    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • ElibjrE
      Elibjr
      Wow, this is a amazing! This is starting to make Sketchup look more like a CAD modeler! Well done. I-Render Nxt also renders section cuts similar to Indigo. I will also try this with this and Layout later!
      • P
        pgarmyn
        @tig said:
        The issue might be that offset.rb [ill advisedly] adds a new method to Array.offset(distance)* this clashes ...
        Thanks TIG and micione, for the analysis 👍
        Anyway, I don't think Array.offset is the reason for the incompatibility. As I said, no method in my plugin uses offset.
        I just installed Windowizer-3 (W3) beside RichSection (RS) in SU8.
        In this version of Windowizer there is no def offset(dist) for class Array.
        I confirm Bugsplat when combining both plugins. When using RS or W3,
        But after uninstalling RS (also the files), I have also have Bugsplats in W3 for complex models (many nested groups).
        Bugsplat in RS (combined with W3) takes always place at the end, after a commit operation,
        TO BE CONTINUED....
          ArCAD-UK
          Impressed so far 👍
          Feedback:
          Why create two scenes? I appreciate they are different but do you really need two when the change is simply a toggle of the section plane?
          RICHSECTION NAME is strange when using custom names e.g. the resulting names aren't as expected
          It might be useful to have a simple continuous line in the Projection line styles.
          • P
            pgarmyn
            @arcad-uk said:
            Impressed so far 👍
            Feedback:.....
            Why create two scenes? The first scene is for editing: The camera is not saved, the sectionplan is visible. The second scene (name+p : for parallel view) is for those who really use it (directly) in layout: camera saved, sectionplan not visible. But i can put some swiches in the RichSection settings.
            RICHSECTION NAME is strange ...... Dont understand. Is it the 'p' at the end?
            It might be useful to have a simple continuous line.... : In what case? Exemple?
            Thanks for your interest. 😉
              ArCAD-UK
              Last night my first section entry [XL01] was replaced with [XL0001] today everything seems ok 😕 I may have used "undo" and messed things up.
              There is a lot going on when creating an RS, can I do a complete undo with 1 click?
              I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. 😞
              • jolranJ
                jolran
                You do know that you can do this in Hatchfaces ? If you want real edges as hatches from section slice that is.
                  ArCAD-UK
                  I will have a look at that thanks! I'm not a fan of raster hatching...
                  • jolranJ
                    jolran
                    Check out the help files, if that does not work for you, you can PM me and fire the questions. Or if you rather post a question in Hatchafaces topic thats fine too.
                    • P
                      pgarmyn
                      I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. (
                      Undo : I can't undo scenes and styles loaded (from file). The SU API for Ruby has no functions to create them from scratch. I have to load them from a file. No way, at my knowledge, to include this in the undo DB (within start and commit_operation).
                      Controle vector output (with color and line style) to Layout : I can only dream of it. 😉
                      • P
                        pgarmyn
                        Hi TIG, micione and others...
                        As I said before (see 'TO BE CONTINUED'), I loaded the free version (Windowizer3, W3) and did some testing.
                        As the Bugsplat takes place after a commit_operation in the RichSection plugin (without 'other' errors), I tried to find the conflict in the W3 code.
                        I didn't find anything directly in common with the RichSection plugin, but I found these anomalies:
                        • def getMaterials is a root method declared twice : once in windowizer,rb, once in getMaterials.rb; Even if the 'require getMaterials,rb' is comment out; the file is automatically loaded because it is directly in the Sketchup/plugins
                        • The following classes are extended : Array, Sketchup::Face, Sketchup::Entity; Sketchup::ArcCurve; Sketchup::Curve
                        • many Global variables
                        • the global variable $wName is once a string [=Wdw.new.to_s.slice(6..14)] and later an empty class object [=Wdw.new]…..
                          I tried to clean up the code for testing, but I can't see the end of it.
                        As there is nothing specificly in common with RS (I mean : in common with RS but not with other plugins), I cleaned up the plugin directory and installed only Windowizer3 + Fredo's RoundCorner
                        It works fine for a (very) small model.
                        But for more a more complex models (50 identical component-instances: in total (nested) about 9500 edges, 3300 faces), I had directly a Bug-splat when creating round corners around one face within the component.
