    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.9k Views 109 Watching
    • Rich O BrienR Online
      I never knew this tread had added a poll?
      Nice to see Thea getting some attention
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Yeah it's been some time now πŸ˜„
          jiminy-billy-bob
          New version 0.9.1 beta !
          Changelog :
          • Fixed options dialog on OSX
          • Disabled automatic display of floating toolbar on OSX
          • Fixed "Add layer hidden on new pages"
          • Fixed clash with RichSections plugin
          • Several bug fixes
          Download in the plugin store !
            paolo01
            Just installed and the plugin is very useful, to keep layers in order. It is really excellent! Thank you!
            If I can suggest a new function, it might be useful to have the possibility to duplicate the position of a single layer in different groups. For instance, in a building with many stores, I could have the layer "external walls store2" within the group "store2", but also within the group "external walls", containing all the external walls of any store .
            I think it could be possible to reach a similar result using layers and outliner together, but using a single panel would make the function of visibility much simpler.
            Thank you again and good job!
            Paolo
              jiminy-billy-bob
              I think it would be rather confusing to have duplicates of the same layer. I've never seen such thing in any software, and I think there is a reason for that.
              Although, I was considering adding a function similar to layer compositions in Photoshop.
              • wind-borneW Offline
                wind-borne
                Changelog :
                Thanks for saving me the trouble to deal with toolbar with each update. πŸ˜„
                Options dialog still dysfunctional on my OSX,
                reverts to this setup regardless of my choices
                "To read between the lines was easier than to follow the text."OSX 10.11.6
                %(#BF80BF)[SU 8 pro
                  jiminy-billy-bob
                  So you confirm you're running SU8 pro on OSX 10.9.1 ?
                  Do you see the effects of changing these options ? (Like if you uncheck "Display render toolbar")
                    rafaelparedes
                    no add a layer only visible in the current scene 😞?
                      wind-borne
                      Yes, using 10.9.1 and SU pro and tested on SU 2013, no combination of check/uncheck of boxes has any effect and reopening options displays as shown above every time.
                      Duh moment when I read warning sign when merging layers and saw I could disable elsewhere. My style of modeling doesn't bring forth that warning on its own and didn't understand why the plugin was until I watched SU's Layers window while merging layers. The warning sign was what I wanted to eliminate and now I know how.
                      %(#BF80BF)[SU 8 pro
                        jiminy-billy-bob
                        What I mean is, does it hide the render toolbar ? (In the main dialog)
                        I want to know if the changes are applied, apart from the options dialog being broken.
                        Warning when merging layers ? There is none in LP. I d'ont get what you're talking about.
                        Maybe the warning when drawing geometry on another layer than layer0 ?
                          wind-borne
                          Vid showing your Layers Panel rebuilding and second part shows (control-E)merge layers moving active layer(shown in SU layer window) and tripping warning sign.
                          Unticking the warning box yields same results though not shown in vid.
                          %(#BF80BF)[SU 8 pro
                            jiminy-billy-bob
                            Thanks for the video! very usefull πŸ˜‰
                            There is clearly some issue with storing user preferences. I'll look into it.
                            As for the warning, it seems you have this plugin installed. It is the one displaying this warning.
                              jiminy-billy-bob
                              When you choose another render engine in the list, does your change stay after reopening the dialog? Or does it revert back to Vray? (Which is default)
                                wind-borne
                                Those are not dependent on the OK button. They hold across sessions, in the vid you can see indigo>vray>indigo as I slowed that transition way down...
                                %(#BF80BF)[SU 8 pro
                                  jiminy-billy-bob
                                  Right. So this is not related to storing user preference, the issue comes from the options dialog itself.
                                  • Bob JamesB Offline
                                    Bob James
                                    Still having some problems:
                                    After working with a new model for a while I start getting this error.
                                      jiminy-billy-bob
                                      Only one file?
                                        Bob James
                                        Only one file?
                                        No. Several.
                                          jiminy-billy-bob
                                          But not all of them?
                                          Could you send me one of these files?
                                          • H Offline
                                            hesheit1028
                                            OS X– Mac 10.9.1
                                            Sketch Up pro 2013 – ver. 13.0.3688
                                            I am currently having some problems with the layer panel when ever I try to switch from one sketch up project to another.
                                            All layers are gone when ever I switch from project to another and I could never get it back until I restart my Sketch Up.
                                            Please Help.
                                            Marris.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 32 / 34
