    1.5k Posts 478 Posters 4.3m Views 478 Watching
      You do not need this renderer loaded all of the time.
      Use the SketchUcation Plugins Manager [or its Extensions Manager] to disable it.
      This also applies to some other tools [often BIM oriented]
      After a restart there will be no clashes with this toolset, or some others that also experience similar problems.
      You can load the disabled plugin temporarily for a session as you need it [orange button] - being mindful that it may have now broken some other tools for just that session.
      Você não precisa de um plugin como este 'renderizador' para ser carregado o tempo todo.
      Use o SketchUcation Plugins Manager (Gerente) [ou sua Extensions Manager] para desativá-lo.
      Isso também pode se aplicar a alguns outros instrumentos [muitas vezes BIM orientada]
      Depois de um reboot que não haja confrontos com este conjunto de ferramentas, ou alguns outros que têm problemas semelhantes.
      Você pode habilitar o plugin desativada temporariamente para uma sessão que é necessário [botão laranja] - lembrando que agora ele pode ter quebrado algumas outras ferramentas, mas apenas para aquela sessão.
        andrey vieira
        Funcionou certinho,
        obrigado!!
        • W
          whitelock
          Love this plugin however wanted to ask about rounding corners. When I try and round corners I end up with all the edge lines visible. I know you can turn these off in the drop down menu but I have tried every varuaition I can think of and cant get the desired results. can someone please tell me what parameters I need to set in order to get smooth rounds with edge lines at the radius points only like in the picture below.
          Luke
          • W
            whitelock
            here are the pictures illustrating my point.
            thanks
            how I would like my rounds to look
            how they look when using the plugin
            • gillesG
              gilles
              Try this:
              • fredo6F
                NEW RELEASE: RoundCorner v2.6a - 27 Nov 13
                RoundCorner 2.6a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                • KrisidiousK
                  Krisidious
                  Look at all the Fredo updates... Thanks mang.
                  By: Kristoff Rand
                  • OxerO
                    Oxer
                    Hi, I updated all the Fredo Plugins with the 27-11-13 version and now the Tooltips for the toolbars don't appear, only the name of the Toolbar.
                    The same with GhostComp, FredoScale, ToolsOnSurface, Curvizard and Curviloft, the Tooltips for JointPushPull work fine.
                    • fredo6F
                      Oxer,
                      Normally in SU13, you should have a multi line tooltip.
                      • first line should be the plugin title
                      • the second line should be the corresponding Tools in the plugin
                      This is therefore strange
                      • OxerO
                        Oxer
                        I know it, and yes, it's very strange.
                        Of your Plugins, the Tooltips work fine only in JointPushPull (appear translated) and FredoTools (appears in English).
                        • fredo6F
                          It may be a bug in SU13, maybe related to the Spanish version of Sketchup. I don't have it on my PC, with a English and French SU13.
                          By the way, what do you get if you switch to NO default language in LibFredo6. Do you get the correct tooltips in English
                          • OxerO
                            Oxer
                            I changed to default language and the problem persists, perhaps is an error only on Mac & SU2013, if another mac user could tell us if he has the same problem or it's a problem only mine.
                            I don't want that you lose time with this.
                            • TeknicalT
                              Teknical
                              I have a problem with this plugin in SketchUp 2013 Pro. I installed the new lib file and the new version of RoundOver but when i use it, it crashes SketchUp. Any idea on how to fix this? Here's the bug report
                              http://img844.imageshack.us/img844/8743/xql8.jpg
                                AcesHigh
                                I have a problem with Roundcorner. I am trying to apply it on some furniture. As soon as I apply, everything looks good. But as soon as I try to save, Sketchup says there are problems on my model that need to be fixed. If I try to fix them, I lose most corners of the model.
                                Below, attached, is the log if I manually fix the model in the model info window. It results in a huge 1,3 mb txt file of error report!!!!!
                                and also an image showing the apparently well rounded corners, and then, the rounded corners after errors are fixed.
                                finally, you may ask: then why fix the erros? Just don´t fix them.
                                Unfortunatelly, I did not fix the errors, but when I saved the file to render with Thea Render, Thea interpreted the file (or saved it to be used at Thea Studio) with the open corners, as if Sketchup had fixed the errors.
                                roundcornererror.txt
                                  The faces are too small and endpoints of lines are too close together. Reduce the number of segments used to create the radius. You don't need as many as you are using for that tiny radius anyway. You might also scale a copy of the component up before running the Round Corner plugin. Once you've finished editing the component, close the scaled up copy and delete it.
                                  • BoxB
                                    It looks suspiciously like the geometry is too small. Perhaps if you scale it up and save it. Then scale it down once saved.
                                    Dave got there just before me.
                                      AcesHigh
                                      I see. Would it help if I changed model units to millimiters? If not, I will try the other methods.
                                        The units you're working in make no difference to whether or not the lines are too short.
                                          AcesHigh
                                          doesn´t make much sense to me, in the moment you guys tell me I can create a component, increase its size and realize the operation on the large sized model. I mean, its a virtual enviroment, not the real world, why does it makes a difference zooming into the model or increasing it´s size? 😕 😕
                                            It just does. Don't think too hard about it. It isn't worth troubling yourself over it. Zooming in doesn't change the length of the lines, it only changes their apparent size.
                                            If you use the process I described you won't have to scale back down after rounding over. You can see that same process in the video here.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 74
                                            • 75
                                            • 41 / 75
