[Plugin] RichSection V0.5.8 UPDATED march 2015
@tig said:
Because your code is all encrypted we don't know what it does.
If it has any 'offset; methods within it that are not encapsulated in your module/class methods, then your 'offset()' method might well clash with the bald scripted 'offet.rb' by RickW, if users have that loading with other scripts.
Your code must not interfere with base class/module/methods or other's scripts that load as helpers - these are things like offset.rb, progressbar.rb and so on... It's easy enough to recast your own versions within your own modules so there is no overlap with other scripts...About my code:
- Every method, variable, ... is declared within module PiGa ; module RSection ; end ; end
- No basic classes or modified or extended.
And this is the case for the loader PiGa_RichSection.rb, and the main ruby RichSection.rbs
That wasn't yet good practice in 2004 (Looking in code of offset.rb)
I scanned my code : there is no method 'offset' or anything else named 'offset'So, if there is something The problem is not there.
Please, micione tell me....
What's happening ? How do you know there is a conflict ?
What other plugin is using offset.rb ? (Probably anther plugin from Rick Wilson) -
pgarmyn,
"offset.rb" is used by other tools of Rick Wilson (eg "windowizer").
What happens:
Your tool applies the first section, then it stops, stuck.
Any attempt to use the "move tool" on the section, it causes BugSplat.Only by removing "offset.rb" your tool starts working again.
In order to identify the conflict, must be eliminated (one by one) all installed plugins. And this is what I did.
I hope I was helpful.P.S. perhaps seek the advice of Rick Wilson?
@micione said:
pgarmyn,
"offset.rb" is used by other tools of Rick Wilson (eg "windowizer").....
I will test it out. Tomorrow -
A futur hit for sure!
When you say Demo, will be commercial at the end ?Maybee commercial... . But I will also keep a FREE version .
Until March 2014, everybody can have the full 'DEMO'(Thanks for the correction Bob James)
As 'RichSections' are standard SU-groups, they only need the plugin for update. -
The issue might be that
offset.rb
[ill advisedly] adds a new method toArray.offset(distance)
* this clashes with thePoint3d.offset(vector, distance)
because an Array of three values [x,y,z] can be offset just as it it were a Point3d, but the native method is expecting a Vector3d [or an Array of three [xv,yv,zv]] and an optional second argument of a distance that overrides the vector's length...*In my copy of
offset.rb
I have renamed it asoffsetArray(dist)
to avoid the clash [it's never used anyway!].So to avoid clashes with the
offset.rb
methodArray.offset()
never use.offset()
on point that is expressed as an Array - make that array into a Point3d before the offset is applied, then the clash is avoided.
So it should be
point=Geom::Point3d.new(0,1,2)
[or...new([0,1,2])
then
point.offset(vector)
or in one step
Geom::Point3d.new([0,1,2]).offset(vector)
BUT NEVER
[0,1,2].offset(vector)
or
pt=[1,2,3] pt.offset(vector)
Amazing!!
This plugin cover one of the CAD missing function in sketchup.
Now I need to check it in layout.Thank you pgarmyn!
Wow, this is a amazing! This is starting to make Sketchup look more like a CAD modeler! Well done. I-Render Nxt also renders section cuts similar to Indigo. I will also try this with this and Layout later!
offset.rb
* this clashes ...Thanks TIG and micione, for the analysis
Anyway, I don't think Array.offset is the reason for the incompatibility. As I said, no method in my plugin uses offset.
I just installed Windowizer-3 (W3) beside RichSection (RS) in SU8.
In this version of Windowizer there is no def offset(dist) for class Array.
I confirm Bugsplat when combining both plugins. When using RS or W3,
But after uninstalling RS (also the files), I have also have Bugsplats in W3 for complex models (many nested groups).Bugsplat in RS (combined with W3) takes always place at the end, after a commit operation,
TO BE CONTINUED....
Impressed so far
Feedback:
Why create two scenes? I appreciate they are different but do you really need two when the change is simply a toggle of the section plane?
RICHSECTION NAME is strange when using custom names e.g. the resulting names aren't as expected
It might be useful to have a simple continuous line in the Projection line styles.
@arcad-uk said:
Impressed so far
Feedback:.....
