    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.7k Views 144 Watching
    • cottyC
      cotty
      @charly2008 said:
      Dear Fredo,
      After the installation, now get this error message. After I've seen in the plugins directory I am now very confused. I do not know what I must do. I also tried the Fredo6_ LibFredo6 - v5.4a - 13.rbz November 7 to install but without success.
      You should delete the Libfredo files and folders which do not begin with Fredo6_...
      my SketchUp gallery
      • charly2008C
        charly2008
        Thanks Tig, thanks Cotty,
        the deletion of the mentioned files solved the Problem.
        Charly
        • guanjinG
          guanjin
            davecoopstl
            Good news, Fredo! I upgraded to your latest version (with Altitude Editor), and all seems to be fixed. I do not have the Cleansing bug when I start the script.
            The Altitude Editor is a BRILLIANT edition.
            Thanks for all the amazing work!
            Dave.
            • OxerO
              Oxer
              Thanks Fredo for this useful plugin!! 👍
              I have created the Spanish (Spain) Language File for TopoShaper v1.1a
              Spanish Language (Spain) TopoShaper v1.1a
                miikka1978
                In quite many cases I end up tracing all the contours from layout. Because of complexity and visibility I have to put all the individual contours into the layers based on their altitude (60m altitude => Layer:60).
                Would it be possible to include option in TopoShaper to read/create contour altitude from layer information in future? Anyway, I am not sure how many people actually trace the contours when creating terrain in their modeling, so I don't know if this functionality would be beneficial for greater audience.
                • edenuxE
                  edenux
                  I am so glad I found this. Thank you so much, you are amazing!
                  Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
                  • G
                    Gmansu8
                    Folks:
                    I've installed Fredo6's fabulous TopoShaper. However, the menu bar that pops up (across the top of my computer screen) doesn't seem to "size" properly. The text is too large for the menu rectangles that should restrain them. I've tried changing font sizes for the operating system (Win7), but the issue (too large text) persists.
                    Anyone have a solution?
                    Thanks to All.
                    • G
                      Gmansu8
                      Okay, I think I've resolved my problem. Win7 has a font multiplier (125%, 150%) above normal (100%). It seems only normal sizing (100%) functions properly with the TopoShaper operation menu.
                      If Fredo6 could find a way to make the TopoShaper operations menu size itself dynamically that would help those of us with suboptimal vision.
                      Hey, it's Christmas! I can ask, right?
                      Fredo, you're a Rock Star (...ends cadence on power chord "A").
                      • fredo6F
                        You are right. It's Christmas and the impossible can be ordered, with probable delivery for the next one 😄
                        Actually, the Ruby API completely lacks control about text display (size, color, fonts, ....) and this is something that would be welcome. For info, the hottest issue today is on Mac with Retina screens.
                        • pbacotP
                          Yes some rubies are unusable with a retina screen.
                          Actually SU is not that great on it either. It looks nice, but the lines are very thin and one sometimes cannot easily see what lines and faces are selected.
                          • bobpineoB
                            bobpineo
                            Fredo,
                            first of all thank you again for your most excellent Plugin.
                            I have a question, how do you suggest modeling contours around a retaining wall?
                            I have been testing a variety of options, but can't quite get a clean surface that would approximate this detail.
                            There would be a lot of clean up to get the surface correct, and I was hoping you could comment on a work around...
                            Or dare I say it, and added function to the plugin..?
                            Not sure even how to explain it, (let alone figure out how to go about adding this function)...but could it be possible to designate areas that are to remain flat?
                            For example a surface at the top of a retaining wall.
                            Thank you in advance TIG, and I am dropping by your donation tab to give you a much appreciated thank you!
                            Best.
                            BP
                            Plan view of topographic lines around a retaining wall
                            Perspective view
                            Result after running toposhaper
                            Deviation of mesh from contour
                            Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                            • I
                              ivreich
                              Hi Fredo
                              I'm having problems running your latest version of Topo Shaper. Everything works fine up until I hit "generate terrain" at the last step, then the model goes crazy and i end up with a bunch of unexpected geometry (guide lines, blank rectangle face)
                              No error warnings in the ruby console either...
                              I've attached the SU 2013 file, could you help me have a look?
                              Joel
                              SU 2013 File with contours
                              Preview Mode works fine...
                              Unexpected end-results...
                              • fredo6F
                                @ivreich said:
                                Hi Fredo
                                Joel
                                I tried, with SU13 (since your model is SU13) and get a correct result with a 50x and 100x grid. However, I noticed a small problem (which requires a model fix), most probably in a small triangle of the skirt.
                                Ivreich_Topo.skp
                                Could you send the bad-generation file.
                                • fredo6F
                                  @bobpineo said:
                                  Fredo,
                                  Unfortunately, cliff cannot be handled in the current version of Toposhaper, because it is based on a Grid concept where each point of the grid corresponds to one altitude.
                                  Currently, you have to post-process the shape by cutting the wall manually.
                                  • I
                                    ivreich
                                    Hi Fredo
                                    File with bad results attached...
                                    Thanks again!
                                    J
                                    bad results
                                    • bobpineoB
                                      bobpineo
                                      @fredo6 said:
                                      @bobpineo said:
                                      Fredo,
                                      Thank you Fredo, How hard is that to incorporate into the plugin, its is christmas pretty soon after all!
                                      thanks Again.
                                      BP
                                      • fredo6F
                                        thanks Again.
                                        BP
                                        Before Christmas, you may use the Sandbox stamp and then JointPushPull to extrude the sahpe surrounded by walls.
                                        Handling cliff is rather complex, because I need first to introduce a feature where the mesh is adapted to follow exactly some contours and then change the mesh logic to handle several altitudes for the same grid node.
                                          jcorreiadefreitas
                                          Tried the plugin today and it does wonders... however i am wondering if it is possible to clip or "limit" the terrain generation to a line as i dont want it to generate in terrain beyond the lowest contour...
                                          • fredo6F
                                            @jcorreiadefreitas said:
                                            [attachment=0:3eevq3al]<!-- ia0 -->1.jpg<!-- ia0 -->[/attachment:3eevq3al]
                                            If all contours are enclosed within a big one, then this big contour is taken as the limit.
                                            So it should work in your case.
                                            Otherwise, just send me the model so that I have a look.
                                            • 22
                                            • 23
                                            • 8 / 23
