    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • wind-borneW Offline
      wind-borne
      @jiminy-billy-bob said:
      New version 0.9.1 beta !
      Changelog :
      • Fixed options dialog on OSX
      • Disabled automatic display of floating toolbar on OSX
      Thanks for saving me the trouble to deal with toolbar with each update. πŸ˜„
      Options dialog still dysfunctional on my OSX,
      reverts to this setup regardless of my choices
      "To read between the lines was easier than to follow the text."OSX 10.11.6
      %(#BF80BF)[SU 8 pro
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        So you confirm you're running SU8 pro on OSX 10.9.1 ?
        Do you see the effects of changing these options ? (Like if you uncheck "Display render toolbar")
          rafaelparedes
          no add a layer only visible in the current scene 😞?
            wind-borne
            Yes, using 10.9.1 and SU pro and tested on SU 2013, no combination of check/uncheck of boxes has any effect and reopening options displays as shown above every time.
            Duh moment when I read warning sign when merging layers and saw I could disable elsewhere. My style of modeling doesn't bring forth that warning on its own and didn't understand why the plugin was until I watched SU's Layers window while merging layers. The warning sign was what I wanted to eliminate and now I know how.
            %(#BF80BF)[SU 8 pro
              jiminy-billy-bob
              What I mean is, does it hide the render toolbar ? (In the main dialog)
              I want to know if the changes are applied, apart from the options dialog being broken.
              Warning when merging layers ? There is none in LP. I d'ont get what you're talking about.
              Maybe the warning when drawing geometry on another layer than layer0 ?
                wind-borne
                Vid showing your Layers Panel rebuilding and second part shows (control-E)merge layers moving active layer(shown in SU layer window) and tripping warning sign.
                Unticking the warning box yields same results though not shown in vid.
                %(#BF80BF)[SU 8 pro
                  jiminy-billy-bob
                  Thanks for the video! very usefull πŸ˜‰
                  There is clearly some issue with storing user preferences. I'll look into it.
                  As for the warning, it seems you have this plugin installed. It is the one displaying this warning.
                    jiminy-billy-bob
                    When you choose another render engine in the list, does your change stay after reopening the dialog? Or does it revert back to Vray? (Which is default)
                      wind-borne
                      Those are not dependent on the OK button. They hold across sessions, in the vid you can see indigo>vray>indigo as I slowed that transition way down...
                      %(#BF80BF)[SU 8 pro
                        jiminy-billy-bob
                        Right. So this is not related to storing user preference, the issue comes from the options dialog itself.
                        • Bob JamesB Offline
                          Bob James
                          Still having some problems:
                          After working with a new model for a while I start getting this error.
                            jiminy-billy-bob
                            Only one file?
                              Bob James
                              Only one file?
                              No. Several.
                                jiminy-billy-bob
                                But not all of them?
                                Could you send me one of these files?
                                • H Offline
                                  hesheit1028
                                  OS X– Mac 10.9.1
                                  Sketch Up pro 2013 – ver. 13.0.3688
                                  I am currently having some problems with the layer panel when ever I try to switch from one sketch up project to another.
                                  All layers are gone when ever I switch from project to another and I could never get it back until I restart my Sketch Up.
                                  Please Help.
                                  Marris.
                                    jiminy-billy-bob
                                    Noted, thanks.
                                    • V Offline
                                      vmcs
                                      Hello,
                                      LP 0.9 beta, SketchUp 8.0.4811, Windows7
                                      I found a problem with unicode in the layer's name. When I use russian characters for the layer name, they replaced by the question signs. At the same time, russian text for group name showed correctly.
                                      With best regards,
                                      Victor
                                        jiminy-billy-bob
                                        Can you copy/paste here the problematic characters? Thanks
                                          gbterstal
                                          This plugin is something I have been waiting for...! I used layers and not Outliner and the ability to group layers for different designs on the same model is just fantastic.
                                          Well done...!!!!!
                                            jiminy-billy-bob
                                            Thanks man πŸ˜‰
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
