    [Plugin Library] LibFredo6 - v16.3a - 20 Oct 26
    2.3k Posts 587 Posters 11.9m Views 589 Watching
    • K
      KevB
      can somebody tell me where you put the shared library file ie the round corners
      Kevin
        Kevin
        Go to the first post of the thread and read it. It tells you where to put the files. Why don't you install the Sketchucation Plugin Store? Then you can just let it auto install your plugins.
          detcharles
          Hello,
          I am reposting from earlier concerning a problem with the way the text is displayed in joint push pull. I included a photo [see attached].
          Fredo mentioned its an issue with Open GL text sizing. Does anyone know how to adjust that?
          Thank You
          I am running SU8 PRO on a Macbook Pro Retina, OS Maverick
          • fredo6F
            NEW RELEASE: LibFredo6 v5.4a - 07 Nov 13
            LibFredo6 5.4a is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
            Note: I will re-release all my scripts in the coming days, hopefully based on LibFredo6 5.4
            • guanjinG
              guanjin
              I installed Fredo6_% 21LibFredo6 - v5.4a, tips or display version 5.3, you need 5.4
              guanjin
              • OxerO
                Oxer
                For me the same when I run SU.
                • fredo6F
                  NEW RELEASE: LibFredo6 v5.4b - 08 Nov 13
                  Note: LibFredo6 5.4a was an incorrect release on the forum (it was OK on Plugin Store). So please move to 5.4b for avoidance of doubt
                  LibFredo6 5.4b is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
                  • guanjinG
                    guanjin
                    Thank updates, operating normally, thank you!
                      Merdox
                      thaaaankss
                        Aldob
                        Hi Fredo,
                        Thanks for you awsome plugin. However I have difficulties install it to alternative file location using additional plugin folder. I installed latest version library and plugins from plugin store and when launch SketchUP I have messages about errors and have no plugins in sketchup after opening. The only I have BZ_toolbar with no icones on it. I'd be appreciate if you could help me to solve a problem.
                        error message
                        Error Loading File C.txt
                          metamachine
                          first off, a massive thank you for your hard work.
                          I have recently upgraded to 2013 but the installation of fredocore has been less than smooth for me . I have installed it via the extension warehouse but run into this error in my ruby console|
                          rror; #<NoMethodError; undefined method `each' for nil;NilClass>
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `get'
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;154;in `[]'
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;667;in `load_second_phase_rubies'
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Plugin.rb;124;in `launch_action'
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/bootstrap_FredoScale.rb;381;in `launch_action_p'
                          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_FredoScale/bootstrap_FredoScale.rb;322;in `configure'
                          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `call'
                          /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `build_config_handlers'
                          /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `call'
                          In this instance i tried to use the box scaling but nothing happens or shows. Ive done a ton of googling but I have not seen a similar error message. I hope anyone can help me
                          thnx,
                          -D
                            @metamachine
                            Please add your OS and SketchUp version to your SketchUcation User profile...
                            And then expand their details in a post as needed...
                            That will often help us understand your issues more readily...
                            I guess you are on a MAC with v2013 [Make?]...
                            Have you restarted SketchUp after the updates - some of Fredo's tools require this to complete the changes...*
                            Have you installed the very latest versions of the Lib itself AND each of the Tools.
                            Many have been updated to suit v2013 and so they cannot be 'copied over' from your v8 folders.
                            All of the latest Lib and Tool files should be available at the EW... OR they are download-able as RBZ archives from the easy to use SketchUcation PluginStore page [these can then be installed from the SketchUp > Preferences > Extensions > Install... button in v8/v2013], or using SketchUcation's Plugin Store dialog from within SketchUp itself, which AutoInstalls etc...*
                              metamachine
                              Yea, i should have added my profile and system specs.
                              Anyway, Im running a retina macbook pro late 2013 osx mavericks and sketchup 13. I have installed the plugins via the EW so I have no idea what is going on exactly. I have noticed this mavericks update is very picky with granting apps and software permission to write etc. to the point of claiming the software "is broken and should me moved to thrash" if it comes from a source apple does not recognise.
                              Yesterday i died a complete reinstall of sketchup 2013 but to no avail. I guess Ill have to mess about a bit more
                              -D
                                metamachine
                                fixed!
                                so apparently having the plugins in both user/library/sketchup/plugins and hd/library/sketchup/plugins causes a conflict and stops the extension from working. after some hours of frustration I can finally work again.
                                thank you again
                                -D
                                  Please do update your profile, then.
                                    Why did you put the file in the alternate Plugins folder ? πŸ˜’
                                    • E
                                      emash
                                      Please help me, my interface is resetting each time i start sketchup. Plugin buttons using fredo are all gone each start, P.S. Mac OS, sketchup pro 8
                                        jimbob99
                                        rhino > sketchup... too many plugins and downloads for tools that should already been implented into the original program.
                                        • cottyC
                                          cotty
                                          And you think this belongs into this topic because ...? πŸ˜•
                                          my SketchUp gallery
                                            rekin0
                                            Thanks for signaling this.
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 113
                                            • 114
                                            • 35 / 114
