    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • P
      pgarmyn
      Hi TIG, micione and others...
      As I said before (see 'TO BE CONTINUED'), I loaded the free version (Windowizer3, W3) and did some testing.
      As the Bugsplat takes place after a commit_operation in the RichSection plugin (without 'other' errors), I tried to find the conflict in the W3 code.
      I didn't find anything directly in common with the RichSection plugin, but I found these anomalies:
      • def getMaterials is a root method declared twice : once in windowizer,rb, once in getMaterials.rb; Even if the 'require getMaterials,rb' is comment out; the file is automatically loaded because it is directly in the Sketchup/plugins
      • The following classes are extended : Array, Sketchup::Face, Sketchup::Entity; Sketchup::ArcCurve; Sketchup::Curve
      • many Global variables
      • the global variable $wName is once a string [=Wdw.new.to_s.slice(6..14)] and later an empty class object [=Wdw.new]…..
        I tried to clean up the code for testing, but I can't see the end of it.
      As there is nothing specificly in common with RS (I mean : in common with RS but not with other plugins), I cleaned up the plugin directory and installed only Windowizer3 + Fredo's RoundCorner
      It works fine for a (very) small model.
      But for more a more complex models (50 identical component-instances: in total (nested) about 9500 edges, 3300 faces), I had directly a Bug-splat when creating round corners around one face within the component.
      I uninstalled Windowizer3 (the files) and did the same manipulation : Eventing worked fine.
      I think that the plugins of Fredo are a reference for the Sketchup community.
      CONCLUSION : Windowizer 3 is not a stable plugin. I didn't spent my money to test the payed version ….
      Windowizer is not distributed on Sketchucation, but maybee it is important to tell people that it causes Bugsplats in other plugins.
      • ladcweiL
        ladcwei
        I am waiting for this plugin for five years,then I could handle whole design with Su &layout completely today!Thanks a lot!
        It's another plugin for sections:
        http://www.sublog.net/?s=realsection
        it could assign diffferent materials to different grounps,maybe it could give some useful ideas...
        I am chinese,you can download this plugin on http://www.sublog.net for free,needn't to pay,this site show all the resourse here,it's a good guide! 😄
        • P
          pgarmyn
          @ladcwei said:
          ....http://www.sublog.net/?s=realsection
          Hallo ladcwei
          You can also assign different materials in the RichSection plugin: by layer, by nature (color) or a combination.
          It's much faster than assigning materials to individual elements, but you will have to organize your model and use different layers to assign different section-materials.
          I know realSection (GWD), there is also SectionCutface (TIG), and other good plugins.
          Each plugin is different. I wanted to offer projection.
          [highlight=#ffff40:y89ppu1f]So what were you waiting for during 5 years ? ❓ ❓[/highlight:y89ppu1f]
          Thanks for the interest.
          • P
            pgarmyn
            I added two new videos.
            In the last video, I produced a plan with [highlight=#ffff00:3n6bzrcv]SKETCHUP + RichSection + LAYOUT[/highlight:3n6bzrcv]:
            See video and attached PDF file (RichSection-demo-04.PDF) in the first post.
              Absolutly astonishing! 😎
              (tested in V8)
              Another plugin who makes bugsplatsh :wxSU.rb !!!
              Does it posible to delete these dotted lines in the free space ?
              ( i have not yet explore the plugin! 😳
              Ps Why you don't say on the first post that the UI of Rich Section is working automatically also in French? ☀
              rich4.skp
              • P
                pgarmyn
                (tested in V8)
                [attachment=1:3822h56j]<!-- ia1 -->rich2.jpg<!-- ia1 -->[/attachment:3822h56j]
                %(#0000FF)[Bonjour Pilou. Quel honneur ❗
                Pour enlever ces lignes, il suffit d'éteindre 'PROJECTION'. (La section calculera aussi beaucoup plus vite).
                Dans les dessins technique (architecture), la projection représente les éléments au-dessus du plan de projection.
                On peut aussi limiter la projection (par distance, calques). Une démonstration (distance de projection limitée) est faite dans video #03.
                Je vais ajouter : Si la version de SU est française, elle chargera RichSection en français..]
                For the rest of the world:
                To take away those pointed lines, just switch off 'PROJECT'. (The section will also calculate faster).
                In technical drawings (architecture), 'projection' represents the elements above the section-plane.
                You can also controle wich elements are projected (by distance, layers). This is demonstrated (with projection limited by distance) in video #03.
                For people with a french SU, the program will load a french RichSection dictionary.
                For the rest of the world: are there traductors on this forum?
