    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      Merdox
      thaaaankss
        Aldob
        Hi Fredo,
        Thanks for you awsome plugin. However I have difficulties install it to alternative file location using additional plugin folder. I installed latest version library and plugins from plugin store and when launch SketchUP I have messages about errors and have no plugins in sketchup after opening. The only I have BZ_toolbar with no icones on it. I'd be appreciate if you could help me to solve a problem.
        error message
        Error Loading File C.txt
          metamachine
          first off, a massive thank you for your hard work.
          I have recently upgraded to 2013 but the installation of fredocore has been less than smooth for me . I have installed it via the extension warehouse but run into this error in my ruby console|
          rror; #<NoMethodError; undefined method `each' for nil;NilClass>
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `get'
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;154;in `[]'
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;667;in `load_second_phase_rubies'
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Plugin.rb;124;in `launch_action'
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/bootstrap_FredoScale.rb;381;in `launch_action_p'
          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_FredoScale/bootstrap_FredoScale.rb;322;in `configure'
          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `call'
          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `build_config_handlers'
          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `call'
          In this instance i tried to use the box scaling but nothing happens or shows. Ive done a ton of googling but I have not seen a similar error message. I hope anyone can help me
          thnx,
          -D
            @metamachine
            Please add your OS and SketchUp version to your SketchUcation User profile...
            And then expand their details in a post as needed...
            That will often help us understand your issues more readily...
            I guess you are on a MAC with v2013 [Make?]...
            Have you restarted SketchUp after the updates - some of Fredo's tools require this to complete the changes...*
            Have you installed the very latest versions of the Lib itself AND each of the Tools.
            Many have been updated to suit v2013 and so they cannot be 'copied over' from your v8 folders.
            All of the latest Lib and Tool files should be available at the EW... OR they are download-able as RBZ archives from the easy to use SketchUcation PluginStore page [these can then be installed from the SketchUp > Preferences > Extensions > Install... button in v8/v2013], or using SketchUcation's Plugin Store dialog from within SketchUp itself, which AutoInstalls etc...*
              metamachine
              Yea, i should have added my profile and system specs.
              Anyway, Im running a retina macbook pro late 2013 osx mavericks and sketchup 13. I have installed the plugins via the EW so I have no idea what is going on exactly. I have noticed this mavericks update is very picky with granting apps and software permission to write etc. to the point of claiming the software "is broken and should me moved to thrash" if it comes from a source apple does not recognise.
              Yesterday i died a complete reinstall of sketchup 2013 but to no avail. I guess Ill have to mess about a bit more
              -D
                metamachine
                fixed!
                so apparently having the plugins in both user/library/sketchup/plugins and hd/library/sketchup/plugins causes a conflict and stops the extension from working. after some hours of frustration I can finally work again.
                thank you again
                -D
                  Please do update your profile, then.
                    Why did you put the file in the alternate Plugins folder ? πŸ˜’
                    • E
                      emash
                      Please help me, my interface is resetting each time i start sketchup. Plugin buttons using fredo are all gone each start, P.S. Mac OS, sketchup pro 8
                        jimbob99
                        rhino > sketchup... too many plugins and downloads for tools that should already been implented into the original program.
                        • cottyC
                          cotty
                          And you think this belongs into this topic because ...? πŸ˜•
                          my SketchUp gallery
                            rekin0
                            Thanks for signaling this.
                            • G
                              guilhermestudio
                              hi,
                              I'm with some issues to instal LibFredo6.
                              I did all the usual procedure and when I start Sketchup appear this mensage:
                              "You must install LibFredo6 version 5.2 or higher to run Fredo6_Curviloft"
                              and in the menu/window instead of LibFredo6 Settings I see "Ruby Console" that opens a dialog box, that I have no idea of what tipe on it.
                              Please Help
                                @guilhermestudio said:
                                hi,
                                Please Help
                                Do you have FULL read/write Security permission set for all users/groups listed under Properties > Security > Edit... for the Plugins folder ?
                                If not, then you might think you have installed the Lib folder, but Windows might have actually put it into the VirtualStore to protect you from yourself, but not tell you... πŸ˜’
                                If you have a link/button in one of the top-bars of the Plugins folder's Windows Explorer window that's a sure sign...
                                Fix the Security to FULL [you need to be an Admin to do that [set it in Users control-panel if not]].
                                Then install the Lib and any other things you find in the VirtualStore...
                                Alternatively... if you think you have installed the Lib and it is in the Plugins folder... then how did you do it - if you did it manually did you keep the files in their subfolders etc - not doing so is a recipe for disaster !
                                I recommend you use the RBZ Preferences > Extensions > Install... button installer, or use the PluginStore dialog's AutoInstaller... πŸ˜•
                                  rv1974
                                  Fredo, I have errors in calculations. What Am I Doing Wrong?
                                  fredo_topo.skp
                                  Ruby Error - CALCULATING TERRAINS - 14-Jan-14 14_01_18.txt
                                    rv1974
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v5.5g - 24 Jan 14
                                      LibFredo6 5.5g is a release for EdgeInspector 1.0, which is just published as part of FredTools 1.6g.
                                      • OxerO
                                        Oxer
                                        Thanks Fredo for this update and new tool !! πŸ‘
                                        I have updated the Spanish Language (Spain).
                                        Spanish Language (Spain) v5.5g
                                        • fredo6F
                                          Oxer,
                                          Thanks very much. Will go in next release
                                          Fred
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v5.6a - 03 Feb 14
                                            LibFredo6 5.6a is a release for fixing bugs in Curvizard, for the Make Curve tools
                                            There is also a (limited) support for Retina screens. The parameter can be set in the Default Parameters dialog box of LibFredo6. When set, the size of the button palettes, visual progress bars and some custom tooltips is enlarged by a factor 2. However, the font size is not changed (not possible from Ruby). So you may obtain an acceptable result or keep tiny fonts.
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 115
                                            • 116
                                            • 35 / 116