Why create two scenes? The first scene is for editing: The camera is not saved, the sectionplan is visible. The second scene (name+p : for parallel view) is for those who really use it (directly) in layout: camera saved, sectionplan not visible. But i can put some swiches in the RichSection settings.
RICHSECTION NAME is strange ...... Dont understand. Is it the 'p' at the end?
It might be useful to have a simple continuous line.... : In what case? Exemple?
Thanks for your interest.
Last night my first section entry [XL01] was replaced with [XL0001] today everything seems ok I may have used "undo" and messed things up.
There is a lot going on when creating an RS, can I do a complete undo with 1 click?
I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode.
You do know that you can do this in Hatchfaces ? If you want real edges as hatches from section slice that is.
I will have a look at that thanks! I'm not a fan of raster hatching...
Check out the help files, if that does not work for you, you can PM me and fire the questions. Or if you rather post a question in Hatchafaces topic thats fine too.
I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. (
Undo : I can't undo scenes and styles loaded (from file). The SU API for Ruby has no functions to create them from scratch. I have to load them from a file. No way, at my knowledge, to include this in the undo DB (within start and commit_operation).
Controle vector output (with color and line style) to Layout : I can only dream of it.
Hi TIG, micione and others...
As I said before (see 'TO BE CONTINUED'), I loaded the free version (Windowizer3, W3) and did some testing.
As the Bugsplat takes place after a commit_operation in the RichSection plugin (without 'other' errors), I tried to find the conflict in the W3 code.
I didn't find anything directly in common with the RichSection plugin, but I found these anomalies:- def getMaterials is a root method declared twice : once in windowizer,rb, once in getMaterials.rb; Even if the 'require getMaterials,rb' is comment out; the file is automatically loaded because it is directly in the Sketchup/plugins
- The following classes are extended : Array, Sketchup::Face, Sketchup::Entity; Sketchup::ArcCurve; Sketchup::Curve
- many Global variables
- the global variable $wName is once a string [=Wdw.new.to_s.slice(6..14)] and later an empty class object [=Wdw.new]…..
I tried to clean up the code for testing, but I can't see the end of it.
As there is nothing specificly in common with RS (I mean : in common with RS but not with other plugins), I cleaned up the plugin directory and installed only Windowizer3 + Fredo's RoundCorner
It works fine for a (very) small model.
But for more a more complex models (50 identical component-instances: in total (nested) about 9500 edges, 3300 faces), I had directly a Bug-splat when creating round corners around one face within the component.
I uninstalled Windowizer3 (the files) and did the same manipulation : Eventing worked fine.
I think that the plugins of Fredo are a reference for the Sketchup community.CONCLUSION : Windowizer 3 is not a stable plugin. I didn't spent my money to test the payed version ….
Windowizer is not distributed on Sketchucation, but maybee it is important to tell people that it causes Bugsplats in other plugins.
I am waiting for this plugin for five years,then I could handle whole design with Su &layout completely today!Thanks a lot!
It's another plugin for sections:
http://www.sublog.net/?s=realsection
it could assign diffferent materials to different grounps,maybe it could give some useful ideas...
I am chinese,you can download this plugin on http://www.sublog.net for free,needn't to pay,this site show all the resourse here,it's a good guide! -
@ladcwei said:
....http://www.sublog.net/?s=realsection
it could assign diffferent materials to different grounps,maybe it could give some useful ideas...Hallo ladcwei
You can also assign different materials in the RichSection plugin: by layer, by nature (color) or a combination.
It's much faster than assigning materials to individual elements, but you will have to organize your model and use different layers to assign different section-materials.I know realSection (GWD), there is also SectionCutface (TIG), and other good plugins.
Each plugin is different. I wanted to offer projection.
[highlight=#ffff40:y89ppu1f]So what were you waiting for during 5 years ? [/highlight:y89ppu1f]Thanks for the interest.
I added two new videos.
In the last video, I produced a plan with [highlight=#ffff00:3n6bzrcv]SKETCHUP + RichSection + LAYOUT[/highlight:3n6bzrcv]:See video and attached PDF file (RichSection-demo-04.PDF) in the first post.
Absolutly astonishing!
(tested in V8)Another plugin who makes bugsplatsh :wxSU.rb !!!
Does it posible to delete these dotted lines in the free space ?
( i have not yet explore the plugin!Ps Why you don't say on the first post that the UI of Rich Section is working automatically also in French?