                • P
                  pgarmyn
                  For more important (big, complex) drawings. It is worth to use SU 2013. MUCH MUCH faster ❗ ❗ ❗
                    Excellent! 😎 👍 ☀
                    • P
                      pgarmyn
                      deleted double message
                      • P
                        pgarmyn
                        If someone want's to pay for my RichSection [Demo] plugin :
                        [highlight=#ffff00:2ljx047o]They sell (correction) USE it already in China:[/highlight:2ljx047o] 🤣 🤣
                        Document
                        (www.sublog.net)
                        I can't explain much in chinese, so i added an other video (above). 😆
                        • emerald15E
                          emerald15
                          Thank you. I've just completed a more than usually complex drawing that required cross sections. I use RichSection to great effect. I really like all the additional optional colours, line types & infills.
                          • P
                            pgarmyn
                            May we see the result ❓ 😎
                            • I
                              ivreich
                              YES 😄 the 2nd video is showing that 😄
                              Use RichSection materials 'by layer' or 'by nature' or a combination.
                              Every RichSection can also have different section materials, by using a different 'prefix'
                              Hey there..
                              I've managed to figure out how to create different hatch patterns for objects on different layers, but I can't seem to create different hatch patterns for objects with different materials. It always goes back to the default pattern?
                              Also, I don't quite understand the options for the richsection material - what is the difference between "prefix+layername, prefix+materialname, default" and "prefix+materialname, prefix+layername, default"?
                              As I mentioned, I just can't seem to get material names to work in defining different hatch patterns...please help!
                              Thanks...
                              Joel
                              • ladcweiL
                                ladcwei
                                I think it could make good effect more safely 😉
                                • P
                                  pgarmyn
                                  @ivreich said:
                                  ..... I don't quite understand the options for the richsection material - what is the difference between "prefix+layername, prefix+materialname, default" and "prefix+materialname, prefix+layername, default"?
                                  ...please help!
                                  Thanks...
                                  Joel
                                  Hi Joel
                                  Supposing
                                  • Model : you used layers L1 and L2
                                  • Model : you applied the following materials to groups and components : N1 and N2
                                    First possibility :
                                  • Model : existing materials in library 'in model' : #L1.... / NOT existing materials : #L2
                                  • RS-options : prefix = #
                                  • RS-options : default material = #default
                                  • RS-options : section material = prefix+layername, default
                                  • RS section materials for a group or component in layer L1 : #L1
                                  • RS section materials for a group or component in layer L2 : #default (because #L2 doesn't exist)
                                    2nd possibility :
                                  • Model : existing materials in library 'in model' : #N1.... / NOT existing materials : #N2
                                  • RS-options : section material = prefix+materialname, default
                                  • RS section materials for a group or component with material N1 assignd: #N1
                                  • RS section materials for a group or component with material N2 assignd: #default (because #N2 doesn't exist)
                                  Got it ❓ 😄
                                  • P
                                    pgarmyn
                                    It seems to be a very complex model ❗ ❗ ❗
                                    What kind of building is it ? With a giant bell at the center ?
                                    Maybee the bell needs some thickness. You can do this with the Joint PushPull plugin from Fredo.
                                    Thanks for sharing your experiance.
                                      sexypox69
                                      Cant get it to work like in the videos....it just works as sketchup native section cut, also sketchup crashed a few times (bugsplat)....but i love the intention. It would save me the time to go put in hatches in my layout documents
                                      • ladcweiL
                                        ladcwei
                                        Yes,it's a temple for new year,it attracts much people to ring the bell on the three floors,it is supposed to be a kind of memorial tower.
                                        However,in some complex models,the plugin could give section lines but never fill the hole,I don't know is there some problem has not been solved? It seems to work right.
                                          ArCAD-UK
                                          Missing faces also happens with 🤓 TIG's Section Cut Face. He has done a lot of checks on it but there can still be situations in a model where a face can be missing without reason. 😕
                                          • P
                                            pgarmyn
                                            Hallo,
                                            To know what is going on first exclude this :
                                            • ...as native Sketchup : Did you used groups or components ?
                                            • Did you activate the plugin? (Menu Windows/preferences >> extensions). Is there RichSection-panel and a RichSection menu ?
                                            • Open de Ruby console (open the 'Windows' menu, and then click 'Ruby Console'): do you have any errors here while placing RIchSection cuts?
                                            • Bug Splat : What other plugins are installed? There can be incompatibility : see first post. Unactivate all other plugins, restart SU and test again the RichSection plugin. This should work !
                                            I see you have SU 8 installed. I suggest to install SU2013 make (you can keep SU8). It faster and much more stable.
                                            Then install (first and only) the RichSection plugin. It should work ! If it is the case, instal the other plugins, and test after each installation.
                                            Please tell me if you got it working 😄
                                            • 19
                                            • 20
                                            • 3 / 20
