUp.
                                        It is especially sweet on v2014 because of the plugin folder relocation.
                                        If you use Fredo's Additional Folders though you still get prompts. But the default installs are single click conformations.
                                          In more detail...
                                          The number of dialogs/clicks needed is a direct result of the SketchUp version.
                                          In v8:
                                          If it's the first time you've used the PluginStore's AutoInstall that session...
                                          There's a 'click to confirm installation' dialog [SCF initiated but it's built-in to SketchUp], as the destination folder's 'installable'/'writable' properties are checked.
                                          Then a 'click to confirm installation' dialog [unavoidable - it's built-into SketchUp].
                                          On subsequent usage during that session, there should just be the one 'click to confirm installation' dialog for each AutoInstall [unavoidable - it's built-into SketchUp]
                                          Final closing SCF dialog to tell you it was successful.
                                          This on PC [and probably MAC - but untested...].
                                          In v2013:
                                          If it's the first time you've used the PluginStore's AutoInstall that session - there's a 'click to confirm installation' dialog [unavoidable - built-into SketchUp].
                                          Otherwise, for subsequent installations there is no confirmation dialog [unavoidable - it's built-in to SketchUp].
                                          This on MAC/PC.
                                          In v2014:
                                          There is NO 'click to confirm installation' dialog built-into this SketchUp version.
                                          This on MAC/PC.
                                          For the 'Update All' option you should get the initial 'confirmation click(s)' [if any] and a 'final closing dialog' for ALL Plugins, not for their individual AutoInstallations.
                                          If you have more than one Plugins folder defined in SketchUp's $LOAD_PATH then you WILL also get a dialog asking you to choose the destination folder for the Plugin's AutoInstallation, either before the 'confirmation click(s)' [if any], or simply before the 'final closing dialog' if you have v2014...
                                          • T
                                            tomot
                                            Where do I find out more about the location of the new v2014 plugins folder?
                                            It seems to me there were more important items on various SU wish lists, over the years. I don't ever recall seeing move the Plugins folder, on such a list. 😢
                                            my plugins
                                            tomot
                                            • 11
                                            • 3 / 11
