    [Plugin] SketchUV - now free
    176 Posts 62 Posters 148.4k Views 62 Watching
    • W Offline
      Whaat
      @smicha said:
      @whaat said:
      Price drop - now just $5. Get it here:
      http://www.smustard.com/script/SketchUV
      Do you plan to add the function to normalize different sizes of textures - I asked about it in previous posts?
      Yes, but I can't give you any accurate estimate of when that would be. It could be anywhere from two months to several years away.
        stpauljason
        I just bought the plugin, and am very happy with it. I read the user manual as well, and have a question using the path select tool. Is it possible to weld a piece back after it has been cut, like in most UV mapping software. I sometimes accidentally double click on the wrong line, and I hate to have to start the whole line cut again on a large model.
        I tried holding the Alt, Shift, and Ctrl Keys separately hoping they would activate the opposite of cut, but they did not.
        Jason
        • W Offline
          Whaat
          Jason
          Hi Jason,
          If I understand you correctly, all you have to do is select the edges you want to 'weld' and then right-click on them and select 'soften'. You can also use the soften edges dialog in SketchUp by going to Window->Soften Edges
          When you 'cut' all you are doing is unsoftening the edge.
          Hope this helps.
            Pherim
            This completes my Sketchup. Have not tried every function but it seems the cylindrical mapping is exactly what I was looking for! Thank you so much this is worth paying for!
            • ely862meE Offline
              ely862me
              Hi, Dale
              I am using SketchUV mostly for it's selecting features, and I was wondering if you could add a new function to the Path Select Tool. What I need and I think it would be welcome is to be able to select more than one path by pressing the CTRL key as in the native Select tool.
              For example I have two exploded circles(or two random contours) and I want to connect those, I use the Path select on one contour, then I press CTRL key and select the next one, then I use Curviloft and "Voila!".
              In the actual case we are not able to select more than one path.Or there is a way that I am not aware of ?
              Thanks !
              Elisei (sketchupper)
              Come and See EliseiDesign
              • W Offline
                Whaat
                @ely862me said:
                Hi, Dale
                Thanks !
                Maybe if you weld the paths with the Weld plugin, you might be able to do this. I have not used Curviloft so I am not sure...
                Someday, I would like to release the Path Select Tool as a standalone plugin. Maybe then, I could add that feature, too.
                Thanks.
                • ely862meE Offline
                  ely862me
                  I am sorry I have not explained myself better .
                  By connecting the paths I meant to create a surface between them.
                  The impediment is that after you select one path you can't select another one. In this case I select one path with the Path Select tool then I hold CTRL and take the Select tool from Sketchup and select the segments one by one(which is very hard and time consuming).
                  Long story short : Take Path Select Tool and select a path then hold CTRL and select as many paths as you want !(This is what I think it will be very useful!)
                  Thank you!
                  • charly2008C Offline
                    charly2008
                    Hello,
                    Is there a way to correct the distortion shown below tool with a UV tool or is the error in the map projection?
                    Thanks for any help.
                    Untitled.skp
                    • FrederikF Offline
                      Frederik
                      It looks like it's the map, which isn't good enough... 😐
                      Here's my attempt with a map from JHT's Planetary Pixel Emporium...
                      Earth-model.skp
                      Cheers
                      Kim Frederik
                        charly2008
                        Hi Kim,
                        thank you for your help and your effort. Also thanks for this link.
                        Charly
                        • SwissmountainS Offline
                          Swissmountain
                          Hello and thank you for this much needed plugin.
                          I am rendering in Modo and need to export my models.
                          I notice that each polygon gets assigned its own material, creating hundreds of materials and making the export near impossible.
                          Is this how the plugin is intended to work?
                          Cogito ergo dum-di-dum
                          • W Offline
                            Whaat
                            Sorry for the late reply.
                            You need to use the Triangulate feature in SketchUV prior to exporting in order to reduce the number of exported materials. This is explained in the SketchUV tutorials.
                            Dale
                            • cottyC Offline
                              cotty
                              Does anyone have problems with this plugin and SU14?
                              my SketchUp gallery
                              • E Offline
                                Extractor
                                Yes, for example errors in the Ruby Console when using a spherical map. I wrote an e-mail to D. Martens and he replied that there will be an update in a few weeks.
                                • soloS Offline
                                  Me, I was looking for an updated version.
                                  I need this tool to work with SU 2014
                                  • cottyC Offline
                                    cotty
                                    As Extractor wrote a solution seems to be on the way...
                                    my SketchUp gallery
                                    • W Offline
                                      Whaat
                                      Updated version available on Extension Warehouse.
                                      SketchUp Extension Warehouse
                                      Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                      (extensions.sketchup.com)
                                      • soloS Offline
                                        • cottyC Offline
                                          cotty
                                          my SketchUp gallery
                                          • FrederikF Offline
                                            Frederik
                                            Respect, Dale...
                                            Cheers
                                            Kim Frederik
                                            • 3 / 9
