    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • micioneM
      micione
      pgarmyn,
      "offset.rb" is used by other tools of Rick Wilson (eg "windowizer").
      What happens:
      Your tool applies the first section, then it stops, stuck.
      Any attempt to use the "move tool" on the section, it causes BugSplat.
      Only by removing "offset.rb" your tool starts working again.
      In order to identify the conflict, must be eliminated (one by one) all installed plugins. And this is what I did.
      I hope I was helpful.
      P.S. perhaps seek the advice of Rick Wilson?
      • P
        pgarmyn
        @micione said:
        pgarmyn,
        "offset.rb" is used by other tools of Rick Wilson (eg "windowizer").....
        I will test it out. Tomorrow
        • P
          pgarmyn
          A futur hit for sure! ☀
          When you say Demo, will be commercial at the end ?
          Maybee commercial... . But I will also keep a FREE version .
          Until March 2014, everybody can have the full 'DEMO'(Thanks for the correction Bob James)
          As 'RichSections' are standard SU-groups, they only need the plugin for update.
            The issue might be that offset.rb [ill advisedly] adds a new method to Array.offset(distance)* this clashes with the Point3d.offset(vector, distance) because an Array of three values [x,y,z] can be offset just as it it were a Point3d, but the native method is expecting a Vector3d [or an Array of three [xv,yv,zv]] and an optional second argument of a distance that overrides the vector's length...
            *In my copy of offset.rb I have renamed it as offsetArray(dist) to avoid the clash [it's never used anyway!].
            So to avoid clashes with the offset.rb method Array.offset() never use .offset() on point that is expressed as an Array - make that array into a Point3d before the offset is applied, then the clash is avoided.
            So it should be
            point=Geom::Point3d.new(0,1,2) [or ...new([0,1,2])]
            then
            point.offset(vector)
            or in one step
            Geom::Point3d.new([0,1,2]).offset(vector)
            BUT NEVER
            [0,1,2].offset(vector)
            or
            pt=[1,2,3] pt.offset(vector)
            • G
              gbing
              Amazing!!
              This plugin cover one of the CAD missing function in sketchup.
              Now I need to check it in layout.
              Thank you pgarmyn!
              • ElibjrE
                Elibjr
                Wow, this is a amazing! This is starting to make Sketchup look more like a CAD modeler! Well done. I-Render Nxt also renders section cuts similar to Indigo. I will also try this with this and Layout later!
                • P
                  pgarmyn
                  @tig said:
                  The issue might be that offset.rb [ill advisedly] adds a new method to Array.offset(distance)* this clashes ...
                  Thanks TIG and micione, for the analysis 👍
                  Anyway, I don't think Array.offset is the reason for the incompatibility. As I said, no method in my plugin uses offset.
                  I just installed Windowizer-3 (W3) beside RichSection (RS) in SU8.
                  In this version of Windowizer there is no def offset(dist) for class Array.
                  I confirm Bugsplat when combining both plugins. When using RS or W3,
                  But after uninstalling RS (also the files), I have also have Bugsplats in W3 for complex models (many nested groups).
                  Bugsplat in RS (combined with W3) takes always place at the end, after a commit operation,
                  TO BE CONTINUED....
                    ArCAD-UK
                    Impressed so far 👍
                    Feedback:
                    Why create two scenes? I appreciate they are different but do you really need two when the change is simply a toggle of the section plane?
                    RICHSECTION NAME is strange when using custom names e.g. the resulting names aren't as expected
                    It might be useful to have a simple continuous line in the Projection line styles.
                    • P
                      pgarmyn
                      @arcad-uk said:
                      Impressed so far 👍
                      Feedback:.....
                      Why create two scenes? The first scene is for editing: The camera is not saved, the sectionplan is visible. The second scene (name+p : for parallel view) is for those who really use it (directly) in layout: camera saved, sectionplan not visible. But i can put some swiches in the RichSection settings.
                      RICHSECTION NAME is strange ...... Dont understand. Is it the 'p' at the end?
                      It might be useful to have a simple continuous line.... : In what case? Exemple?
                      Thanks for your interest. 😉
                        ArCAD-UK
                        Last night my first section entry [XL01] was replaced with [XL0001] today everything seems ok 😕 I may have used "undo" and messed things up.
                        There is a lot going on when creating an RS, can I do a complete undo with 1 click?
                        I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. 😞
                        • jolranJ
                          jolran
                          You do know that you can do this in Hatchfaces ? If you want real edges as hatches from section slice that is.
                            ArCAD-UK
                            I will have a look at that thanks! I'm not a fan of raster hatching...
                            • jolranJ
                              jolran
                              Check out the help files, if that does not work for you, you can PM me and fire the questions. Or if you rather post a question in Hatchafaces topic thats fine too.
                              • P
                                pgarmyn
                                I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. (
                                Undo : I can't undo scenes and styles loaded (from file). The SU API for Ruby has no functions to create them from scratch. I have to load them from a file. No way, at my knowledge, to include this in the undo DB (within start and commit_operation).
