    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • cottyC Offline
      cotty
      @jimbob99 said:
      rhino > sketchup... too many plugins and downloads for tools that should already been implented into the original program.
      And you think this belongs into this topic because ...? 😕
      my SketchUp gallery
        rekin0
        Thanks for signaling this.
          guilhermestudio
          hi,
          I'm with some issues to instal LibFredo6.
          I did all the usual procedure and when I start Sketchup appear this mensage:
          "You must install LibFredo6 version 5.2 or higher to run Fredo6_Curviloft"
          and in the menu/window instead of LibFredo6 Settings I see "Ruby Console" that opens a dialog box, that I have no idea of what tipe on it.
          Please Help
            @guilhermestudio said:
            hi,
            Please Help
            Do you have FULL read/write Security permission set for all users/groups listed under Properties > Security > Edit... for the Plugins folder ?
            If not, then you might think you have installed the Lib folder, but Windows might have actually put it into the VirtualStore to protect you from yourself, but not tell you... 😒
            If you have a link/button in one of the top-bars of the Plugins folder's Windows Explorer window that's a sure sign...
            Fix the Security to FULL [you need to be an Admin to do that [set it in Users control-panel if not]].
            Then install the Lib and any other things you find in the VirtualStore...
            Alternatively... if you think you have installed the Lib and it is in the Plugins folder... then how did you do it - if you did it manually did you keep the files in their subfolders etc - not doing so is a recipe for disaster !
            I recommend you use the RBZ Preferences > Extensions > Install... button installer, or use the PluginStore dialog's AutoInstaller... 😕
            • R Do not disturb
              rv1974
              Fredo, I have errors in calculations. What Am I Doing Wrong?
              fredo_topo.skp
              Ruby Error - CALCULATING TERRAINS - 14-Jan-14 14_01_18.txt
              • R Do not disturb
                rv1974
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v5.5g - 24 Jan 14
                  LibFredo6 5.5g is a release for EdgeInspector 1.0, which is just published as part of FredTools 1.6g.
                  • OxerO Offline
                    Oxer
                    Thanks Fredo for this update and new tool !! 👍
                    I have updated the Spanish Language (Spain).
                    Spanish Language (Spain) v5.5g
                    • fredo6F Offline
                      Oxer,
                      Thanks very much. Will go in next release
                      Fred
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v5.6a - 03 Feb 14
                        LibFredo6 5.6a is a release for fixing bugs in Curvizard, for the Make Curve tools
                        There is also a (limited) support for Retina screens. The parameter can be set in the Default Parameters dialog box of LibFredo6. When set, the size of the button palettes, visual progress bars and some custom tooltips is enlarged by a factor 2. However, the font size is not changed (not possible from Ruby). So you may obtain an acceptable result or keep tiny fonts.
                        • jeff hammondJ Offline
                          hey Fredo,
                          not sure which thread to post this but this one seems ok 😉
                          some of your toolbars aren't showing tooltips per icon.. i don't have all of your plugins installed but with the ones i do, the following names show as the tooltip for every icon in their respective toolbar:
                          Curviloft
                          RoundCorner
                          FredoScale
                          two of them are showing each icon tooltip properly:
                          JointPushPull (the new one)
                          BezierSpline
                          (not sure about fredotools and curvizard as i use the single button toolbar for those)
                          • F Offline
                            fboth
                            **Dear Fredo
                            I have Sketchup 2013. I installed your fredo 6 and reound corner and I get Error message
                            erfordert Sketchup Version höher als 5.0.160 Aktuerlle Version ist 13.0.4813
                            Please help me
                            Franz**
                            • fredo6F Offline
                              @fboth said:
                              **Dear Fredo
                              Please help me
                              Franz**
                              It looks like you have an old version of LibFredo6 and RoundCorner.
                              Please upgrade to latest ones.
                              Ideally, use the Sketchucation PluginStore tool to install the plugins.
                                roshinimohan
                                how do i go about it for mac os
                                  Go about what? What is "it"?
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v5.7a - 15 Feb 14
                                    LibFredo6 5.7a is a release for EdgeInspector 1.1, which is part of FredoTools 1.7a
                                    See main post of this thread for Download of LibFredo6.
                                    • F Offline
                                      fboth
                                      Thank you Fredo,
                                      yes it works now!!
                                      I got another Problem, when I round the Corners of a cube, I get holes in the Corners, how to avoid this? And if I select one Corner after the other, as I do not want to round all Corners of the case, I get sometimes holes sometimes there is some material left I mean the rounding does not go around the new round Corner in the Corner.
                                      • cottyC Offline
                                        cotty
                                        @fboth said:
                                        Thank you Fredo,
                                        yes it works now!!
                                        If the faces are too small, they are not created. You can try to scale your model up (100x, 1000x) before you use the plugin.
                                        my SketchUp gallery
                                        • guanjinG Offline
                                          guanjin
                                          Check the update click to view is invalid
                                          • guanjinG Offline
                                            guanjin
                                            Selection boxes have become such a big,sketchup8 and 2013 are so。
                                            5.6 and 5.7 are like this, 5.4 no problem 。
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 111
                                            • 112
                                            • 36 / 112
