    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • micioneM
      micione
      Report a conflict with "offset.rb."
      attached file.
      offset.rb
      • doush-007D
        doush-007
        Hello,
        i install the plugin but it doesn't appear any where , i searched in toolbar menu , any idea ?
        I am using sketchup 2013.
        • P
          pgarmyn
          attached file.
          Ok, thanks. I will try to fix that. It will take some time.... ❗
          • P
            pgarmyn
            @doush-007 said:
            Hello,
            A new plugin must be activated in the menu 'window/preferences',
            a panel opens, select 'extensions' and activate 'RichSection'.
            • doush-007D
              doush-007
              thanks a lot πŸ˜„
              • P
                pgarmyn
                attached file.
                Offset.rb is not a standalone plugin (Can be called by other plugins). It is from Rick Wilson, created in 2004.
                What's happening ❓ How do you know there is a conflict ❓
                What other plugin is using offset.rb ? (Probably anther plugin from Rick Wilson) ❓
                  Because your code is all encrypted we don't know what it does.
                  If it has any 'offset; methods within it that are not encapsulated in your module/class methods, then your 'offset()' method might well clash with the bald scripted 'offet.rb' by RickW, if users have that loading with other scripts.
                  Your code must not interfere with base class/module/methods or other's scripts that load as helpers - these are things like offset.rb, progressbar.rb and so on... It's easy enough to recast your own versions within your own modules so there is no overlap with other scripts... πŸ˜’
                  • P
                    pgarmyn
                    About my code:
                    • Every method, variable, ... is declared within module PiGa ; module RSection ; end ; end
                    • No basic classes or modified or extended.
                      And this is the case for the loader PiGa_RichSection.rb, and the main ruby RichSection.rbs
                    That wasn't yet good practice in 2004 (Looking in code of offset.rb)
                    I scanned my code : there is no method 'offset' or anything else named 'offset'
                    So, if there is something ❓ The problem is not there.
                    Please, micione tell me....
                    What's happening ? How do you know there is a conflict ?
                    • micioneM
                      micione
                      pgarmyn,
                      "offset.rb" is used by other tools of Rick Wilson (eg "windowizer").
                      What happens:
                      Your tool applies the first section, then it stops, stuck.
                      Any attempt to use the "move tool" on the section, it causes BugSplat.
                      Only by removing "offset.rb" your tool starts working again.
                      In order to identify the conflict, must be eliminated (one by one) all installed plugins. And this is what I did.
                      I hope I was helpful.
                      P.S. perhaps seek the advice of Rick Wilson?
                      • P
                        pgarmyn
                        @micione said:
                        pgarmyn,
                        "offset.rb" is used by other tools of Rick Wilson (eg "windowizer").....
                        I will test it out. Tomorrow
                        • P
                          pgarmyn
                          A futur hit for sure! β˜€
                          When you say Demo, will be commercial at the end ?
                          Maybee commercial... . But I will also keep a FREE version .
                          Until March 2014, everybody can have the full 'DEMO'(Thanks for the correction Bob James)
                          As 'RichSections' are standard SU-groups, they only need the plugin for update.
                            The issue might be that offset.rb [ill advisedly] adds a new method to Array.offset(distance)* this clashes with the Point3d.offset(vector, distance) because an Array of three values [x,y,z] can be offset just as it it were a Point3d, but the native method is expecting a Vector3d [or an Array of three [xv,yv,zv]] and an optional second argument of a distance that overrides the vector's length...
                            *In my copy of offset.rb I have renamed it as offsetArray(dist) to avoid the clash [it's never used anyway!].
                            So to avoid clashes with the offset.rb method Array.offset() never use .offset() on point that is expressed as an Array - make that array into a Point3d before the offset is applied, then the clash is avoided.
                            So it should be
                            point=Geom::Point3d.new(0,1,2) [or ...new([0,1,2])]
                            then
                            point.offset(vector)
                            or in one step
                            Geom::Point3d.new([0,1,2]).offset(vector)
                            BUT NEVER
                            [0,1,2].offset(vector)
                            or
                            pt=[1,2,3] pt.offset(vector)
                            πŸ˜’
                            • G
                              gbing
                              Amazing!!
                              This plugin cover one of the CAD missing function in sketchup.
                              Now I need to check it in layout.
                              Thank you pgarmyn!
                              • ElibjrE
                                Elibjr
                                Wow, this is a amazing! This is starting to make Sketchup look more like a CAD modeler! Well done. I-Render Nxt also renders section cuts similar to Indigo. I will also try this with this and Layout later!
                                • P
                                  pgarmyn
                                  @tig said:
                                  The issue might be that offset.rb [ill advisedly] adds a new method to Array.offset(distance)* this clashes ...
                                  Thanks TIG and micione, for the analysis πŸ‘
                                  Anyway, I don't think Array.offset is the reason for the incompatibility. As I said, no method in my plugin uses offset.
                                  I just installed Windowizer-3 (W3) beside RichSection (RS) in SU8.
                                  In this version of Windowizer there is no def offset(dist) for class Array.
                                  I confirm Bugsplat when combining both plugins. When using RS or W3,
                                  But after uninstalling RS (also the files), I have also have Bugsplats in W3 for complex models (many nested groups).
                                  Bugsplat in RS (combined with W3) takes always place at the end, after a commit operation,
                                  TO BE CONTINUED....
                                    ArCAD-UK
                                    Impressed so far πŸ‘
                                    Feedback:
                                    Why create two scenes? I appreciate they are different but do you really need two when the change is simply a toggle of the section plane?
                                    RICHSECTION NAME is strange when using custom names e.g. the resulting names aren't as expected
                                    It might be useful to have a simple continuous line in the Projection line styles.
                                    • P
                                      pgarmyn
                                      Feedback:.....
                                      Why create two scenes? The first scene is for editing: The camera is not saved, the sectionplan is visible. The second scene (name+p : for parallel view) is for those who really use it (directly) in layout: camera saved, sectionplan not visible. But i can put some swiches in the RichSection settings.
                                      RICHSECTION NAME is strange ...... Dont understand. Is it the 'p' at the end?
                                      It might be useful to have a simple continuous line.... : In what case? Exemple?
                                      Thanks for your interest. πŸ˜‰
                                        ArCAD-UK
                                        Last night my first section entry [XL01] was replaced with [XL0001] today everything seems ok πŸ˜• I may have used "undo" and messed things up.
                                        There is a lot going on when creating an RS, can I do a complete undo with 1 click?
                                        I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. 😞
                                        • jolranJ
                                          jolran
                                          You do know that you can do this in Hatchfaces ? If you want real edges as hatches from section slice that is.
                                            ArCAD-UK
                                            I will have a look at that thanks! I'm not a fan of raster hatching...
                                            • 19
                                            • 20
                                            • 2 / 20