                                Controle vector output (with color and line style) to Layout : I can only dream of it. 😉
                                • P
                                  pgarmyn
                                  Hi TIG, micione and others...
                                  As I said before (see 'TO BE CONTINUED'), I loaded the free version (Windowizer3, W3) and did some testing.
                                  As the Bugsplat takes place after a commit_operation in the RichSection plugin (without 'other' errors), I tried to find the conflict in the W3 code.
                                  I didn't find anything directly in common with the RichSection plugin, but I found these anomalies:
                                  • def getMaterials is a root method declared twice : once in windowizer,rb, once in getMaterials.rb; Even if the 'require getMaterials,rb' is comment out; the file is automatically loaded because it is directly in the Sketchup/plugins
                                  • The following classes are extended : Array, Sketchup::Face, Sketchup::Entity; Sketchup::ArcCurve; Sketchup::Curve
                                  • many Global variables
                                  • the global variable $wName is once a string [=Wdw.new.to_s.slice(6..14)] and later an empty class object [=Wdw.new]…..
                                    I tried to clean up the code for testing, but I can't see the end of it.
                                  As there is nothing specificly in common with RS (I mean : in common with RS but not with other plugins), I cleaned up the plugin directory and installed only Windowizer3 + Fredo's RoundCorner
                                  It works fine for a (very) small model.
                                  But for more a more complex models (50 identical component-instances: in total (nested) about 9500 edges, 3300 faces), I had directly a Bug-splat when creating round corners around one face within the component.
                                  I uninstalled Windowizer3 (the files) and did the same manipulation : Eventing worked fine.
                                  I think that the plugins of Fredo are a reference for the Sketchup community.
                                  CONCLUSION : Windowizer 3 is not a stable plugin. I didn't spent my money to test the payed version ….
                                  Windowizer is not distributed on Sketchucation, but maybee it is important to tell people that it causes Bugsplats in other plugins.
                                  • ladcweiL
                                    ladcwei
                                    I am waiting for this plugin for five years,then I could handle whole design with Su &layout completely today!Thanks a lot!
                                    It's another plugin for sections:
                                    http://www.sublog.net/?s=realsection
                                    it could assign diffferent materials to different grounps,maybe it could give some useful ideas...
                                    I am chinese,you can download this plugin on http://www.sublog.net for free,needn't to pay,this site show all the resourse here,it's a good guide! 😄
                                    • P
                                      pgarmyn
                                      @ladcwei said:
                                      ....http://www.sublog.net/?s=realsection
                                      Hallo ladcwei
                                      You can also assign different materials in the RichSection plugin: by layer, by nature (color) or a combination.
                                      It's much faster than assigning materials to individual elements, but you will have to organize your model and use different layers to assign different section-materials.
                                      I know realSection (GWD), there is also SectionCutface (TIG), and other good plugins.
                                      Each plugin is different. I wanted to offer projection.
                                      [highlight=#ffff40:y89ppu1f]So what were you waiting for during 5 years ? ❓ ❓[/highlight:y89ppu1f]
                                      Thanks for the interest.
                                      • P
                                        pgarmyn
                                        I added two new videos.
                                        In the last video, I produced a plan with [highlight=#ffff00:3n6bzrcv]SKETCHUP + RichSection + LAYOUT[/highlight:3n6bzrcv]:
                                        See video and attached PDF file (RichSection-demo-04.PDF) in the first post.
                                          Absolutly astonishing! 😎
                                          (tested in V8)
                                          Another plugin who makes bugsplatsh :wxSU.rb !!!
                                          Does it posible to delete these dotted lines in the free space ?
                                          ( i have not yet explore the plugin! 😳
                                          Ps Why you don't say on the first post that the UI of Rich Section is working automatically also in French? ☀
                                          rich4.skp
                                          • P
                                            pgarmyn
                                            (tested in V8)
                                            [attachment=1:3822h56j]<!-- ia1 -->rich2.jpg<!-- ia1 -->[/attachment:3822h56j]
                                            %(#0000FF)[Bonjour Pilou. Quel honneur ❗
                                            Pour enlever ces lignes, il suffit d'éteindre 'PROJECTION'. (La section calculera aussi beaucoup plus vite).
                                            Dans les dessins technique (architecture), la projection représente les éléments au-dessus du plan de projection.
                                            On peut aussi limiter la projection (par distance, calques). Une démonstration (distance de projection limitée) est faite dans video #03.
                                            Je vais ajouter : Si la version de SU est française, elle chargera RichSection en français..]
                                            For the rest of the world:
                                            To take away those pointed lines, just switch off 'PROJECT'. (The section will also calculate faster).
                                            In technical drawings (architecture), 'projection' represents the elements above the section-plane.
                                            You can also controle wich elements are projected (by distance, layers). This is demonstrated (with projection limited by distance) in video #03.
                                            For people with a french SU, the program will load a french RichSection dictionary.
                                            For the rest of the world: are there traductors on this forum?
                                            • 19
                                            • 20
                                            • 2 / 20
