    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 152.1k Views 58 Watching
    • G
      Gábor
      Hi Ken,
      In the future releases we plan to implement such a feature you're looking for. Until then in the "My Downloads" list you can see those plugins what you've ever downloaded from the pluginstore on any computer. At the moment no feature to port the "My installs" but it is on our "To Do List".
        Yes 😄
        A future version might well have a new 'My Syncs' tab - where you will be able to see what plugins you have installed on your current computer/SketchUp-version, AND also those extra ones on other computers/SketchUp-versions [provided you have accessed the PluginStore at least once from these alternative computers/SketchUp-versions], and then it'll offer you the chance to AutoInstall the missing ones - either clicked individually or in bulk [like the 'Update all' button in 'My Updates']...
        We are [hopefully] anticipating your needs/desires, and much of the needed codes is already available.
        We just need to assemble it and beta test etc...
        However, please do make suggestions for enhancements - there's always going to be something we haven't thought of 😉
          ArCAD-UK
          This is a great addition to SU and it keeps getting better. Love the updating notification, just updated four plugins that I didn't realise had been modified!
          I hope I've not missed the memo; installation of plugins is so simple, is there an easy way to uninstall unwanted plugins?
            There's a Plugins > SketchUcation item 'SketchUcation Plugins Uninstaller..'
            That opens a dialog similar to the Plugins Manager.
            It lets you Uninstall selected Plugins - the rb/rbs/rb!/rbs! files are renamed with a final x - rbx.rbsx/rb!x/rbs!x
            They do not then appear in the 'Plugins Manager' or 'My Installs' lists.
            You can Reinstall any 'x' plugins using the same dialog too.
            If you want to permanently remove these Uninstalled files from your system you'll need to do it manually - open your Plugins folder, filter by the final 'x', select them and 'delete'.
            The associated subfolder [if any] is usually named after the plugin file itself and so it can therefore be removed manually too, at the same time; although leaving it in the Plugins folder does no harm...
            • goatboyG
              goatboy
              I get these two...
              Error - Start up.pdf
              One at start up, the second when I click on the Plug ins manager button.
              Error - Plug Ins Manager.pdf
              Also: I use multiple monitors, and the new tool bars and menus show up frequently on one of the other screens...am I the only one?
              • Bob JamesB
                Bob James
                I had not realized this was available 😲 😳
                Very handy. 👍
                Seems like this should also be in SketchUcation Plugins Store in the "My Setup" 😎
                  @goatboy...
                  It's a Plugins folder limited Security permissions problem...
                  Please read this which explains how to fix it...
                  http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
                  • BoxB
                    Tig could you put that permissions business together as a sticky so you don't have to write it again and we can just link to it.
                      @Box
                      I keep meaning to...
                      I will ! 😕
                      [mod=:o474z5tl]I have !
                      ...[/mod:o474z5tl]
                      • jeff hammondJ
                        2 little UI(?) suggestions
                        • when logging in, the ability to press <return> once your name&password has been typed instead of needing to mouseclick on the login button
                        • some sort of feedback upon clicking 'autoinstall' that the plugin is actually downloading.. i.e.- a little spinning wheel pops up somewhere.. or something.. similar to downloading via a browser as each app has some sort of user feedback that a page is loading or a file is downloading.
                          mptak
                          I'm not sure if this is the right place to post but here goes. First off as usual I am truly in awe of the great work of both the Trimble Team and all of the developers contributing at SUcation. Here's my quandary. Sketchup 2013-Make is installed on 2000 laptops at my kid's high school (why not Pro is another story). However, admin permissions are required when trying to add even the most basic of plugins/tools. Any suggestions/ideas if this Sketchucation Tools 2.5 can get around this bureaucratic virtual wall.
                            Added to ToDo list
                            some sort of feedback upon clicking 'autoinstall' that the plugin is actually downloading.. i.e.- a little spinning wheel pops up somewhere.. or something...
                            Added 'or something' to ToDo list
                            • BoxB
                              It says downloading % in the bottom left corner on mine.
                                Jeff means that the PluginStore Dialog box show a loading graphic when you click autoinstall not the status bar in SketchUp.
                                In sme instance the download can be so fast that the need for a spinner would be pointless. But I do know on some plugin the few secs to mins needs to be indicated.
                                • jeff hammondJ
                                  oh.. then i change my suggestion.. make that ↑ work on mac.
                                  it's not a big deal for the tiny .rb files as the 'auto-installed' dialog pops up quickly.. with the larger sized plugins though and no feedback, there's enough time in between clicking the install button and the installed message for doubt to kick in on whether or not i clicked the button properly
                                  [EDIT]
                                  yes, exactly 👍
                                    @Jeff
                                    You can see in the My Setup bulk updater we display 'Loading' when you are installing multiple updates.
                                    In the next release we will expand this to all installs so there is visual indicators of 'sumthin' happening.
                                    You going to Basecamp Jeff?
                                    • jeff hammondJ
                                      i haven't planned on it.. i'm going to make it one of these years mainly so i can have a few drinks with you all
                                      • P
                                        pgarmyn
                                        It would be great to extend this plugin with jiminy-billy-bob's statistcs, to have statistics on all plugins
                                        404 Not Found
                                        (sketchucation.com)
                                          richyrich33
                                          HI there,
                                          Before I install I was just wondering if I can designate the plugin folder/ folders that SketchUcation Tools corresponds to? Currently I have my plugins in a dropbox folder that I link to from all of my computers using the additional folders plugin, thus keeping my plugins consistent across all machines.
                                          Cheers
                                            ... Before I install I was just wondering if I can designate the plugin folder/ folders that SketchUcation Tools corresponds to? Currently I have my plugins in a dropbox folder that I link to from all of my computers using the additional folders plugin, thus keeping my plugins consistent across all machines. ...
                                            The default Plugins folder path is hard-coded into SketchUp - however, if you install Fredo's Additional Plugins Folder tool you can easily set up your own custom plugins folders.
                                            http://sketchucation.com/pluginstore?pln=000_AdditionalPluginFolders
                                            Unfortunately a custom-folder path will NOT be recognized by the native RBZ Installer button under Preferences > Extensions, BUT if you use the SketchUcation PluginStore dialog to AutoInstall from within SketchUp itself, then it should spot the additional folder in the $LOAD_PATH and offers that as an alternative destination for the plugin's installation.
                                            You can also use the SketchUcation menu item '...Installer' which lets you install downloaded RBZ andZIP archives, and it again spots if there is an additional custom-folder in the $LOAD_PATH and offers that as an alternative destination for the plugin's installation...
                                            • 11
                                            • 2 / 11
