    Sketchup and Blender
    extensions
    170 Posts 26 Posters 33.4k Views 26 Watching
      • soloS Offline
        @rich o brien said:
        Here you go....
        [attachment=0:7zja5vc2]<!-- ia0 -->thea-logo-su.zip<!-- ia0 -->[/attachment:7zja5vc2]
        Load file
        Press 0 for Camera view
        Press Alt+A to play animation
        That is a clean logo. Hmm, basic mesh with a sub-D modifier only.
        So this is modeled in SU, exported to Blender and added a modifier only?
        I'd love to sit next to you as you model this in SU as I cannot seem to get my head around what tools you used and your workflow, then I need to still figure out the material assigning in Blender, I did a tutorial this weekend and it's already forgotten. πŸ˜•
          Yes modeled in SU to a point just to figure out vert placement and form. Then into Blender for tweaking and some edge loops, creases and sub-d
            BTW, a better way to figure what key does what...
            http://waldobronchart.be/blenderkeyboard/
            • soloS Offline
              Now I'm goofing around with fluid flow.
              I'm learning Blender arse about face, doing fluids, then particles and fabric.
              I want to have fun learning.
              Some crazy DOF and HDRI lighting with a few emitters.
                Is that with Thea plugin?
                • soloS Offline
                  Yes.
                    I must invest in it.
                    • soloS Offline
                      Looks like it's free.
                      (www.thearender.com)
                      Oh, do follow the installation guide as I messed up initially, there are a couple of steps that are important.
                        Awesome...
                          Next up is to try out some Cell Fracture...enable under preferences > addons
                          • soloS Offline
                            [attachment=0:120nuup0]<!-- ia0 -->thea-cracked.gif<!-- ia0 -->[/attachment:120nuup0]
                            So where does one get a tutorial or instructions on how to use these plugins?
                              Most I just muddle into...
                              I see a technique used for something different and tend to adapt it.
                              Here I realised that the Cell Fracture tool and some keyframing on scaling might look nice.
                              Not quite but something to file away....
                              There's an extensive tutorial on Cell Fracture on how to shoot a coffee cup with a bullet.
                              • soloS Offline
                                Found it: http://www.youtube.com/watch?v=DEo_9AopfoQ
                                  That's the one. Pretty involved but covers some killers parts of blender. Expect 4 days to complete that.
                                  You really should pick an object or topic and run with it.
                                  I remember nearly 3yrs ago starting off on v2.5 and doing the same tutorial nearly 10 times until I didn't need to reference the video.
                                  That helped loads. Boring but worth it.
                                  Another good one is Kent Tramell's human male head modelling series. Nearly 12hrs but mesmerising stuff.
                                  • soloS Offline
                                    That was fun, here is a very low resolution gif of my first try.
                                    Click on image to animate.
                                      Great stuff.
                                      Next is to see what the Build modifier can do. You like that I think.
                                      • michaliszissiouM Offline
                                        michaliszissiou
                                        Hey guys…
                                        You really need a lot of help.
                                        We could try a meeting
                                        google hangout.
                                        Sharing screens etc
                                        I do it all the time.
                                        for instance, you won't find a good UV tutorial around
                                        neither a good tutorial on cycles.
                                        Oh my,
                                        You could join the blender sculpting club instead.
                                        TIP OF THE DAY
                                        [0] num pad for camera view.
                                        Select your object or something in the center of the scene
                                        On [N] panel, check LockCameraToView.
                                        Navigate now, zoom etc.
                                        Uncheck LockCamera, zoom so the camera window fill your view port, check LockCamera again, navigate
                                        More friendly to SUpUsers?
                                          DOD3R
                                          Hi solo,
                                          Can you share story about your journey from SU to blender. I know you mentioned some Cinema4d somewhere.
                                          I think it must be interesting.
                                          I am myself was lurking around blender for a long time. It supposed to be a solution for uv mapping absence in SU, but i so far had no time to invest my time into it.
                                          D.
                                            archigrafix
                                            Hi Solo and everyone I think I will join youonthis Blender trip...
                                            I myself many times tried to jump from SU to Blender or SU to Modo, but always switched back to SU. Why? Mostly because I work on architectures and I feel so well an easy for that in Sketchup. Anyway if I want to go further on architectural renderings: HighPoly,UVs, integrated renderer etc... Blender feels a good choice
                                            I recently booked to Andrew Price Architectural academy and I feel it very nice and exciting, if only I get more time to spend on it of course 😳
                                            Agir comme un homme de pensΓ©e, et penser comme un homme d'action...
                                            • 2 / 9
