    Follow me tool pls
    41 Posts 8 Posters 3.1k Views 8 Watching
      You need to select a segment that is attached to other segments in the curve. Then you right click and choose Recurve in the Context menu.
      You would probably find it very useful to go to the thread for the plugin and read how it works.
      • E Offline
        erzane
        need I ''recurve 1,5'' plugin ?
          I'm not sure how you would expect to use Recurve if you don't have the plugin.
          • E Offline
            erzane
            ok, now I see better why I didn't find it on the skp menu
            so, I downloaded the plugin
            but when I >select curve >right clic >recurve edges
            it give me this strange result
            it change the form of my curve
            I select and recurve edges
            strange result
            • E Offline
              erzane
              now I have a good result enough
              after recurve and recurve, and modify my paths a bit
              but I still don't understand why have I 3 pipes with horizontal lines all along them.
              all the other pipes are ok, only those 3 as you can see are stranges (2 on the very left, and the 3rd on the very right side)
                It looks as if the profile you used for the Follow Me operation was exploded. Just select all of the geometry in those "cables", right click and choose Smooth/Soften. Adjust the slider if you have to.
                • BoxB Offline
                  And you wouldn't need Dave's fix if you had used recurve on the circle of the profile as well as the path before follow me.
                  • E Offline
                    erzane
                    Dave : smooth/soften option is very god, it clean all kind of small undesirable details
                    thanks a lot for that tip
                    Box : yes I didn't think about recurve the circles in fact
                    p.s. as I see, recurve is not very necessary if I can use smooth/soften option for repare right ?
                    p.s.' I found a solo ''smooth'' option in the same menu for erase single lines
                    here is the result after smooth/soften
                      The nice thing about using Recurve on your Follow Me paths is that it makes them easier to select if you preselect the path before running Follow Me on the profile. Especially when the profile is small and the path is long, it is nice to be able to select the path with a single click. You won't have to chase around the model to select all of the path lines.
                      • BoxB Offline
                        There are many ways to do things in sketchup. Different situations and workflow make different tools more relevant to the particular applications. There are probably 10 more ways we could come up with to do what you are doing, but it is all about learning what is possible. You need to work out what works best for you. personally I prefer to get the construction right to begin with rather than spending time repairing things. The soften/smooth setting isn't designed to hide things.
                        • E Offline
                          erzane
                          I learned a lot of thing on this thread, thanks a lot guys
                            It is indeed best to fix things and make them right as you go along. Much easier than going back and repairing the model later. Sloppy modeling up front just means more work in the end.
                            • E Offline
                              erzane
                              I agree,
                              thanks for your tips
                              • F Offline
                                Futurepast
                                @tig said:
                                Look up 'weld' in a dictionary...
                                It means to join separate pieces together to form a single object.
                                In English it usually refers to metal things...🤓
                                A duuh moment for me! Arc Weld, Mig Meld, Tig weld........TIG WELD I get it now! 😆
                                • 2 / 3
