    Sketchup and Blender
    extensions
    170 Posts 26 Posters 37.5k Views 26 Watching
      Next up is to try out some Cell Fracture...enable under preferences > addons
      • soloS Offline
        [attachment=0:120nuup0]<!-- ia0 -->thea-cracked.gif<!-- ia0 -->[/attachment:120nuup0]
        So where does one get a tutorial or instructions on how to use these plugins?
          Most I just muddle into...
          I see a technique used for something different and tend to adapt it.
          Here I realised that the Cell Fracture tool and some keyframing on scaling might look nice.
          Not quite but something to file away....
          There's an extensive tutorial on Cell Fracture on how to shoot a coffee cup with a bullet.
          • soloS Offline
            Found it: http://www.youtube.com/watch?v=DEo_9AopfoQ
              That's the one. Pretty involved but covers some killers parts of blender. Expect 4 days to complete that.
              You really should pick an object or topic and run with it.
              I remember nearly 3yrs ago starting off on v2.5 and doing the same tutorial nearly 10 times until I didn't need to reference the video.
              That helped loads. Boring but worth it.
              Another good one is Kent Tramell's human male head modelling series. Nearly 12hrs but mesmerising stuff.
              • soloS Offline
                That was fun, here is a very low resolution gif of my first try.
                Click on image to animate.
                  Great stuff.
                  Next is to see what the Build modifier can do. You like that I think.
                  • michaliszissiouM Offline
                    michaliszissiou
                    Hey guys…
                    You really need a lot of help.
                    We could try a meeting
                    google hangout.
                    Sharing screens etc
                    I do it all the time.
                    for instance, you won't find a good UV tutorial around
                    neither a good tutorial on cycles.
                    Oh my,
                    You could join the blender sculpting club instead.
                    TIP OF THE DAY
                    [0] num pad for camera view.
                    Select your object or something in the center of the scene
                    On [N] panel, check LockCameraToView.
                    Navigate now, zoom etc.
                    Uncheck LockCamera, zoom so the camera window fill your view port, check LockCamera again, navigate
                    More friendly to SUpUsers?
                      DOD3R
                      Hi solo,
                      Can you share story about your journey from SU to blender. I know you mentioned some Cinema4d somewhere.
                      I think it must be interesting.
                      I am myself was lurking around blender for a long time. It supposed to be a solution for uv mapping absence in SU, but i so far had no time to invest my time into it.
                      D.
                        archigrafix
                        Hi Solo and everyone I think I will join youonthis Blender trip...
                        I myself many times tried to jump from SU to Blender or SU to Modo, but always switched back to SU. Why? Mostly because I work on architectures and I feel so well an easy for that in Sketchup. Anyway if I want to go further on architectural renderings: HighPoly,UVs, integrated renderer etc... Blender feels a good choice
                        I recently booked to Andrew Price Architectural academy and I feel it very nice and exciting, if only I get more time to spend on it of course 😳
                        Agir comme un homme de pensée, et penser comme un homme d'action...
                        • soloS Offline
                          @dod3r said:
                          Hi solo,
                          D.
                          DOD3R, I really have no story, I did try Cinema4D and thought it was great but it was pricey and not as comprehensive as Blender that has everything one could possibly need and free. The thing is when I initially tried to learn Blender in 2005 it was one big mess, the UI was all over the place and short cuts and keys did not match between modeling tools, now with the whole new UI it's a hell of a lot better but still not as polished as say Maya, but certainly getting there fast. The best resource for Blender is Google as I can Google any question and I get a solution or even a YouTube tutorial.
                          That being said I am also very lazy, and learning new software is like scraping nails across a blackboard, I usually only learn things I need to know relevant to a project. However I decided to find fun stuff to do in Blender and follow tutorials in order to create them, doing so I will learn all the other stuff around them and hopefully by the end of a few cool tutorials I will have the knowledge to try something on my own.
                          • cottyC Offline
                            cotty
                            Is that the new basecamp hat in your avatar? 😉
                            my SketchUp gallery
                              jpalm32
                              Really enjoying this thread solo.
                              I loaded and unloaded Blender so many times.
                              Maybe I should give another try.
                              • soloS Offline
                                When I get time I will play, this time I tackled UV mapping. The globe has got a basic map, a bump map, a specular map and then a larger cloud map.
                                • CadFatherC Offline
                                  CadFather
                                  great idea Solo, and i see fast developments in this thread, i shall lock it on my speed dials. i also play with Blender once in a while, but nothing worth showing yet.
                                  one thing that comes to mind, is the danger of scattering the information in the thread, perhaps creating a second wiki-like thread, with only the 'working stuff' (which can be updated) and no comments?
                                  • andybotA Offline
                                    andybot
                                    Interesting point - this thread might become like the "D'oh" thread - many good nuggets buried in miles of posts.
                                    [By "good nuggets" I mean: each user will find different things useful - but not everything for everyone...]
                                    • soloS Offline
                                      I have found a great resource, an online quick-start course for Blender and it's free, it will take you through modeling a pencil from start to end, teaching you a lot of stuff as you go including UV mapping, face painting, creating bump and specular maps, rigging, posing,the works.
                                      Just a moment...
                                      (www.udemy.com)
                                      And here is a quick view of what I achieved half assed, something went wrong with my rigging that I need to figure out.
                                      CLICK TO ANIMATE
                                      • olisheaO Offline
                                        olishea
                                        This is a great thread 👍
                                        oli
                                        • arail1A Offline
                                          arail1
                                          When I first started using modo I found this short, simple video to be a helpful explanation of sub d modeling:
                                          • soloS Offline
                                            Andrew Price from Blender guru created this awesome trailer for the Architecture academy.
                                            • 4 / 9