                        I uninstalled Windowizer3 (the files) and did the same manipulation : Eventing worked fine.
                        I think that the plugins of Fredo are a reference for the Sketchup community.
                        CONCLUSION : Windowizer 3 is not a stable plugin. I didn't spent my money to test the payed version ….
                        Windowizer is not distributed on Sketchucation, but maybee it is important to tell people that it causes Bugsplats in other plugins.
                        • ladcweiL
                          ladcwei
                          I am waiting for this plugin for five years,then I could handle whole design with Su &layout completely today!Thanks a lot!
                          It's another plugin for sections:
                          http://www.sublog.net/?s=realsection
                          it could assign diffferent materials to different grounps,maybe it could give some useful ideas...
                          I am chinese,you can download this plugin on http://www.sublog.net for free,needn't to pay,this site show all the resourse here,it's a good guide! 😄
                          • P
                            pgarmyn
                            @ladcwei said:
                            ....http://www.sublog.net/?s=realsection
                            Hallo ladcwei
                            You can also assign different materials in the RichSection plugin: by layer, by nature (color) or a combination.
                            It's much faster than assigning materials to individual elements, but you will have to organize your model and use different layers to assign different section-materials.
                            I know realSection (GWD), there is also SectionCutface (TIG), and other good plugins.
                            Each plugin is different. I wanted to offer projection.
                            [highlight=#ffff40:y89ppu1f]So what were you waiting for during 5 years ? ❓ ❓[/highlight:y89ppu1f]
                            Thanks for the interest.
                            • P
                              pgarmyn
                              I added two new videos.
                              In the last video, I produced a plan with [highlight=#ffff00:3n6bzrcv]SKETCHUP + RichSection + LAYOUT[/highlight:3n6bzrcv]:
                              See video and attached PDF file (RichSection-demo-04.PDF) in the first post.
                                Absolutly astonishing! 😎
                                (tested in V8)
                                Another plugin who makes bugsplatsh :wxSU.rb !!!
                                Does it posible to delete these dotted lines in the free space ?
                                ( i have not yet explore the plugin! 😳
                                Ps Why you don't say on the first post that the UI of Rich Section is working automatically also in French? ☀
                                rich4.skp
                                • P
                                  pgarmyn
                                  (tested in V8)
                                  [attachment=1:3822h56j]<!-- ia1 -->rich2.jpg<!-- ia1 -->[/attachment:3822h56j]
                                  %(#0000FF)[Bonjour Pilou. Quel honneur ❗
                                  Pour enlever ces lignes, il suffit d'éteindre 'PROJECTION'. (La section calculera aussi beaucoup plus vite).
                                  Dans les dessins technique (architecture), la projection représente les éléments au-dessus du plan de projection.
                                  On peut aussi limiter la projection (par distance, calques). Une démonstration (distance de projection limitée) est faite dans video #03.
                                  Je vais ajouter : Si la version de SU est française, elle chargera RichSection en français..]
                                  For the rest of the world:
                                  To take away those pointed lines, just switch off 'PROJECT'. (The section will also calculate faster).
                                  In technical drawings (architecture), 'projection' represents the elements above the section-plane.
                                  You can also controle wich elements are projected (by distance, layers). This is demonstrated (with projection limited by distance) in video #03.
                                  For people with a french SU, the program will load a french RichSection dictionary.
                                  For the rest of the world: are there traductors on this forum?
                                  • P
                                    pgarmyn
                                    For more important (big, complex) drawings. It is worth to use SU 2013. MUCH MUCH faster ❗ ❗ ❗
                                      Excellent! 😎 👍 ☀
                                      • P
                                        pgarmyn
                                        deleted double message
                                        • P
                                          pgarmyn
                                          If someone want's to pay for my RichSection [Demo] plugin :
                                          [highlight=#ffff00:2ljx047o]They sell (correction) USE it already in China:[/highlight:2ljx047o] 🤣 🤣
                                          Document
                                          (www.sublog.net)
                                          I can't explain much in chinese, so i added an other video (above). 😆
                                          • emerald15E
                                            emerald15
                                            Thank you. I've just completed a more than usually complex drawing that required cross sections. I use RichSection to great effect. I really like all the additional optional colours, line types & infills.
                                            • 19
                                            • 20
                                            • 3 / 20
